When I use <fb.exportReleaseBuild> task to build by command line, one error occurred.
(FlashBuild4.7 premium)
fb.exportReleaseBuild] com.adobe.air.InvalidInputException: An implementation f
or native extension 'InputMethodContext' required by the application was not fou
nd for the target platform.
Now my project used native extensions. (eg. libs/InputMethodExtension.ane)
So how am I write to build.xml for using native extensions.
Thanks!
Hi, I have the same issue.
Some details: The projects uses Native Extensions. Compilation and exporting from Flash builder are OK
This is my build.xml
<?xml version="1.0"?>
<project default="main">
<target name="main">
<fb.exportReleaseBuild project="myproject" />
</target>
</project>
and I run it by using the following script
set WORKSPACE=path_to_my_workspace
REM works with either FlashBuilderC.exe or eclipsec.exe
"C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\FlashBuilderC.exe" ^
--launcher.suppressErrors ^
-noSplash ^
-configuration C:\flashbuilderconf ^
-application org.eclipse.ant.core.antRunner ^
-data "%WORKSPACE%" ^
-file "%cd%\build.xml"
and I get the same error
Am I missing anything?
