3 Replies Latest reply on Nov 30, 2006 5:07 PM by _lw
    3D Text
    askmrkelly Level 1
      I am trying to animate the blend property for 3D text, but cannot seem to get it to work. Is this possible?
        • 1. Re: 3D Text
          _lw Level 1
          the 3D text is a model, you have to set the blend of it's shader to manipulate the blend.
          member("3dtext").model("text").shader.blend= 50
          • 2. Re: 3D Text
            askmrkelly Level 1
            Cool. The code works, but how would I apply the actual tween?
            I want the 3D text's blend to tween much like the blend of any other sprite.
            • 3. Re: 3D Text
              _lw Level 1
              if you want to use the timeline, you can just link the blend of the 3D shader to the blend of a other sprite that is put next to the stage:
              member("3dtext").model("text").shader.blend=sprite(5).blend
              and then do the tweening wiht sprite(5) for example
