1 Reply Latest reply on Sep 20, 2015 3:11 PM by KoMaruyama
    How is this Editing Trick done?
    bryced87 Level 1
      I found this video today, It's Remote Control cars that real very realistic. The guy filmed himself driving both of them. How did he edit them so it looked like they were both there at the same time? I've heard of Garbage Matts but when I use matts I can't get something to be in front or behind an object without part of the video cutting off. https://www.youtube.com/watch?v=60KvhR8fZHw
        • 1. Re: How is this Editing Trick done?
          KoMaruyama Adobe Community Professional
          Hilarious video (that guy needs a horn in the truck for Oranges the Cat (bridge scene))
          It looks like most of those shots are completed using simple garbage masks (or mattes) to reveal one take over the other.
          1. Both remote control trucks are shot using a "locked off camera", so there isn't any major movement in the background.
          2. There is a large gap between the first truck and the second (they never overlap)
          3. An animated mask shape isolates the second truck layer, revealing only the area slightly ahead of the second truck
          4. Animated Masks / Rotoscoping References on Adobe
          5. Alternatively, you might even use a simple transition wipe to marry the two video layers. (Reference on Adobe)
          The detail on those RC trucks (including the arm out the window) is excellent.
          Setting up the shoot is important.  He probably has both trucks ready (notice that they start off camera).
          Locked off camera / lights
          Drive one of the trucks through the scene.
          pick up the other remote and drive the other through the scene.
          In After Effects or PremierePro, edit/time-remap the trucks so they don't drive in the same location at the same time. You can do this with transparency turned down on one of the layers.
          Then, it's just a matter of rotoscoping one of the trucks.
          This works relatively well as long as the background doesn't change notably.
