3 Replies Latest reply on Apr 26, 2006 3:05 PM by Newsgroup_User
    Several DW 8 errors
    Reaganjudd
      Hello,
      I am getting several errors in DW 8, which started after several months of error-free usage.
      Upon loading of DW: "The following JavaScript errors occurred: at line 56 of file "C:/ProgramFiles/Macromedia/Dreamweaver 8/Configuration/Shared/Common/Scripts/dwscriptsExtData.js":Reference error: dwscripts is not defined."
      If I hit OK, then DW loads, and i get this error: "The following translator were not loaded due to errors: ColdFusion.htm has configuration information that is invalid."
      Upon an attempt to copy and paste some code: "Whil executing DWMenu_edit_copy command in menus.xml, the following JavaScript error(s) occurred: TypeError: MM.event has no properties"
      Can anyone help??
        • 1. Re: Several DW 8 errors
          Level 7
          Try this:
          Close DW8 and Navigate as follows:
          -Documents and settings
          - Administrator or whatever your user account name is
          - application data
          - Macromedia
          - DW8
          - rename the "configuration" folder
          Start DW8 and the problem is solved. DW recreates the configuration folder
          which apparently fixes the problem. You can then delete the renamed folder.
          Jo
          "Reaganjudd" <webforumsuser@macromedia.com> wrote in message
          news:e2onnr$m3d$1@forums.macromedia.com...
          > Hello,
          > error-free usage.
          > 56 of
          > error:
          > translator
          > information
          > that is invalid."
          > DWMenu_edit_copy
          > TypeError:
          > Can anyone help??
          • 2. Re: Several DW 8 errors
            Reaganjudd Level 1
            HOORAY! It worked! Yippee! Thanks for the fix.
            • 3. Re: Several DW 8 errors
              Level 7
              Just be aware that this method will dump your installed extensions - meaning
              that you will have to reinstall them.
              Murray --- ICQ 71997575
              Adobe Community Expert
              (If you *MUST* email me, don't LAUGH when you do so!)
              http://www.dreamweavermx-templates.com - Template Triage!
              http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
              http://www.dwfaq.com - DW FAQs, Tutorials & Resources
              http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
              "Josie1one" <joleros[nospam]@yahoo.com> wrote in message
              news:e2oofj$mvd$1@forums.macromedia.com...
              > Try this:
              > - application data
              > - Macromedia
              > - DW8
              > folder.
              > Jo
              >> Hello,
              >> of
              >> error-free usage.
              >> 56 of
              >> error:
              >> translator
              >> information
              >> that is invalid."
              >> DWMenu_edit_copy
              >> TypeError:
              >> Can anyone help??
