3 Replies Latest reply on May 22, 2016 9:01 PM by Mohit Goyal
    Lightroom CC is stuck in develop mode
    colrehogan
      When I click on LR CC to start it, first the library mode starts to come up and then it automatically switches to develop mode where it hangs up and will not do anything else.  What is going on?
        • 1. Re: Lightroom CC is stuck in develop mode
          Mohit Goyal Adobe Employee (Admin)
          Hi colrehogan,
          You need to turn off the GPU Preferences in Lightroom.
          First you need to reset the Lightroom Preferences.
          Steps:
          Quit Lightroom.
          Navigate to the preferences file:
          Mac OS: /Users/[user name]/Library/Preferences/com.adobe.Lightroom6.plist
          Windows 7, 8: C:\Users\[user name]\AppData\Roaming\Adobe\Lightroom\Preferences\Lightroom 6 Preferences.agprefs
          Rename the preferences file Lightroom 6 Preferences.agprefs.old
          Now, When you launch the Lightroom it will open on the Library Module.
          Go to Edit Menu on the top Menu(Windows)/ Click on the Lightroom on the top (Mac)
          Click on the Preferences
          Go to the Performance tab
          Uncheck the GPU settings from there.
          Restart the Lightroom
          Let us know if it helps,
          Regards,
          ~Mohit
          • 2. Re: Lightroom CC is stuck in develop mode
            Femke13
            Hello,
            I'm having the same problem. But I seem to be unable to uncheck the box, as lightroom gets stuck there. Is there a way around this?
            • 3. Re: Lightroom CC is stuck in develop mode
              Yes, follow the below steps.
              You need to turn off the Graphics Processor from the Lightroom Preferences.
              Open Control Panel >> Go to Device Manager >> Under the Display Adapter look for the Graphics Adapter >> Right Click and disable.
              Now,
              Open Lightroom
              Go to Lightroom Preferences from the Edit menu
              Click on Performance tab
              Uncheck the Graphics Processor
              Restart Lightroom
              Open and check if it works fine, then go back to the Device Manager and enable the Graphics Processor.
              Let us know if that helps.
              Regards,
              Mohit
