7 Replies Latest reply on Sep 25, 2015 5:44 AM by Peter Spier
    Upgrade Error.
    rexs30763350
      I upgraded to Windows 10 a couple of months ago.  This week there was an automatic update on my InDesign file for 2015.
      Now InDesign will not open - crashes on opening.  Windows comes up and says it has stopped working.  No more information than that,which is frustrating.
      What can I do to fix this and get back to work?
        • 1. Re: Upgrade Error.
          Brucgovn Adobe Community Professional
          You need to check with Event Viewer Log once .
          However . as you had upgraded to Windows 10 , it is better to run System File Checker command once to check if there is any issue with System Files .
          https://support.microsoft.com/en-in/kb/929833
          Once the Command is completed , launch InDesign and check .,
          Still same??
          We will need to check with Event Viewer log for Faulting Module.
          • 2. Re: Upgrade Error.
            LearnedMan Level 3
            A similar thing happen with me and Adobe Acrobat Pro 8.0. I found a fix for mine, I don't think it will work for you. I uninstalled Acrobat Reader. You may have to roll back the update. I don't know how at the moment, but I'm sure there are instructions on the net. Good luck
            • 3. Re: Upgrade Error.
              rexs30763350 Level 1
              I ran the FIle checker and found issues which were fixed.
              In Design still failed to load.  I restarted, still failed.
              Creative Cloud wanted to update, so I did, and tried again, still failed.
              I don't know how to find the Event Log
              • 4. Re: Upgrade Error.
                OK, I found the Event Viewer.
                Faulting application name: InDesign.exe, version: 11.1.0.122, time stamp: 0x55bf8487
                Faulting module name: ntdll.dll, version: 10.0.10240.16430, time stamp: 0x55c59f92
                Exception code: 0xc0000374
                Fault offset: 0x00000000000ea28c
                Faulting process ID: 0x2dd4
                Faulting application start time: 0x01d0f78b52845f9c
                Faulting application path: C:\Program Files\Adobe\Adobe InDesign CC 2015\InDesign.exe
                Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
                Report ID: 3dc57ad5-c92c-4f0e-bd93-83e99849e7cd
                Faulting package full name:
                Faulting package-relative application ID:
                • 5. Re: Upgrade Error.
                  Sheena Kaul Adobe Employee
                  Moving to InDesign
                  • 6. Re: Upgrade Error.
                    System
                    -Provider
                    [ Name] Application Error
                    -EventID1000
                    [ Qualifiers] 0
                    Level2
                    Task100
                    Keywords0x80000000000000
                    -TimeCreated
                    [ SystemTime] 2015-09-25T12:11:50.000000000Z
                    EventRecordID14386
                    ChannelApplication
                    ComputerRexLaptop
                    Security
                    -EventData
                    InDesign.exe
                    11.1.0.122
                    55bf8487
                    ntdll.dll
                    10.0.10240.16430
                    55c59f92
                    c0000374
                    00000000000ea28c
                    2dd4
                    01d0f78b52845f9c
                    • 7. Re: Upgrade Error.
                      Uninstall and reinstall...
