6 Replies Latest reply on Nov 30, 2006 1:54 PM by cgacfox
    Help my knife tool is grayed out!
    cgacfox
      I have been using Fireworks for a number of years now. I need to create a graphic header and drew a rounded-rectangle. I want to cut it in half but noticed that my knife tool is grayed out. It has always worked in the past. What could have happened to it? How do I get it back to functioning? Please help!
        • 1. Re: Help my knife tool is grayed out!
          Level 7
          > help!
          Make sure you haven't accidentally flattened the object you want to use
          the knife tool on. It won't work on bitmaps.
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: Help my knife tool is grayed out!
            cgacfox Level 1
            I didn't flatten it. I drew the rectangle and wanted to cut the top off but the knife tool is grayed out for some reason. I started over again and still nothing. Not sure what is going on.
            • 3. Re: Help my knife tool is grayed out!
              Level 7
              Try deleting the Fireworks preferences text file. That will set
              everything back to the original defaults the next time you load the
              program.
              • 4. Re: Help my knife tool is grayed out!
                cgacfox Level 1
                Thank you. I will try that. Where exactly is that file located? I just went into my program files for Fireworks MX 2004 and cannot find the file. Again thanks for your help.
                • 5. Re: Help my knife tool is grayed out!
                  Level 7
                  On my machine it's located at
                  C:\Documents and Settings\Linda Rathgeber\Application
                  Data\Macromedia\Fireworks 8\English
                  • 6. Re: Help my knife tool is grayed out!
                    cgacfox Level 1
                    Thank you so much! That worked. I don't know what happened but that is much better now!
