1. Re: CEPHtmlEngine slows Computer (Mac) and solution.
abascalufe Nov 2, 2015 7:37 AM (in response to NE-Design)Hi NE
I've just remove the damn ones by doing the following:
Finder > Applications > Photoshop
Click in show package contents
Search for CEPHtmlEngine
and you'll see these files:
CEPHtmlEngine
CEPHtmlEngine Helper
CEPHtmlEngine Helper EH
CEPHtmlEngine Helper NP
If you dare move them to trash !
All works fine now
By the way i don't use the CC app (cloud icon in the top menu bar) or extensions
2. Re: CEPHtmlEngine slows Computer (Mac) and solution.
otterstyle Feb 15, 2016 6:00 PM (in response to abascalufe)Is there any other way to get rid CEPhtmlEngine problem?
Does this (removing it from the Photoshop package) work with other CC applications like InDesign?
3. Re: CEPHtmlEngine slows Computer (Mac) and solution.
Steve Werner Feb 15, 2016 7:35 PM (in response to otterstyle)I haven't seen this mentioned in this forum.
A Google search showed almost all the references were to problems in Photoshop but not InDesign.
4. Re: CEPHtmlEngine slows Computer (Mac) and solution.
otterstyle Feb 16, 2016 4:39 AM (in response to Steve Werner)Here is a screenshot oft the CEPhtmlEngine task after launching InDesign:
It does constantly use above 100% CPU usage when InDesign is focused (it get's below 100% when it is minimized).
This has only begun for me recently… maybe since a week ago. Everytime I startk InDesign I have to manually shut down the CEPhtmlEngine via Activity Monitor.
I'm using CC2015.2 (InDesign 11.2.0.99) on OSX 10.11.3 on a MacBook Pro (Retina, 15", Late 2013), 2,6 GHz Intel Core i7, 16 GB 1600 MHz DDR3.
EDIT:
The problem also occurs after opening other CC2015.2 applications:
Here a screenshot just after opening Illustrator CC 2015.2:
Here after opening Photoshop CC2015.2:
Interestingly the tasks also shows up (with just below 100% CPU usage) after opening AfterEffects CC 2015.2 but disappears after the new splash screen / opening dialogue is closed (doesn't help with the other applications like PS, AI or InDesign):
Could it be GUI related? It certainly never happened to me before the updated GUI.
5. Re: CEPHtmlEngine slows Computer (Mac) and solution.
Steve Werner Feb 16, 2016 5:05 AM (in response to otterstyle)It's running for me too. Just because there are various processes running (there are dozens!) doesn't mean that they cause problems. No problems here: Mac OS X 10.11.3. InDesign CC 2015.2. Runs like a dream on my MacBook Pro.
What makes you think that the process is the problem?
6. Re: CEPHtmlEngine slows Computer (Mac) and solution.
_JSM Feb 16, 2016 5:09 AM (in response to otterstyle)same problem, Illustrator, InDesign, ...
Delete and reinstall does not work.
Also I have the complete Creative Cloud deleted multiple files looking for " orphaned " and filled with new CC, this brought no success .
The Tools : AdobeCreativeCloudCleanerTool.dmg and Creative Cloud Uninstaller.dmg not help .
and playing with the Erase and Install , now played 5 times already .
So, and now? Someone a proposed solution ?
and btw Adobe your tests actually your software before you the divorce them in the wild?The Forums are full with exactly this unresolved problem!
7. Re: CEPHtmlEngine slows Computer (Mac) and solution.
otterstyle Feb 16, 2016 5:28 AM (in response to Steve Werner)@Steve Werner
As you can see in my screenshots one of those processes always need extreme cpu usage (above 100%). You can hear the fans of the laptop going wild until I kill the process with the Activity Monitor. After killing it the fans go silent. Besides the fan noises it lowers the performance of my whole system and drains the battery. There is something going on there.
Also these processes doesn't seem to be necessary at all as I can kill them right after launching the applications and they won't restart themselves.
8. Re: CEPHtmlEngine slows Computer (Mac) and solution.
otterstyle Feb 16, 2016 5:35 AM (in response to _JSM)@JensSeidel
Do you know when the problem occurred to you the first time? I'm pretty sure I see this behavior since the last few days.
The only way at the moment seems to kill the CEPHtmlEngine right after launching the application and avoid restarting it. Annoying but certainly less of a hassle than reinstalling the applications multiple times without any effect.
9. Re: CEPHtmlEngine slows Computer (Mac) and solution.
_JSM Feb 16, 2016 5:39 AM (in response to otterstyle)otterstyle The process starts again automatically new, no matter how many I kill him ...
i think a few day, dort know the frist time
(scheint ein Problem insbesondere der deutschen Nutzer zu sein?)
10. Re: CEPHtmlEngine slows Computer (Mac) and solution.
otterstyle Feb 16, 2016 5:41 AM (in response to _JSM)You need to kill the task "CEPHtmlEngine" not the "Helper". When I shut down the CEPHtmlEngine the Helper shuts down with it. When i try to kill the "CEPHtmlEngine Helper" it always starts again within a second.
Also It could be a problem with the german version of CC…
11. Re: CEPHtmlEngine slows Computer (Mac) and solution.
_JSM Feb 16, 2016 5:47 AM (in response to otterstyle)otterstyle Thank you, thank you very much, so I get now at least my work done.
I opened a support ticket, I write in here if something turns up.
12. Re: CEPHtmlEngine slows Computer (Mac) and solution.
huid31332308 Feb 16, 2016 2:14 PM (in response to NE-Design)Did the CPU consumption issue happen immediately after you launch Adobe application, or after an extended period of use? Would you mind if I follow up with you to collect for information if possible?
13. Re: CEPHtmlEngine slows Computer (Mac) and solution.
huid31332308 Feb 16, 2016 2:20 PM (in response to NE-Design)Could you please show me the full command line parameter of the CEPHtmlEngine Helper taking 100+ CPU?
To do so, note down the PID (process ID) of the CEPHtmlEngine taking 100+ CPU in activity monitor, then open a terminal and type:
ps -ef|grep CEPHtmlEngine\ Helper|grep PID <-- replace PID with the actual PID
Thanks.
14. Re: CEPHtmlEngine slows Computer (Mac) and solution.
otterstyle Feb 16, 2016 5:19 PM (in response to huid31332308)Thank you huid31332308 for asking!
The CPU load rises immediately after launching InDesign and stays between 80–100+ until I shut down the task or the application.
Here is the log (replaced my username with *USERNAME*):
501 57667 57663 0 2:07am ?? 3:55.57 /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/CEP/CEPHtmlEngine/CEPHtmlEngine.app/Contents/Frameworks/CEPHtmlEn gine Helper.app/Contents/MacOS/CEPHtmlEngine Helper --type=renderer --enable-deferred-image-decoding --lang=en-US --lang=de --log-file=/Users/*USERNAME*/Library/Logs/CSXS/CEPHtmlEngine6-IDSN-11.2-com.adobe.DesignLibraries.angular.log --log-severity=error --params_ppid=IDSN --params_ppversion=11.2 --params_extensionid=com.adobe.DesignLibraries.angular --params_loglevel=1 --params_serverid=e24048cd-52f7-4ee9-be2a-77f7748dca4c --params_clientid=4046a574-d3df-4949-b020-d8e27dd2d408 --params_commandline=WyItLWhpZ2gtZHBpLXN1cHBvcnQ9MSIsIi0tZW5hYmxlLW5vZGVqcyJd --enable-pinch-virtual-viewport --enable-delegated-renderer --num-raster-threads=1 --disable-accelerated-video-decode --channel=57663.1.1622148403
15. Re: CEPHtmlEngine slows Computer (Mac) and solution.
_JSM Feb 17, 2016 6:11 AM (in response to NE-Design)Thanks huid31332308
ps -ef|grep CEPHtmlEngine\ Helper|grep 1208
501 1208 1204 0 2:34pm ?? 3:18.50 /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/CEP/CEPHtmlEngine/CEPHtmlEngine.app/Contents/Frameworks/CEPHtmlEn gine Helper.app/Contents/MacOS/CEPHtmlEngine Helper --type=renderer --enable-deferred-image-decoding --lang=en-US --lang=de --log-file=/Users/jens/Library/Logs/CSXS/CEPHtmlEngine6-IDSN-11.2-com.adobe.DesignLibrari es.angular.log --log-severity=error --params_ppid=IDSN --params_ppversion=11.2 --params_extensionid=com.adobe.DesignLibraries.angular --params_loglevel=1 --params_serverid=769deb37-3734-4a39-914d-bdd0ba0a5f0f --params_clientid=50d322ee-ada2-4360-b2ac-0ea1118c9c77 --params_commandline=WyItLWhpZ2gtZHBpLXN1cHBvcnQ9MSIsIi0tZW5hYmxlLW5vZGVqcyJd --enable-pinch-virtual-viewport --enable-delegated-renderer --num-raster-threads=1 --disable-accelerated-video-decode --channel=1204.1.654038714
I hope this is what u mean.
16. Re: CEPHtmlEngine slows Computer (Mac) and solution.
days_of_speed Feb 17, 2016 8:42 AM (in response to NE-Design)Also being driven insane with this CEPHtmlEngine issue. Opens and over runs the CPU on all CC apps including ID.
I believe this is the new libraries offering - which in itself is also a nightmare. Constantly attempting to save my artwork into a shared library. Unwieldy idea poorly executed.
Fans at full blast and CPU being cooked. Only solution is opening Activity Monitor and killing CEPHtmlEngine.
Please fix Adobe.
17. Re: CEPHtmlEngine slows Computer (Mac) and solution.
huid31332308 Mar 1, 2016 4:56 PM (in response to NE-Design)Hi _JSMotterstyleNE-Design @days_of_speed:
Thanks for providing very useful information!
Could you please try out the private build of Design Library (Shared Files - Acrobat.com), which has a potential fix for the CPU usage issue?
1. Move the old Design Library extension to somewhere else (move to your Desktop for example):
- Photoshop: /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/
- Illustrator: /Applications/Adobe Illustrator CC 2015/CEP/extensions/com.adobe.DesignLibraries.angular/
- InDesign: /Applications/Adobe InDesign CC 2015/Resources/CEP/extensions/com.adobe.DesignLibraries.angular/
2. Download DL.zip from Shared Files - Acrobat.com, then extract it to
The final directory structure should look like:
.../extensions/
|-DL/
|-CSXS/manifest.xml
|-index.html
Thanks very much!
18. Re: CEPHtmlEngine slows Computer (Mac) and solution.
huid31332308 Mar 1, 2016 4:51 PM (in response to days_of_speed)Hi days_of_speed,
.../extensions/
|-DL/
|-CSXS/manifest.xml
|-index.html
Thanks very much!
19. Re: CEPHtmlEngine slows Computer (Mac) and solution.
w.thorne Feb 17, 2016 8:07 PM (in response to NE-Design)Quitting the CC menubar app almost immediately slowed the fan (within two minutes fan and CPU usage were back to normal).
20. Re: CEPHtmlEngine slows Computer (Mac) and solution.
momol41417615 Feb 18, 2016 3:11 AM (in response to huid31332308)It works!
Thx @huid31332308
21. Re: CEPHtmlEngine slows Computer (Mac) and solution.
francob2k Feb 19, 2016 1:36 AM (in response to huid31332308)Hi, same problem and it works!
But CC Libraries disappeared from every app: Illustrator, inDesign, Photoshop... even in "window" menu, there is no more option to view them.
How to make them available in every app again without having MBP fans spinning crazily?
22. Re: CEPHtmlEngine slows Computer (Mac) and solution.
otterstyle Feb 19, 2016 3:20 AM (in response to huid31332308)Seems to work for me as well! Thank you! The CEPHtmlEngine Helper (there are still multiple; the one with the highest percentage) now needs about 6-7% with some higher peaks as of now. Hope what ever you did will end in the next update.
I still can access the CC Libraries in PS, AI and InDesign after the hotfix.
23. Re: CEPHtmlEngine slows Computer (Mac) and solution.
francob2k Feb 19, 2016 3:31 AM (in response to otterstyle)Me not! Cannot find CC Libraries on window menu, nor on the left panels after this trick.
24. Re: CEPHtmlEngine slows Computer (Mac) and solution.
huid31332308 Feb 19, 2016 9:23 AM (in response to NE-Design)Dear All,
Glad to know it worked for you!
Don't worry about multiple CEPHtmlEngine Helper processes as they are as expected.
25. Re: CEPHtmlEngine slows Computer (Mac) and solution.
huid31332308 Feb 19, 2016 9:25 AM (in response to francob2k)Hi francob2k,
Could you please show me all the files under /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/DL/?
26. Re: CEPHtmlEngine slows Computer (Mac) and solution.
francob2k Feb 19, 2016 9:37 AM (in response to huid31332308) -
27. Re: CEPHtmlEngine slows Computer (Mac) and solution.
huid31332308 Feb 19, 2016 9:39 AM (in response to francob2k)I see why...
Could you extract DL.zip to a subfolder under ..../CEP/extension/DL/?
The final dir structure should look like this:
.../extensions/
|-DL/
|-CSXS/manifest.xml
|-index.html
28. Re: CEPHtmlEngine slows Computer (Mac) and solution.
francob2k Feb 19, 2016 9:46 AM (in response to huid31332308)Oops I made a mistake, now it works like a sharm and fans spins normally.
Thank you!
29. Re: CEPHtmlEngine slows Computer (Mac) and solution.
MaVoSt Feb 19, 2016 7:52 PM (in response to huid31332308)It worked! !
Thanks!
30. Re: CEPHtmlEngine slows Computer (Mac) and solution.
Joowonsome Feb 20, 2016 6:53 AM (in response to huid31332308)that worked. thank you...:-D
31. Re: CEPHtmlEngine slows Computer (Mac) and solution.
days_of_speed Feb 21, 2016 5:38 AM (in response to huid31332308)Have changed only Photoshop and that seems to have fixed this across both Photoshop and ID and AI (e.g. I didn't amend anything in their Design Library folders.
32. Re: CEPHtmlEngine slows Computer (Mac) and solution.
days_of_speed Feb 21, 2016 5:40 AM (in response to days_of_speed)Spoke too soon. Fans have kicked in with Photoshop closed.
Will make changes in all folders!
33. Re: CEPHtmlEngine slows Computer (Mac) and solution.
days_of_speed Feb 21, 2016 6:01 AM (in response to days_of_speed)Fixed and all CC Libraries working.
34. Re: CEPHtmlEngine slows Computer (Mac) and solution.
Noortje_Noralie Feb 22, 2016 3:01 AM (in response to NE-Design)huid31332308 tnx for your help. But I still have the problem when opening after effects. Is there a way to solve it as well 'cuz after effects does not have the folders you describe.
35. Re: CEPHtmlEngine slows Computer (Mac) and solution.
AdamJury Feb 22, 2016 1:58 PM (in response to huid31332308)For what it's worth, I'd been noticing high CPU usage from CEPHtmlEngine Helper when using InDesign CC 2015 (latest version, latest version of OS X as well), up to and including it becoming non-responsive (along with InDesign). Only a few minutes into testing this private build, but so far, so good!
36. Re: CEPHtmlEngine slows Computer (Mac) and solution.
mattk79 Feb 22, 2016 5:33 PM (in response to days_of_speed)Exactly!! Finally updated to OSX 10.10 so I could update to Adobe CC 2015. Well guess what?!? Fans blasting all day, CPU Cooking at almost 200 deg F and memory pretty much gone. I didn't know if this was a OSX issue or what. I couldn't figure out until it happened as soon as I opened AI back up. I had Photoshop and Illustrator running earlier today (without any actual files open) and could not figure out why the heck my CPU was being maxed. I killed ALL (three instances) of CEPHTMLENGINE (I only had AI running) and sure enough my fans started to slow down and my CPU has settled down. My memory is still being used up. I only have 2GB available out of 16GB. I only have iTunes, Google Chrome, Mail and Illustrator open. Where the heck did all my memory go?!?
I've only updated Photoshop and Illustrator. I'm afraid to update Premiere, AE, Audition, Bridge, etc because if two programs wipe my computer out then updating the others will probably kill it.
Why is this happening? Adobe, what have you done?
37. Re: CEPHtmlEngine slows Computer (Mac) and solution.
mattk79 Feb 22, 2016 5:40 PM (in response to days_of_speed)How did you get your Libraries working? It has completely removed it from PS.
38. Re: CEPHtmlEngine slows Computer (Mac) and solution.
days_of_speed Mar 1, 2016 4:58 PM (in response to mattk79)Have you checked you moved the correct files out and the directory structure is as below? (Mine is and works fine - fans off and Libraries working as intended).
2. Download DL.zip from Shared Files at Acrobat.com, then extract it to
39. Re: CEPHtmlEngine slows Computer (Mac) and solution.
TricsMedia Feb 23, 2016 7:38 AM (in response to NE-Design)This is a known issue at Adobe and their engineers are working on a solution. I am assuming this solution will come in form of app updates. The accepted answer does work, but not for dreamweaver and possibly also other adobe apps other than Indesign, Illustrator and Photoshop.
