2 Replies Latest reply on Aug 21, 2007 9:50 PM by aceinc
    Flash 9 Debug
    caltman
      I am new to Flex Builder 2 and I am going through an Adobe Traing from the Source book to learn how to use Flex. When I click the debug tool I receive and error that says:
      Installed Flash Player is Not a Debugger
      C:\WINDOWS\system32\Macromed\Flash\Flash9b.ocx
      Flex Builder cannot locate the required debug version of the Flash Player. You may need to install the debug version of Flash Player 9.0 or reinstall Flex Builder. Do you want to try to debug with the current version?
      I installed Flex once and it states that it installs the Flash 9.0 with the debugger but I is not working. How can I fix this issue?
      Carroll Altman
        • 1. Re: Flash 9 Debug
          ur_dtrain Level 1
          You should be able to find the installers here:
          C:\Program Files\Adobe\Flex Builder 2\Player\debug
          Or substitute your install path.
          You should probably uninstall your existing Player first.
          • 2. Re: Flash 9 Debug
            aceinc
            I followed these instructions, I deinstalled all Flash versions installed, when I do the install I see a message fly by about not being able to load something. When it completed I didn't have flash installed, and had to re-download flash from the adobe web site.
            Where do I go from here?
