2 Replies Latest reply on Sep 24, 2015 11:31 AM by shahnisarg28
    How can I add and remove a hidden raw of a table while checking and unchecking the checkbox??
    shahnisarg28 Level 1
      I want to add a 1*1 table, or saw just a cell with text field, when I check the checkbox and remove the same when I uncheck the checkbox. I have tried almost everything, but not showing the correct result. Can anyone please guide??
        • 1. Re: How can I add and remove a hidden raw of a table while checking and unchecking the checkbox??
          davidm84370181 Level 1
          Hello shahnisarg28,
          I think you can achieve what you want by simply utilizing the Action Builder provided by the program.
          You make the cell visible when the Checkbox is checked by:
          1. You right click the checkbox, select Actions - Add Action.
          2. You set
               Condition: When Checkbox is checked
               Result: (Show or Hide an Objet) = Sel the visibility of cell to visible
          You make the cell hidden or invisible when the Checkbox is unchecked by:
          2. You set
               Condition: When Checkbox is unchecked
               Result: (Show or Hide an Objet) = Set the visibility of cell to hidden.
          Tell me if that works out for you.
          Regards,
          David.
          • 2. Re: How can I add and remove a hidden raw of a table while checking and unchecking the checkbox??
            Hello davidm84370181,
            Thank you very much for you reply. It really helped.
            But, I have encountered an another situation.
            I have 10 raws of data, having 2 checboxes in every raw, named "satisfactory" and "unsatisfactory". Its a kind of survey.
            First thing I wanted to do is that, only one checkbox out of 2 can be checked, if one checks "satisfactory" automatically "unsatisfactory" should be unchecked and vice-versa. Which I did and working good.
            Another thing is that, if any "unsatisfactory" checkbox has been checked, a table at the bottom should appear.
            I coded both the things and works fine individually, but if I check "unsatisfactory" once, the table at bottom appears, and when I check "satisfactory" in the same raw, the "unsatisfactory" should be unchecked and the table at bottom should be hidden, which is not working in my case. I have tried a lot, but couldnt find any solution.
            Any help on this is highly appreciated.
            Thanks.
            Nisarg Shah
