2 Replies Latest reply on Sep 24, 2015 6:24 AM by WolfShade
    SOAP compilation fails with JRE 1.8
    theFnKid
      Bug#4062560 - SOAP compilation fails with JRE 1.8
      Description
      Problem Description:
      Invoking a web service throws an error based around a wrong version of java.
      Steps to Reproduce:
      <cftry>
      <cfinvoke method="getQuote" webservice="http://www.webservicex.net/stockquote.asmx?WSDL" returnvariable="SOAPResponse" >
      <cfinvokeargument name="symbol" value="ADBE" >
      </cfinvoke>
      <cfoutput>
      #SOAPResponse#
      </cfoutput>
      <cfcatch type="Any" >
      <cfdump var="#cfcatch#" >
      </cfcatch>
      </cftry>
      Actual Result:
      The errors can vary, some that I have encountered are:
      Using A public web service:
      C:\ColdFusion10\cfusion\stubs\WS-2056965968_2\src\net\webservicex\www\ExtensionMapper.java :15: cannot access java.lang.SuppressWarnings bad class file: java\lang\SuppressWarnings.class(java\lang:SuppressWarnings.class) class file has wrong version 52.0, should be 50.0 Please remove or make sure it appears in the correct subdirectory of the classpath. @SuppressWarnings({"unchecked","unused"}) ^
      COLUMN 0
      ID ??
      LINE -1
      RAW_TRACE bad class file: java\lang\SuppressWarnings.class(java\lang:SuppressWarnings.class)
      TEMPLATE java\lang
      TYPE CFML
      Using custom web service:
      coldfusion.jsp.CompilationFailedException: Errors reported by Java compiler: C:\ColdFusion10\cfusion\stubs\WS-682373501_2\src\coldfusion\xml\rpc\xsd\ArrayDelegate.jav a:18: cannot access java.lang.Object bad class file: java\lang\Object.class(java\lang:Object.class) class file has wrong version 52.0, should be 50.0 Please remove or make sure it appears in the correct subdirectory of the classpath. public class ArrayDelegate ^ .
      COLUMN 0
      ID ??
      LINE -1
      RAW_TRACE bad class file: java\lang\Object.class(java\lang:Object.class)
      TEMPLATE java\lang
      TYPE CFML
      Using custom web service enforcing WSVersion=1:
      coldfusion.jsp.CompilationFailedException: Errors reported by Java compiler: C:\ColdFusion10\cfusion\stubs\WS-682373501_1\coldfusion\xml\rpc\CFCInvocationException.ja va:10: cannot access java.rmi.RemoteException bad class file: java\rmi\RemoteException.class(java\rmi:RemoteException.class) class file has wrong version 52.0, should be 50.0 Please remove or make sure it appears in the correct subdirectory of the classpath. public class CFCInvocationException extends org.apache.axis.AxisFault implements java.io.Serializable { ^ .
      COLUMN 0
      ID ??
      LINE -1
      RAW_TRACE bad class file: java\rmi\RemoteException.class(java\rmi:RemoteException.class)
      TEMPLATE java\rmi
      TYPE CFML
      Expected Result:
      XML
      Any Workarounds:
      For local services, l can use the CFinvoke take with the component argument to invoke the same web service that fails when compiling as a SOAP.
      Test Configuration
      My Hardware and Environment details:
      Server Product ColdFusion
      Version 10,0,17,295085
      Edition Developer
      Operating System Windows 7
      OS Version 6.1
      Update Level /C:/ColdFusion10/cfusion/lib/updates/chf10000017.jar
      Adobe Driver Version 4.1 (Build 0001)
      AND
      Version ColdFusion 10,292620
      Edition Standard
      Operating System Windows Server 2008 R2
      OS Version 6.1
      Update Level /E:/ColdFusion10/cfusion/lib/updates/chf10000015.jar
      I have also removed all stubs, and cleared all caches.
      I have copied the tools.jar file from the Java 8 JDK into the {cfinstall}/lib directory.
