• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
looping over a structure
Participant ,
Dec 04, 2006 Dec 04, 2006
How do I loop over this structure to populate it with a Query Recordset?
<cfset myStruct = objImage.getSize("images/products/largeImages/#Recordset1.elink#")>
I really appreciate your help.
TOPICS
Advanced techniques
Views
307
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
wouldn't you want to loop over the query data?
i'm guessing you have a struct (myStruct) that holds the image height/width (myStruct.height and myStruct.width)? what is it that's coming from the query that you want the struct to hold (that it's not currently holding)?
Votes
Translate
Translate
Report
Report
Participant ,
Dec 05, 2006 Dec 05, 2006
I would like to populate the structure with the image file names that are coming from the query. The structure is built from a java object. Here is the function to create it.
<cfcomponent>
<cffunction name="getSize" returntype="struct" access="public" output="No">
<cfargument name="Image" required="Yes" type="string">
<cfset myImage = createObject("java", "javax.swing.ImageIcon")>
<cfset myImage.init(expandpath(arguments.Image))>
<cfset myStruct = StructNew()>
<cfset myStruct.width = myImage.getIconWidth()>
<cfset myStruct.height = myImage.getIconHeight()>
<cfreturn myStruct>
</cffunction>
</cfcomponent>
<cfobject component="imageSize" name="objImage">
<cfset myStruct = objImage.getSize("/images/someimage.jpg")>
<cfoutput>
width: #myStruct.width#
height: #myStruct.height#
</cfoutput>
Right now the structure only gives me the first row of the query. I have tried using the cfquery loop to populate the structure with now results. I suspect I am using the wrong syntac.
Votes
Translate
Translate
Report
Report
Guest
well, a structure by design can only have one key with a given name. you can't have myStruct.height multiple times for multiple images returned from the query.
Sounds like you want an array of structs.
Votes
Translate
Translate
Report
Report
Participant ,
Dec 06, 2006 Dec 06, 2006
LATEST
I tried running your code but I get this error.
<cfoutput query="Recordset1">
<cfset ArrayAppend(myArray, objImage.getSize("images/products/largeImages/#Recordset1.elink#")>
</cfoutput>
When I dump this it works.
<cfoutput>#myStruct#</cfoutput>
The error I am getting says.
The CFML compiler was processing:
an expression beginning with "ArrayAppend", on line 23, column 13.This message is usually caused by a problem in the expressions structure.
a cfset tag beginning on line 23, column 7.
The error occurred in C:\CFusionMX7\wwwroot\flash\setSize.cfm: line 23
21 :
22 : <cfoutput query="Recordset1">
23 : <cfset ArrayAppend(myArray, objImage.getSize("images/products/largeImages/#Recordset1.elink#")>
24 : </cfoutput>
25 :
Votes
Translate
Translate
Report
Report
Resources
Documentation
