4 Replies Latest reply on Nov 30, 2006 10:58 AM by ur_dtrain
    Item Renderers and Data Grid control
    FlextasmicD Level 1
      Hello, I've run into a problem when using an item renderer in a datagrid.
      All I need to do is place a checkbox on every row of the data grid which is the easy bit. Ive set the datagrid property rendererIsEditor="true" which works and the checkboxes are displayed. However, when the datagrid is scrolled up and down, the check boxes randomly display checked and unchecked without any actual interaction with the check boxes. Obviously this is a render problem and I'm aware that this might be related to the datagrid only rendering the displayed rows only and not any hidden rows below or above but if anyone can tell be how to stop this from happening i'd really appreciate it.
      Many thanks in advance!
