2 Replies Latest reply on Sep 22, 2015 8:16 AM by jeffs612
    Rollover Image Arrangements
    jeffs612 Level 1
      Is it possible to have rollover images appear under other elements on the page? I have 4 links (in image form) on my 'homepage' (slide1) but the rollover image for each of the links is a large image in the background. It should appear underneath the 4 links. Thanks for any information/urls.
        • 1. Re: Rollover Image Arrangements
          RodWard Adobe Community Professional & MVP
          The Rollover Image and its Rollover Area (the invisible hit area) are always going to be together.  So if you place the rollover object on the bottom layer, you may find that its hit area is obstructed by other objects if there are too many other things on the slide.
          If what you are trying to do is replicate rollovers on a menu of some kind then you really need to rethink having those rollover images as small as possible.
          • 2. Re: Rollover Image Arrangements
            jeffs612 Level 1
            Thank you RodWard for your answer. It wasn't the one I wanted, but I will take your advise and rework the solution. Thanks!
