0 Replies Latest reply on Sep 22, 2015 1:32 PM by alexander_f
    AE CC 2015 Crash on Export
    alexander_f
      Previous versions of my project have rendered from both media encoder and AE 2015 without issue, but now the project is crashing whenever I export, regardless of codec choice or output resolution. The only plugin I am using is Animation Composer, and some scripts that use native AE functionality. I've attached a screenshot of the error, and the crash report in a quote (not sure if that's the proper way...). Any help would be greatly appreciated. Thanks!
      Process:              After Effects [10475]
      Path:                  /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/MacOS/After Effects
      Identifier:            com.adobe.AfterEffects
      Version:              13.5.1 (13.5.1)
      Code Type:            X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:          After Effects [10475]
      User ID:              503
      Date/Time:            2015-09-22 12:51:37.228 -0700
      OS Version:            Mac OS X 10.10.4 (14E46)
      Report Version:        11
      Anonymous UUID:        1B1C07B6-95E4-2621-902C-6A5F0CFAF6B9
      Sleep/Wake UUID:      7326E2E7-FB76-4D97-BDF6-0F68391671CB
      Time Awake Since Boot: 90000 seconds
      Time Since Wake:      14000 seconds
      Crashed Thread:        9
      Exception Type:        EXC_BAD_ACCESS (SIGBUS)
      Exception Codes:      KERN_PROTECTION_FAILURE at 0x0000000134c55000
      VM Regions Near 0x134c55000:
          Stack                  0000000134453000-0000000134c55000 [ 8200K] rw-/rwx SM=PRV  thread 9
      --> STACK GUARD            0000000134c55000-0000000134c56000 [    4K] ---/rwx SM=NUL  stack guard for thread 10
          Stack                  0000000134c56000-0000000134cd8000 [  520K] rw-/rwx SM=PRV  thread 10
      Thread 0:: Dispatch queue: com.apple.main-thread
      0  libsystem_kernel.dylib        0x00007fff8625248a __semwait_signal + 10
      1  libsystem_c.dylib            0x00007fff873fee50 usleep + 54
      2  com.adobe.AfterEffectsLib.framework 0x00000001002e0d8a TestEmergencyUnhandledExceptionHandler() + 2138
      3  com.adobe.AfterEffectsLib.framework 0x00000001002e19fc boost::_bi::bind_t<void, void (*)(bool, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >), boost::_bi::list_av_2<bool, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::type> boost::bind<void, bool, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, bool, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >(void (*)(bool, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >), bool, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >) + 1084
      4  com.adobe.dvacore.framework  0x0000000103a278dc boost::function0<void>::operator()() const + 28
      5  com.adobe.dvacore.framework  0x0000000103a6231c dvacore::threads::(anonymous namespace)::FunctionQueue::ExecuteOneFunction(boost::shared_ptr<dvacore::threads::(anonym ous namespace)::FunctionQueue>, bool) + 124
      6  com.adobe.dvacore.framework  0x0000000103a62e1c boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<bool, bool (*)(boost::shared_ptr<dvacore::threads::(anonymous namespace)::FunctionQueue>, bool), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::(anonymous namespace)::FunctionQueue> >, boost::_bi::value<bool> > >, void>::invoke(boost::detail::function::function_buffer&) + 60
      7  com.adobe.dvacore.framework  0x0000000103a278dc boost::function0<void>::operator()() const + 28
      8  com.adobe.dvacore.framework  0x0000000103a62ed2 dvacore::threads::(anonymous namespace)::RunLoopAdaptor::Execute(__CFRunLoopTimer*, void*) + 18
      9  com.apple.CoreFoundation      0x00007fff8c1142e4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
      10  com.apple.CoreFoundation      0x00007fff8c113f73 __CFRunLoopDoTimer + 1059
      11  com.apple.CoreFoundation      0x00007fff8c18753d __CFRunLoopDoTimers + 301
      12  com.apple.CoreFoundation      0x00007fff8c0cf608 __CFRunLoopRun + 2024
      13  com.apple.CoreFoundation      0x00007fff8c0cebd8 CFRunLoopRunSpecific + 296
      14  com.apple.HIToolbox          0x00007fff8801b56f RunCurrentEventLoopInMode + 235
      15  com.apple.HIToolbox          0x00007fff8801b2ea ReceiveNextEventCommon + 431
      16  com.apple.HIToolbox          0x00007fff8801b12b _BlockUntilNextEventMatchingListInModeWithFilter + 71
      17  com.apple.AppKit              0x00007fff8dcea8ab _DPSNextEvent + 978
      18  com.apple.AppKit              0x00007fff8dce9e58 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346
      19  com.apple.AppKit              0x00007fff8dcdfaf3 -[NSApplication run] + 594
      20  com.adobe.AfterEffectsLib.framework 0x00000001003318d1 CApplication::Run() + 65
      21  com.adobe.AfterEffectsLib.framework 0x00000001002a4cd4 MainMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, void**, int, int, int) + 1076
      22  com.adobe.AfterEffectsLib.framework 0x00000001002a486b EggMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, int) + 59
      23  com.adobe.AfterEffects        0x000000010000310e main + 1838
      24  com.adobe.AfterEffects        0x00000001000029d4 start + 52
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0  libsystem_kernel.dylib        0x00007fff86253232 kevent64 + 10
      1  libdispatch.dylib            0x00007fff8cf99a6a _dispatch_mgr_thread + 52
      Thread 2:
      0  libsystem_kernel.dylib        0x00007fff86252136 __psynch_cvwait + 10
      1  com.apple.CoreServices.CarbonCore 0x00007fff8b4a8a77 TSWaitOnCondition + 108
      2  com.apple.CoreServices.CarbonCore 0x00007fff8b4a8c76 TSWaitOnConditionTimedRelative + 171
      3  com.apple.CoreServices.CarbonCore 0x00007fff8b47ed6b MPWaitOnQueue + 192
      4  com.adobe.dvacore.framework  0x0000000103a7287d dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 141
      5  com.adobe.dvacore.framework  0x0000000103a707e0 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 160
      6  com.adobe.dvacore.framework  0x0000000103a278dc boost::function0<void>::operator()() const + 28
      7  com.adobe.dvacore.framework  0x0000000103a6d734 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 164
      8  com.adobe.boost_threads.framework 0x000000010923e56a thread_proxy + 186
      9  libsystem_pthread.dylib      0x00007fff8fbc3268 _pthread_body + 131
      10  libsystem_pthread.dylib      0x00007fff8fbc31e5 _pthread_start + 176
      11  libsystem_pthread.dylib      0x00007fff8fbc141d thread_start + 13
      Thread 3:
      0  libsystem_kernel.dylib        0x00007fff8625321a kevent + 10
      1  com.adobe.dvatransport.framework 0x0000000108ec3597 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 375
      2  com.adobe.dvatransport.framework 0x0000000108ec3108 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 552
      3  com.adobe.dvatransport.framework 0x0000000108eb2d77 SkyConnectionEnv::MainLoop() + 167
      4  com.adobe.dvatransport.framework 0x0000000108eb2829 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      5  com.adobe.boost_threads.framework 0x000000010923e56a thread_proxy + 186
      6  libsystem_pthread.dylib      0x00007fff8fbc3268 _pthread_body + 131
      7  libsystem_pthread.dylib      0x00007fff8fbc31e5 _pthread_start + 176
      8  libsystem_pthread.dylib      0x00007fff8fbc141d thread_start + 13
