• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to find list of conditional tags in a book using script?
Guest
Sep 23, 2015 Sep 23, 2015
[Thread moved to scripting forum by moderator]
TOPICS
Scripting
Views
351
Translate
Translate
Report
Report
Community guidelines
community guidelines
Mentor ,
LATEST
Hi, here is a quick ExtendScript that should do this. Files must be open to be processed. It is loosely tested, uncommented, and has no guarantees. Hope this helps.
Russ
if (typeof Array.prototype.indexOf != "function")
    Array.prototype.indexOf = function (val, startIndex)
        if(startIndex == null) startIndex = 0;
        for(var i = startIndex; i < this.length; i++)
            if(val === this) return i;
        return -1;
ListConditionTagsInBook(app.ActiveBook);
function ListConditionTagsInBook(book)
    if(book == null || !book.ObjectValid()) book = app.ActiveBook;
    if(!book.ObjectValid()) book = app.FirstOpenBook;
        alert("No active book. Cannot continue.");
        return;
    var conditionNames = new Array(0);
    var filesProcessed = 0;
    var filesSkipped = 0;
    var comp = book.FirstComponentInBook;
    while(comp.ObjectValid())
        if(comp.ComponentType == Constants.FV_BK_FILE)
            doc = FindOpenDoc(comp.Name);
            if(doc != null)
                var conditionObj = doc.FirstCondFmtInDoc;
                while(conditionObj.ObjectValid())
                    if(conditionNames.indexOf(conditionObj.Name) < 0)
                        conditionNames.push(conditionObj.Name);
                    conditionObj = conditionObj.NextCondFmtInDoc;
                } //end condition while
                filesProcessed++;
            } // end doc if
            else
                filesSkipped++;
        } // end component type if
        comp = comp.NextBookComponentInDFSOrder;
    } //end component while
    var msg = "Operation completed. Files processed: "
        + filesProcessed
        + ". Files skipped because they were closed: "
        + filesSkipped
        + ".\n\nConditions found ("
        + conditionNames.length
        + " total):\n\n";
    for(var i = 0; i < conditionNames.length; i++)
        msg += conditionNames + "\n";
    alert(msg);
//Send a fully qualified path. Returns null if the doc
//is not open in the session.
function FindOpenDoc(path)
    var doc= null;
    var filePath, comparePath;
    doc = app.FirstOpenDoc;
    while(doc.ObjectValid())
        if(doc.Name.toLowerCase() == path.toLowerCase())
            break;
        else doc = doc.NextOpenDocInSession;
    if(!doc.ObjectValid()) doc = null;
    return doc;
Votes
Translate
Translate
Report
Report
