6 Replies Latest reply on Aug 10, 2016 6:10 AM by kimaldis
    Working with LRSocket, receiving
    kimaldis Level 1
      I'm trying to set up a communication between Lightroom and another process using LRSocket. I've worked out an LrSocket.bind with mode = "send" and that's all working fine but I cannot for the life of me get a receive working. Here's my Lua code:
      Connection = {
      function Connection.Listen( self, context )
              local running = true
              self.Listener = LrSocket.bind {
             functionContext = context,
                  port = 4242,
                  plugin = _PLUGIN,
                  mode = "receive",
                  onConnected = function( socket, port )
                       Debug.logn( "Listener connected on port " .. port )
                  end,
                  onMessage = function( socket, message )
                       Debug.logn( "Listener Got: " .. message );
                  end,
                  onClosed = function( socket )
                       Debug.logn( "Listener Closed on Port: " .. myPort )
                       running = false
                  end,
                  onError = function( socket, err )
                       if err == "timeout" then
                       end
                  end,
        } -- bind
        while running do
        LrTasks.sleep( 1/2 ) -- seconds
        end
        self.Listener:close()
      end
      I've been testing with both telnet and a short python snippet shown below. Telnet fails to connect at all, the Python code connects and the onConnected callback is called but, although text is being sent, the onMessage callback doesn't get called. I wondered if anyone had managed to make this work at all or if anyone has any pointers on what might be going wrong.
      import socket, select, sys, time
      def Send( msg ):
          TCP_IP = 'localhost'
          TCP_PORT = 4242
          BUFFER_SIZE = 1024
          MESSAGE = "Hello, World!"
          print "Sending on port ",  TCP_PORT
          s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
          s.settimeout(2)
          s.connect((TCP_IP, TCP_PORT))
          s.send(MESSAGE)
          print "Sent"
          s.close()
          time.sleep( 5 )
          print "Closed"
      Send( "Test")
      Many thanks.
        • 1. Re: Working with LRSocket, receiving
          kimaldis Level 1
          I should add, I am calling all of this within a function context and a within an async task:
          LrTasks.startAsyncTask( function()
            LrFunctionContext.callWithContext( 'socket_send', function( context )
                      local Replier = Connection
                      Replier:Listen( context )
                  end)
              end)
          • 2. Re: Working with LRSocket, receiving
            allengambrell2 Level 1
            I have been trying to use the new LrSocket for communication back and forth with a visual basic .net program.  I have been able to send a command to lightroom, but I cannot get lightroom to respond.
            Make sure the command you send has a new line char at the end.
            Here is the code I am using. This is based on some examples i saw somewhere. If someone could help me with the sending part. I cannot even get it to send to itself if I set the same port number.
            local LrSocket = import "LrSocket"
            local LrTasks = import "LrTasks"
            local LrFunctionContext = import "LrFunctionContext"
            local LrDialogs = import 'LrDialogs'
            local LrApplication = import 'LrApplication'
            local LrDevelopController = import 'LrDevelopController'
            local LrSelection = import 'LrSelection'
            LrLogger = import 'LrLogger'
            myLogger = LrLogger( 'exportLogger' )
            myLogger:enable( "print" )
            -- Global consts
            local RECEIVE_PORT = 9885
            local SEND_PORT    = 9886
            -- Global vars
            local SERVER = {}
            function process_Mess (command)
                dbgout("  Processing Mess")
                --dbgout(command)
                --LrDialogs.message( "Received Message", command, "info" );
                posblank1 = string.find  ( command, ' ', 1 )
                if posblank1
                  then
                    LRfunc = string.sub ( command, 1, posblank1-1)
                  else
                    LRfunc = command
                end
                dbgout ("  "..posblank1)
                dbgout (LRfunc)
                if LRfunc == "hello" then
                    dbgout ("    Action: = Hello")
                    LrDialogs.showBezel( "Hello", 2 )
                  dbgout ("Send Message")
                  SERVER:send( "Hello world \n" )
                   dbgout ("Message Sent")
               end
            end
            local function startServer(context)
                SERVER = LrSocket.bind {
                      plugin = _PLUGIN,
                      port = SEND_PORT,
                      mode = 'send',
                      end,
                  onConnecting = function( socket, port )
                        dbgout( "------- Server Waiting for Connection..")
                        dbgout( "-------   Port: "..port)
                    end,
                        dbgout( "------- Server Connected")
                    end,
                  dbgout( "------- Server Error")
                  dbgout( err)
                        socket:reconnect()
                      end,
            end
                LrFunctionContext.callWithContext( 'socket_remote', function( context )
                     dbgout("Socket Receive");
                    local client = LrSocket.bind {
                    plugin = _PLUGIN,
                    port = RECEIVE_PORT,
                    mode = 'receive',
                    onMessage = function(socket, message)
                        dbgout("Message:=")
                        dbgout(message)
                        process_Mess(message)
                    end,
                        dbgout( "Waiting for Connection..")
                    end,
                        dbgout( "Connected")
                    end,
                        socket:reconnect()
                        dbgout( "Closed")
                        SERVER:close()
                    end,
                    onError = function(socket, err)
                        if err == 'timeout' then -- reconnect if timed out
                        socket:reconnect()
                        end
                    end
                    while true do
                    end
                    client:close()
                    SERVER:close()
                end )
            end )
            • 3. Re: Working with LRSocket, receiving
              kimaldis Level 1
              It was the new line. Thanks for that.
              I can't see anything wrong with your code, maybe it's at the VB end. Did you try with telnet?
              I'll post working code when I'm all tidied up and in good order in a couple of days.
              • 4. Re: Working with LRSocket, receiving
                kimaldis Level 1
                As promised, my working example of using LrSocket. It's Mac tested, should work for Windows but you'll need Python installed. It's a very simple send receive plugin, the Python script takes input from the terminal, sends it to the Lightroom plugin, the Lightroom plugin responds with a simple "OK". Start the plugin listening with File->Plugin Extras->Connection Test, kill it by sending it "exit" from the Python script. You can fire up either end first and it'll wait for a connection from the other end.
                Code is reasonably well documented.
                My understanding of sockets is workmanlike but not extensive, there may be better ways of doing this.
                Plugin
                • 5. Re: Working with LRSocket, receiving
                  mattp75670702 Level 1
                  Hi, i'm trying to run your plugin and python script on windows 10 and i cant send or receive any messages. It's just not working. I also have my own plugin that support LrSocket and works on OSX but running it within windows just seems like nothing happens. I tried telnet and other tools to debug it. Nothing seems to see it. What is the Port that should be used? or maybe firewall is blocking it?
                  • 6. Re: Working with LRSocket, receiving
                    kimaldis Level 1
                    Hi Matt, sorry, I only just caught your message:
                    Couple of thoughts:
                    The lightroom plugin always needs to be started first. It times out after 10-15 seconds so you need to be sharpish about getting the Python script going.
                    Anything you send must be terminated with a new line. Lightroom doesn't respond until it sees one.
                    Send & receive ports have to be different using LrSocket. So if you use telnet you'll need to instances, one for sending another, on another port, for receiving. I don't know why they did this, it annoying.
                    you should be able to see send and receive ports in the plugin code.
                    LrSocket documentation is OK but there's a lot left unsaid, as you can see from the above. It took me a while to get it going.
                    I'm only developing on Mac for the moment. I don't have much I can say about Windows. Sorry.
