Hi
I have a form where I want to populate a couple of fields when an option from a drop down is selected.
My column headers are
Product (This is the dropdown)
Description
Item Code
I found some code on these forums from a similar query and have popped it in but Im not sure if Im doing it right as I am getting errors.
Should I be selecting 'change' under show?
The code I have used is:
var sNewSel = event.value;
switch (sNewSel) {
case "Scott Slimroll Hand Towel Roll":
this.getField("Description").value = "Scott Slimroll Hand Towel Roll - 1ply - White";
this.getField("ItemCode").value = "PTKCSLHTROL1P-W";
break;
case "Scott 36 Folded Toilet Tissue":
this.getField("Description").value = "Scott 36 Folded Toilet Tissue 36 x 100";
this.getField("ItemCode").value = "PTKCSCTTIS2P-W";
break;
I have Commit on Select selected
Whats gone wrong?? The error I get is:
Views
Total Likes
Hi there,
in FormCalc, the statement 'switch' is not available, you would have to use if statements.
Make sure to use the FormCalc references manual to help you..
http://help.adobe.com/en_US/livecycle/es/FormCalc.pdf
Otherwise you can use the switch statement within JavaScript
Views
Total Likes
