2 Replies Latest reply on Sep 22, 2015 1:53 PM by angusm57634069
    buttons within rollover buttons?
    angusm57634069
      I have an indesign doc which is basically a world map. On the map several locations are marked which, when exported to PDF, and rolled over shows a popup with office info for that location.
      That i have no trouble with using buttons show/hide etc.
      However, within each rollover i need to add buttons for email/web links that can be clicked to open the relevant link.
      So can button within rollover buttons be made using Indesign?
      Ta.
        • 1. Re: buttons within rollover buttons?
          Jeffrey_Smith Most Valuable Participant
          This will work with 2 Buttons: Button 1 will have an action to show Button 2, and Button 2 can have an action to go to destination (email/web link). Also note: you can not apply a hyperlink to the text portion of the button, it needs to be accomplished as a button action.
          It will not work with 1 Button that has a rollover appearance. The rollover appearance is visual, not functional.
          • 2. Re: buttons within rollover buttons?
            angusm57634069 Level 1
            Hi there,
            Yeah ive managed to get round it by setting the trigger button to be on click rather than on rollover as with that when i rollover the link button within the rollover it hides the popup. Popup is then removed by adding a close button to the popup. A bit more cumbersome but should work fine.
