0 Replies Latest reply on Sep 25, 2015 1:46 PM by palanski
    Populate fields from array, based on dropdown menu selection
    palanski
      Hi there,
      I have a bit of programming background, but am lost in achieving a seemingly simple task in Adobe Acrobat. I turn to your expertise to achieve the following:
      • Declare a global array in a PDF document that has 7 columns
        • The first column will contain values, let's say 1 through 9
        • The other columns will have information that corresponds to each of the first column's rows
      • The PDF document will have one drop-down list, which should be populated by the values from the first column of the array
      • Based on the user's selection in this drop-down array, I want the other 6 fields to populate with the corresponding information from the previously-initialized array
      Thanks for any insight and assistance!
