2 Replies Latest reply on Sep 27, 2015 10:38 AM by kenm37599373
    After Effects CS6 unexpectedly quitting after I close the welcome pop up screen.
    kenm37599373
      After Effects CS6 unexpectedly quitting after I close the welcome pop up screen. I have a macbook pro running 10.6.8 and I am running the trial version of CS6 11.0.4  Please help!!!
        • 2. Re: After Effects CS6 unexpectedly quitting after I close the welcome pop up screen.
          kenm37599373 Level 1
          Here is is, thanks man!
          Process:         After Effects [244]
          Path:            /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
          Identifier:      com.adobe.AfterEffects
          Version:         11.0.4 (11.0.4)
          Code Type:       X86-64 (Native)
          Parent Process:  launchd [160]
          Date/Time:       2015-09-27 13:36:38.480 -0400
          OS Version:      Mac OS X 10.6.8 (10K549)
          Report Version:  6
          Interval Since Last Report:          3247872 sec
          Crashes Since Last Report:           278
          Per-App Interval Since Last Report:  474 sec
          Per-App Crashes Since Last Report:   4
          Anonymous UUID:                      FCCDAE0A-9538-4296-8665-A1ACA0F487CB
          Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
          Exception Codes: KERN_INVALID_ADDRESS at 0x00000000ffffffff
          Crashed Thread:  0  Dispatch queue: com.apple.main-thread
          Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
          0   libstdc++.6.dylib             0x00007fff86ccb685 0x7fff86cca000 + 5765
          1   ...adobe.dynamiclink.framework 0x00000001058e268d dynamiclink::platformutils::GetPathToServer(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::string, std::string, unsigned int) + 653
          2   ...e.AfterEffectsLib.framework 0x000000010080e239 GetProjectOData() + 12489
          3   ...e.AfterEffectsLib.framework 0x00000001007dfd00 CEffects::SuspendUIUpdates(bool) + 57224
          4   ...e.AfterEffectsLib.framework 0x00000001004d51fa CDesktopPlus::IDesktopPlus(CBureaucrat*) + 1718
          5   ...e.AfterEffectsLib.framework 0x00000001007e7678 COutlineDir::GetOutlinePano() + 27534
          6   ...e.AfterEffectsLib.framework 0x000000010080969e CPOutlinePano::IsOneItemSelected(BEE_Item**) + 2640
          7   ...e.AfterEffectsLib.framework 0x00000001004cc867 CBartender::FindDVAMenu(short) + 8883
          8   ...e.AfterEffectsLib.framework 0x000000010040a7d6 ae_menu_utils::DoPopupMenu(boost::intrusive_ptr<dvaui::utility::OS_Menu>&, M_Point, unsigned int) + 2582
          9   ...e.AfterEffectsLib.framework 0x000000010040a826 ae_menu_utils::DoPopupMenu(boost::intrusive_ptr<dvaui::utility::OS_Menu>&, M_Point, unsigned int) + 2662
          10  ...e.AfterEffectsLib.framework 0x00000001003adbbe DialogEveBase::DialogEveBase(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*) + 333214
          11  ...e.AfterEffectsLib.framework 0x0000000100800b20 CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 368
          12  ...e.AfterEffectsLib.framework 0x0000000100801836 CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 3718
          13  ...e.AfterEffectsLib.framework 0x0000000100800142 CTopicArray::~CTopicArray() + 59154
          14  ...e.AfterEffectsLib.framework 0x00000001004988cb GetMetaPanelSuite + 9403
          15  ...e.AfterEffectsLib.framework 0x0000000100498227 GetMetaPanelSuite + 7703
          16  U.dylib                       0x0000000102b74c11 U_Die + 241
          17  U.dylib                       0x0000000102b94f3d U_LoadFrameworkBundle + 557
          18  com.adobe.dvacore.framework   0x0000000102fe7535 (anonymous namespace)::SignalHandler(int, __siginfo*, void*) + 261
          19  libSystem.B.dylib             0x00007fff82f411ba _sigtramp + 26
          20  libstdc++.6.dylib             0x00007fff86ccb685 0x7fff86cca000 + 5765
          21  ...adobe.dynamiclink.framework 0x00000001058e268d dynamiclink::platformutils::GetPathToServer(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::string, std::string, unsigned int) + 653
          22  ...e.AfterEffectsLib.framework 0x000000010080e239 GetProjectOData() + 12489
          23  ...e.AfterEffectsLib.framework 0x00000001007dfd00 CEffects::SuspendUIUpdates(bool) + 57224
          24  ...e.AfterEffectsLib.framework 0x00000001004d51fa CDesktopPlus::IDesktopPlus(CBureaucrat*) + 1718
          25  ...e.AfterEffectsLib.framework 0x00000001007e7678 COutlineDir::GetOutlinePano() + 27534
          26  ...e.AfterEffectsLib.framework 0x000000010080969e CPOutlinePano::IsOneItemSelected(BEE_Item**) + 2640
          27  ...e.AfterEffectsLib.framework 0x00000001004cc867 CBartender::FindDVAMenu(short) + 8883
          28  ...e.AfterEffectsLib.framework 0x000000010040a7d6 ae_menu_utils::DoPopupMenu(boost::intrusive_ptr<dvaui::utility::OS_Menu>&, M_Point, unsigned int) + 2582
          29  ...e.AfterEffectsLib.framework 0x000000010040a826 ae_menu_utils::DoPopupMenu(boost::intrusive_ptr<dvaui::utility::OS_Menu>&, M_Point, unsigned int) + 2662
          30  ...e.AfterEffectsLib.framework 0x000000010035c2eb DialogEveBase::DoModalDialog(short, bool) + 441
          31  ...e.AfterEffectsLib.framework 0x00000001003cba8d DialogEveBase::DialogEveBase(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*) + 455789
          32  ...e.AfterEffectsLib.framework 0x0000000100308e4d TimeCodeControl::CurrentFormatToTime(char const*, T_TimeFormatInfo, int, bool, T_Time*, T_Time const*, bool) + 22845
          33  ...e.AfterEffectsLib.framework 0x000000010043366f CEggApp::Dawdle(int*) + 659
          34  ...e.AfterEffectsLib.framework 0x00000001004c99b6 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 128758
          35  ...e.AfterEffectsLib.framework 0x00000001004dd5b3 CSwitchboard::DoIdle(EventRecord*) + 51
          36  ...e.AfterEffectsLib.framework 0x00000001004de3f3 CSwitchboard::IdleTimerFunc(CSwitchboard*) + 211
          37  ...e.AfterEffectsLib.framework 0x00000001002e06fb 0x1002ad000 + 210683
          38  com.adobe.dvacore.framework   0x0000000102ef46be int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
          39  ...e.AfterEffectsLib.framework 0x0000000100468e9e EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 1918
          40  com.adobe.dvacore.framework   0x0000000102ef45b0 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 112
          41  ...e.AfterEffectsLib.framework 0x00000001002df229 0x1002ad000 + 205353
          42  com.apple.Foundation           0x00007fff89147bc5 __NSFireTimer + 114
          43  com.apple.CoreFoundation       0x00007fff80769bb8 __CFRunLoopRun + 6488
          44  com.apple.CoreFoundation       0x00007fff80767d8f CFRunLoopRunSpecific + 575
          45  com.apple.HIToolbox           0x00007fff84a9374e RunCurrentEventLoopInMode + 333
          46  com.apple.HIToolbox           0x00007fff84a93553 ReceiveNextEventCommon + 310
          47  com.apple.HIToolbox           0x00007fff84a9340c BlockUntilNextEventMatchingListInMode + 59
          48  com.apple.AppKit               0x00007fff815b1eb2 _DPSNextEvent + 708
          49  com.apple.AppKit               0x00007fff815b1801 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
          50  com.apple.AppKit               0x00007fff8157768f -[NSApplication run] + 395
          51  ...e.AfterEffectsLib.framework 0x00000001004c9885 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 128453
          52  ...e.AfterEffectsLib.framework 0x0000000100467f9b SetAPETerminateFunc(boost::function<void ()()> const&) + 891
          53  ...e.AfterEffectsLib.framework 0x000000010046875d EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 61
          54  com.adobe.AfterEffects         0x0000000100003aad main + 1677
          55  com.adobe.AfterEffects         0x000000010000340c start + 52
          Thread 1:  Dispatch queue: com.apple.libdispatch-manager
          0   libSystem.B.dylib             0x00007fff82ef9c0a kevent + 10
          1   libSystem.B.dylib             0x00007fff82efbadd _dispatch_mgr_invoke + 154
          2   libSystem.B.dylib             0x00007fff82efb7b4 _dispatch_queue_invoke + 185
          3   libSystem.B.dylib             0x00007fff82efb2de _dispatch_worker_thread2 + 252
          4   libSystem.B.dylib             0x00007fff82efac08 _pthread_wqthread + 353
          5   libSystem.B.dylib             0x00007fff82efaaa5 start_wqthread + 13
          Thread 2:
          0   libSystem.B.dylib             0x00007fff82f1ba6a __semwait_signal + 10
          1   libSystem.B.dylib             0x00007fff82f1f881 _pthread_cond_wait + 1286
          2   ...ple.CoreServices.CarbonCore 0x00007fff82828d87 TSWaitOnCondition + 118
          3   ...ple.CoreServices.CarbonCore 0x00007fff82797ff8 TSWaitOnConditionTimedRelative + 177
          4   ...ple.CoreServices.CarbonCore 0x00007fff82791efb MPWaitOnQueue + 215
          5   com.adobe.dvacore.framework   0x0000000102f61ce4 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()()> > >&, int) + 200
          6   com.adobe.dvacore.framework   0x0000000102f5efe3 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 115
          7   com.adobe.dvacore.framework   0x0000000102f5c6d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 163
          8   ...obe.boost_threads.framework 0x00000001091c7ace thread_proxy + 158
          9   libSystem.B.dylib             0x00007fff82f19fd6 _pthread_start + 331
          10  libSystem.B.dylib             0x00007fff82f19e89 thread_start + 13
          Thread 3:
          Thread 4:
          Thread 5:
          Thread 6:
          5   com.adobe.ACE                 0x000000010a1572c9 0x10a11e000 + 234185
          6   com.adobe.ACE                 0x000000010a1565da 0x10a11e000 + 230874
          7   ...ple.CoreServices.CarbonCore 0x00007fff8276a0d1 PrivateMPEntryPoint + 63
          8   libSystem.B.dylib             0x00007fff82f19fd6 _pthread_start + 331
          9   libSystem.B.dylib             0x00007fff82f19e89 thread_start + 13
          Thread 7:
          Thread 8:
          Thread 9:
          5   ...obe.ASLFoundation.framework 0x0000000105c31320 ASL::(anonymous namespace)::TaskProc(void*) + 160
          6   ...ple.CoreServices.CarbonCore 0x00007fff8276a0d1 PrivateMPEntryPoint + 63
          7   libSystem.B.dylib             0x00007fff82f19fd6 _pthread_start + 331
          8   libSystem.B.dylib             0x00007fff82f19e89 thread_start + 13
          Thread 10:
          Thread 11:
          Thread 12:
          Thread 13:
          1   ...dobe.dvatransport.framework 0x0000000108e52f12 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 240
          2   ...dobe.dvatransport.framework 0x0000000108e5d0da boost::asio::detail::task_io_service::do_one(boost::asio::detail::scoped_lock<boost::asio ::detail::posix_mutex>&, boost::asio::detail::task_io_service::idle_thread_info*) + 512
          3   ...dobe.dvatransport.framework 0x0000000108e5d467 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 291
          4   ...dobe.dvatransport.framework 0x0000000108e49fbd SkyConnectionEnv::MainLoop() + 129
          5   ...dobe.dvatransport.framework 0x0000000108e4a03b SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
          6   ...obe.boost_threads.framework 0x00000001091c7ace thread_proxy + 158
          Thread 14:
          2   ...dobe.dvatransport.framework 0x0000000108e5d04b boost::asio::detail::task_io_service::do_one(boost::asio::detail::scoped_lock<boost::asio ::detail::posix_mutex>&, boost::asio::detail::task_io_service::idle_thread_info*) + 369
          4   ...dobe.dvatransport.framework 0x0000000108e4ac2a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
          5   ...dobe.dvatransport.framework 0x0000000108e4dc33 boost_asio_detail_posix_thread_function + 19
          6   libSystem.B.dylib             0x00007fff82f19fd6 _pthread_start + 331
          7   libSystem.B.dylib             0x00007fff82f19e89 thread_start + 13
          Thread 15:
          0   libSystem.B.dylib             0x00007fff82ee0d7a mach_msg_trap + 10
          1   libSystem.B.dylib             0x00007fff82ee13ed mach_msg + 59
          2   com.apple.CoreFoundation       0x00007fff80768902 __CFRunLoopRun + 1698
          3   com.apple.CoreFoundation       0x00007fff80767d8f CFRunLoopRunSpecific + 575
          4   com.apple.audio.CoreAudio     0x00007fff86de2786 HALRunLoop::OwnThread(void*) + 152
          5   com.apple.audio.CoreAudio     0x00007fff86dcf755 CAPThread::Entry(CAPThread*) + 125
          Thread 16:
          2   ....audio_hijack_server.hermes 0x000000011009eb21 ah_serv_loop + 101
          3   libSystem.B.dylib             0x00007fff82f19fd6 _pthread_start + 331
          4   libSystem.B.dylib             0x00007fff82f19e89 thread_start + 13
          Thread 17:
          2   com.adobe.AfterEffects.MThread 0x000000012be96017 main + 27303
          3   com.adobe.AfterEffects.MThread 0x000000012be960ce main + 27486
          4   com.adobe.dvacore.framework   0x0000000102f5c6d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 163
          5   ...obe.boost_threads.framework 0x00000001091c7ace thread_proxy + 158
          Thread 18:
          Thread 19:
          Thread 20:
          Thread 21:
          2   com.adobe.AfterEffects.OpenEXR 0x000000012eedd484 IlmThread::Semaphore::wait() + 100
          3   com.adobe.AfterEffects.OpenEXR 0x000000012eedc546 IlmThread::(anonymous namespace)::WorkerThread::run() + 182
          4   libSystem.B.dylib             0x00007fff82f19fd6 _pthread_start + 331
          5   libSystem.B.dylib             0x00007fff82f19e89 thread_start + 13
          Thread 22:
          Thread 23:
          Thread 24:
          Thread 25:
          1   libSystem.B.dylib             0x00007fff82f1b8f9 nanosleep + 148
          2   ...dobe.AfterEffects.Scripting 0x000000012ff293db zcalloc + 188043
          3   ...dobe.AfterEffects.Scripting 0x000000012ff10059 zcalloc + 84745
          4   ...dobe.AfterEffects.Scripting 0x000000012ff29726 zcalloc + 188886
          5   libSystem.B.dylib             0x00007fff82f19fd6 _pthread_start + 331
          6   libSystem.B.dylib             0x00007fff82f19e89 thread_start + 13
          Thread 26:
          2   com.adobe.ape.engine           0x0000000130af0c0d APXGetHostAPI + 2516093
          3   com.adobe.ape.engine           0x000000013089eec1 APXGetHostAPI + 83761
          4   com.adobe.ape.engine           0x0000000130af0cd1 APXGetHostAPI + 2516289
          5   com.adobe.ape.engine           0x0000000130af0d4a APXGetHostAPI + 2516410
          6   com.adobe.ape.engine           0x0000000130af0e79 APXGetHostAPI + 2516713
          Thread 27:
          Thread 28:
          Thread 29:
          Thread 30:
          4   com.apple.CoreMediaIOServices 0x00007fff844555f7 MIO::DAL::RunLoop::OwnThread(void*) + 147
          5   com.apple.CoreMediaIOServices 0x00007fff844571c2 CAPThread::Entry(CAPThread*) + 140
          Thread 31:
          0   libSystem.B.dylib             0x00007fff82ee0dda semaphore_timedwait_signal_trap + 10
          1   libSystem.B.dylib             0x00007fff82f1f772 _pthread_cond_wait + 1015
          2   com.adobe.ape.engine           0x0000000130af0bd0 APXGetHostAPI + 2516032
          3   com.adobe.ape.engine           0x0000000130b08ddb APXGetHostAPI + 2614859
          Thread 32:
          3   com.adobe.ape.engine           0x0000000130c832c3 APXGetHostAPI + 4164403
          Thread 33:
          2   libtbb.dylib                   0x0000000100023010 tbb::internal::rml::private_worker::thread_routine(void*) + 416
          Thread 34:
          Thread 35:
          Thread 36:
          2   com.apple.audio.CoreAudio     0x00007fff86dcf68c CAGuard::WaitFor(unsigned long long) + 168
          3   com.apple.audio.CoreAudio     0x00007fff86dd1c1b CAGuard::WaitUntil(unsigned long long) + 185
          4   com.apple.audio.CoreAudio     0x00007fff86dcfd85 HP_IOThread::WorkLoop() + 1369
          5   com.apple.audio.CoreAudio     0x00007fff86dcf827 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
          6   com.apple.audio.CoreAudio     0x00007fff86dcf755 CAPThread::Entry(CAPThread*) + 125
          Thread 0 crashed with X86 Thread State (64-bit):
            rax: 0x00000000ffffffff  rbx: 0x00007fff5fbfcb00  rcx: 0x00000000000000a8  rdx: 0x00000000009d8500
            rdi: 0x00007fff5fbfc9bd  rsi: 0x000000010f600000  rbp: 0x00007fff5fbfcb00  rsp: 0x00007fff5fbfcab0
             r8: 0x0000000000000001   r9: 0x000000010f6b0550  r10: 0x0000000000000000  r11: 0x0000000000000004
            r12: 0x00000001058804d2  r13: 0x00007fff5fbfcad0  r14: 0x000000010f6b32f0  r15: 0x0000000000000000
            rip: 0x00007fff86ccb685  rfl: 0x0000000000010216  cr2: 0x00000000ffffffff
          Binary Images:
                 0x100000000 -        0x100003fff +com.adobe.AfterEffects 11.0.4 (11.0.4) <685FB83D-7CAC-A841-F2D8-7529E161BD11> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
                 0x100014000 -        0x100040ff7 +libtbb.dylib ??? (???) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtbb.dylib
                 0x100057000 -        0x100065ff3 +libtbbmalloc.dylib ??? (???) <CB038B96-2999-5EB1-E26A-7720A7A8F8CD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtbbmalloc.dylib
                 0x100079000 -        0x100085fff +com.adobe.boost_signals.framework 6.0.0 (6.0.0.339847) <6188E5E8-5615-3978-D00E-19B45B5A1F71> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                 0x10009d000 -        0x1000a0fff +com.adobe.boost_system.framework 6.0.0 (6.0.0.339847) <83D1894D-ADE2-A2B0-DCEC-C3B3581763FB> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                 0x1000a6000 -        0x1000adfff +com.adobe.boost_date_time.framework 6.0.0 (6.0.0.339847) <8F33489D-DBFE-FFC4-68B6-AA3DA2D3D6C3> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                 0x1000c8000 -        0x1001c4ff7 +hydra_filters ??? (???) <99B0081A-4F6B-1029-06BB-95C8BFD428EC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
                 0x100263000 -        0x10027dfff +image_runtime ??? (???) <A1DC006A-7787-A7E8-86FB-B19471FB290B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                 0x1002a9000 -        0x1002aaff7 +ALOG.dylib ??? (???) <BED08E21-1BFF-A3F4-9A06-3285B2D35832> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ALOG.dylib
                 0x1002ad000 -        0x100d1ffef +com.adobe.AfterEffectsLib.framework AfterFXLib 1.0 (1.0) <4A2A38CF-E4B3-2E51-4CDF-0EF63346DFAC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
                 0x100f7c000 -        0x100f7cfff +AEFX.dylib ??? (???) <22A1E09A-DBC0-0A0E-41A3-557B0895F5FD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AEFX.dylib
                 0x100f7f000 -        0x10145dff7 +BEE.dylib ??? (???) <13B10B83-409B-0A14-6C50-0D35EE5C32E5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BEE.dylib
                 0x10165b000 -        0x101669fef +BEZ.dylib ??? (???) <1718F422-640F-252E-8E34-A8C8F162D6D2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BEZ.dylib
                 0x10166e000 -        0x101678ff7 +BM.dylib ??? (???) <61A575E8-AA18-8751-6345-5E90105398CF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BM.dylib
                 0x101680000 -        0x1016dbfef +COR.dylib ??? (???) <AB554C9A-F965-6AEC-132E-EECA05EECD3E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/COR.dylib
                 0x1016fe000 -        0x10171ffff +FILE.dylib ??? (???) <192727E1-DE2E-7693-993B-A04528A78DAE> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FILE.dylib
                 0x10172f000 -        0x101759fff +FLO.dylib ??? (???) <11907BB6-2881-9712-2D0F-FB1E8858BCEF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FLO.dylib
                 0x10175e000 -        0x1017f2fff +FLT.dylib ??? (???) <07EBD338-523F-3B95-2C69-7C3FEC152DEF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FLT.dylib
                 0x101850000 -        0x101856ff7 +LIST.dylib ??? (???) <CA410815-911B-888F-A323-6F5982D778E5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/LIST.dylib
                 0x10185a000 -        0x101874ff7 +M.dylib ??? (???) <D2A1BA16-AFB4-1A8A-A073-3E912030D7FC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/M.dylib
                 0x10187c000 -        0x10189dfff +MC.dylib ??? (???) <64ABFA96-EB25-A512-C84A-57B6607D1D5D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MC.dylib
                 0x1018af000 -        0x10190efff +MSK.dylib ??? (???) <97F17369-69B1-C908-466D-DB2AB165E091> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MSK.dylib
                 0x101921000 -        0x10196bff7 +OM.dylib ??? (???) <22156FD7-9A62-C30C-109A-8AF211433FCC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/OM.dylib
                 0x101982000 -        0x1019a6fef +P.dylib ??? (???) <4B41CB3E-2E9E-172F-4DAD-EF9DAD6489DA> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/P.dylib
                 0x1019af000 -        0x101c6eff7 +PF.dylib ??? (???) <3E0FE9B0-90F6-E0C9-2484-8552CDFA219E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PF.dylib
                 0x101c97000 -        0x101f0dfff +PIN.dylib ??? (???) <9FE7EDCB-EDD6-029B-CC1A-DC8273C3A43B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PIN.dylib
                 0x101f79000 -        0x101f93fff +PLUG.dylib ??? (???) <FCAEFF80-8C5A-E23D-016C-C660FE5B11C5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PLUG.dylib
                 0x101fa0000 -        0x101fb6fe7 +PR.dylib ??? (???) <C59AC914-D04E-D71B-458E-483187F28CD5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PR.dylib
                 0x101fbf000 -        0x101fc5fff +PREF.dylib ??? (???) <4404C635-79B1-82C5-7791-6100F88C1D10> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PREF.dylib
                 0x101fca000 -        0x101fe6fff +RG.dylib ??? (???) <7A942ED4-7F36-2813-6AA8-27452427C2E6> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RG.dylib
                 0x101ff2000 -        0x101ff4ff7 +RI.dylib ??? (???) <082FABAF-C42C-F170-2BCC-168E368B9537> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RI.dylib
                 0x101ff7000 -        0x101ff8fff +RND.dylib ??? (???) <8CFFA986-DDE6-67F9-6A6B-AA554FA451E0> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/RND.dylib
                 0x101fff000 -        0x10205ffef +SLU.dylib ??? (???) <37403799-F7B6-21E7-2205-E25319E2A6E4> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SLU.dylib
                 0x102084000 -        0x1020a5ff7 +SND.dylib ??? (???) <A0D1D6DB-8EBF-F3CA-8640-6A72D15D8A85> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SND.dylib
                 0x1020af000 -        0x1020b1fff +STR.dylib ??? (???) <E93C9960-AA16-925D-1048-2DDA885AA6DB> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/STR.dylib
                 0x1020b5000 -        0x1020b8fff +T.dylib ??? (???) <3A483BC0-CE0B-3E66-6605-4547F6A29A8A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/T.dylib
                 0x1020bc000 -        0x1020fdfff +TDB.dylib ??? (???) <71C8D1FA-1429-53E9-4A60-AD6579D6D946> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/TDB.dylib
                 0x102111000 -        0x102843fff +TXT.dylib ??? (???) <C102965A-18C5-41F7-01AD-7C3F1708B702> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/TXT.dylib
                 0x102b70000 -        0x102bbcfef +U.dylib ??? (???) <12EAE215-0C2F-F90A-3297-524EA0FF2659> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/U.dylib
                 0x102bd8000 -        0x102bdcfff +VAL.dylib ??? (???) <5C7679BA-5570-6F23-B48B-3CAE6F19D58A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VAL.dylib
                 0x102bdf000 -        0x102cb1ff7 +com.adobe.exo.framework 6.0.0 (6.0.0.339847) <8DD8AE9B-4C33-39CB-A231-1EB47B4146A7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/exo.framework/Versions/A/exo
                 0x102e15000 -        0x102e3bfff +PREM.dylib ??? (???) <AB868976-82CD-23F6-F62E-3D5704CCB557> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PREM.dylib
                 0x102e4f000 -        0x102ea3ff7 +FRP.dylib ??? (???) <CD78E0FF-D26B-F1FA-A829-7ED2AB944C12> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FRP.dylib
                 0x102ec2000 -        0x103091fff +com.adobe.dvacore.framework 6.0.0 (6.0.0.339847) <59A0EEBA-1F35-69C3-5E8C-7ECF0190BB54> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                 0x10329e000 -        0x103706fff +com.adobe.dvaui.framework 6.0.0 (6.0.0.339847) <A939BAAC-F4AA-95E5-213D-69B32F340047> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                 0x103c77000 -        0x103d2fff7 +com.adobe.dvaworkspace.framework 6.0.0 (6.0.0.339847) <ADC6E24A-2FEB-0F08-04FB-CE1CDF8EBC2E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                 0x103e3c000 -        0x103e60fef +com.adobe.dvaunittesting.framework 6.0.0 (6.0.0.339847) <EF060542-090E-15CD-D5A0-B8308F88F9C6> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                 0x103ea4000 -        0x103f13ff7 +aif_core ??? (???) <E1ABEDE8-552B-4454-6B32-466A23426AA8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                 0x103f68000 -        0x1041a5ff7 +aif_ogl ??? (???) <E743AABB-B332-37C2-EC89-6851E955D2C4> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                 0x104373000 -        0x1043cbfff +data_flow ??? (???) <2A942DAA-AE8F-1E19-DB04-774CEF1B77F7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
                 0x1044ae000 -        0x104db3fef +image_compiler ??? (???) <05A8A1E1-6B22-8C16-647A-13B7EC4C6322> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/image_compiler.framework/Versions/A/image_compiler
                 0x105623000 -        0x1056aaff7 +image_flow ??? (???) <EE2149AA-500A-CF9D-3883-6D46D0FAD1B9> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
                 0x105753000 -        0x105798fff +com.adobe.dynamiclinkui.framework 6.0.0 (6.0.0.339847) <21AA262A-9874-6DD6-9288-C32FAFAA3162> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
                 0x105806000 -        0x1059f5fef +com.adobe.dynamiclink.framework 6.0.0 (6.0.0.339847) <2F133F03-7FDC-A967-3976-989A7F93EB2E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                 0x105c07000 -        0x105c69ff7 +com.adobe.ASLFoundation.framework 6.0.0 (6.0.0.0) <DD24AB90-538C-5055-5EEA-98988EB710C7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                 0x105d5f000 -        0x105d7cfff +com.adobe.ASLMessaging.framework 6.0.0 (6.0.0.0) <813D1E1C-F8E7-9265-E692-CEEB3C3DC284> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                 0x105daa000 -        0x105db9fff +com.adobe.ASLUnitTesting.framework 6.0.0 (6.0.0.0) <C541B49E-3DAF-B82D-D232-AC110AA87695> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
                 0x105dd4000 -        0x105df7fff +com.adobe.AudioFilterHost.framework 6.0.0 (6.0.0.0) <0CC87DCF-5B66-87B9-F08F-602D4FDF4341> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                 0x105e26000 -        0x105e6cfff +com.adobe.AudioFilters.framework 6.0.0 (6.0.0.0) <38756CA2-5CFA-4F49-F3F4-4DA82A702E66> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                 0x105ec9000 -        0x105f75ff7 +com.adobe.AudioRenderer.framework 6.0.0 (6.0.0.0) <AA906492-729C-649F-6AB5-1B790066E62E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                 0x106033000 -        0x106076fff +com.adobe.AudioSupport.framework 6.0.0 (6.0.0.0) <F4F947EF-758D-4C78-1A83-3DDFD2787023> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                 0x1060c0000 -        0x106ef3ff7 +com.adobe.Backend.framework 6.0.0 (6.0.0.0) <4AA46104-D33D-9C91-0DF7-DBACC2893534> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                 0x107974000 -        0x107ab7ff7 +com.adobe.ImageRenderer.framework 6.0.0 (6.0.0.0) <706C2179-CA31-4E79-EC31-6EE67B33C49E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                 0x107bd6000 -        0x107d65ff7 +com.adobe.ImporterHost.framework 6.0.0 (6.0.0.0) <F5DB417A-9B11-EAA1-E89C-ECF28945F3CF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                 0x107ee3000 -        0x107f49ff7 +com.adobe.MediaFoundation.framework 6.0.0 (6.0.0.0) <927F8873-FE2F-43FE-91E0-26B0D962048A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                 0x107fd1000 -        0x107fd4fff +com.adobe.MediaUtils.framework 6.0.0 (6.0.0.0) <65989AAF-ED52-A56A-A4E9-1C733734DCF8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                 0x107fdb000 -        0x107fdcfff +com.adobe.Memory.framework 6.0.0 (6.0.0.0) <8334ED4F-468A-1974-6EB8-06198BA476B4> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                 0x107fe3000 -        0x10802cff7 +com.adobe.MLFoundation.framework 6.0.0 (6.0.0.0) <5D90C7DA-FFCC-DC0B-0462-3E232FC4D0D5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                 0x10809c000 -        0x1080d8fff +com.adobe.PluginSupport.framework 6.0.0 (6.0.0.0) <69E3B346-06C5-48F8-2A4A-05B009E0463C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                 0x10811e000 -        0x10811fff7 +com.adobe.PRM.framework 6.0.0 (6.0.0.0) <DB552AA8-22F0-FEA6-7F0D-18CA248238F3> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                 0x108125000 -        0x108151ff7 +com.adobe.SweetPeaSupport.framework 6.0.0 (6.0.0.0) <415E8508-79E6-0A9D-B2B6-52E91899EB02> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                 0x108189000 -        0x1081ddff7 +com.adobe.VideoFrame.framework 6.0.0 (6.0.0.0) <BAB2683C-A428-C0F8-B3E3-0C52AD7D283E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                 0x10822d000 -        0x108381fff +com.adobe.VideoRenderer.framework 6.0.0 (6.0.0.0) <CFEC80A7-7293-AC02-ED22-8390711369F0> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                 0x108497000 -        0x108566fff +com.adobe.dvaeve.framework 6.0.0 (6.0.0.339847) <88F71C7F-DE6F-1CB3-F0B6-0FFD66EA239F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                 0x1086d9000 -        0x10875eff7 +com.adobe.PlayerHost.framework 6.0.0 (6.0.0.0) <2A77F0E7-7AD0-9880-446E-EF814C5F01A1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                 0x1087f3000 -        0x1088e4ff7 +com.adobe.VideoFilterHost.framework 6.0.0 (6.0.0.0) <59865915-3691-683E-9AEF-CF979470064D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                 0x1089a3000 -        0x108a4dfe7 +libicucnv.40.0.dylib 40.0.0 (compatibility 40.0.0) <768D99C5-46B9-B849-2834-B5BF541856D1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
                 0x108a74000 -        0x108ae1ff7 +libicudata.40.0.dylib 40.0.0 (compatibility 40.0.0) <1FC741E8-F498-4185-7677-42701BF39611> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
                 0x108ae4000 -        0x108b3eff7 +com.adobe.dvametadata.framework 6.0.0 (6.0.0.339847) <BCB9F3B2-F283-DC95-3062-D01166E40A6F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                 0x108bdb000 -        0x108c6fff7 +com.adobe.dvametadataUI.framework 6.0.0 (6.0.0.339847) <ECAA24EC-A155-2786-28CE-B415422BA9C2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                 0x108d45000 -        0x108d9cfff +com.adobe.dvatemporalxmp.framework 6.0.0 (6.0.0.339847) <29EAA336-F5CC-347A-01C3-856EE85B81EA> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                 0x108dd0000 -        0x108dfaff7 +com.adobe.dvamediatypes.framework 6.0.0 (6.0.0.339847) <FCBDCA19-41F0-1EA3-66D5-E1679F379EF6> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                 0x108e2d000 -        0x108e93ff7 +com.adobe.dvatransport.framework 6.0.0 (6.0.0.339847) <DB539572-3D8A-7B44-2211-9DE1FC3944FD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                 0x108f13000 -        0x108f4ffff +com.adobe.dvamarshal.framework 6.0.0 (6.0.0.339847) <ED1175AE-E97E-5E06-534D-A2DB3645E04F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                 0x108fe1000 -        0x108ff9fff +com.adobe.ProjectSupport.framework 6.0.0 (6.0.0.0) <9B759234-5FC0-D8CE-F923-BBA042344CAD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                 0x109021000 -        0x109087fff +com.adobe.DynamicLinkMedia.framework 6.0.0 (6.0.0.0) <95C6C363-9B98-4035-E21A-CC5911D1C9F6> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                 0x109137000 -        0x10913bff7 +com.adobe.AdobeCrashReporter 6.0 (6.0.20120720) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                 0x109141000 -        0x109141ff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <424E55F7-B6DA-0F5C-E56B-9ECB4A2E6BA8> /usr/lib/libmx.A.dylib
                 0x109144000 -        0x109170fff +com.adobe.AXE8SharedExpat AdobeAXE8SharedExpat 3.7.101.18636 (3.7.101.18636) <488DF1F7-A643-5168-706A-498A0322A87E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
                 0x109193000 -        0x109199ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <C07A1A9F-E1C5-91B8-3F1D-E820DDE3EC77> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                 0x1091a0000 -        0x1091bffff +com.adobe.BIB AdobeBIB 1.2.02.19553 (1.2.02.19553) <D665D6DB-849A-B75A-87A3-BCDBE502C146> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                 0x1091c6000 -        0x1091d5fff +com.adobe.boost_threads.framework 6.0.0 (6.0.0.339847) <E6DD278C-24BA-CD8E-4CB3-86CAFCB1DE69> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                 0x1091f6000 -        0x109264fef +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                 0x1092b8000 -        0x10938ffff +filter_graph ??? (???) <7040917C-8B4E-BB84-7969-124D5DE07B8D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_graph
                 0x1094a3000 -        0x109503ff7 +com.adobe.AdobeXMPCore Adobe XMP Core 5.3 -c 11 (66.146227) <96B43AA1-300E-B6DF-415F-8E90D70DDE48> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                 0x10950d000 -        0x1095c4fe7 +com.adobe.AdobeXMPFiles Adobe XMP Files 5.4 -f 50 (66.146227) <F8BA4F7C-7F22-D01C-C931-E4E7EF70958C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                 0x1095f7000 -        0x1096a5fef +com.adobe.AdobeScCore ScCore 4.2.13 (4.2.13.20553) <1DA959D4-4E63-75C8-E550-D69BEEB0989E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                 0x1096e2000 -        0x10979fff7 +com.adobe.AdobeExtendScript ExtendScript 4.2.13 (4.2.13.20553) <AA2C8A06-198D-499A-4667-36000B393EF2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                 0x1097e9000 -        0x1098e3fe7 +com.adobe.AXEDOMCore AdobeAXEDOMCore 3.7.101.18636 (3.7.101.18636) <C7652AF2-56D7-8AF8-A207-0BDEDDFF0BEC> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                 0x109987000 -        0x109ce8fef +com.adobe.CoolType AdobeCoolType 5.10.31.19553 (5.10.31.19553) <EBBA5B24-2AD8-B793-4DC2-ADCAA2342B06> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                 0x109d35000 -        0x10a0b2fff +com.adobe.AGM AdobeAGM 4.26.18.19553 (4.26.18.19553) <BE1F8ECC-FDD3-A308-3E75-A641D4D0869F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                 0x10a11e000 -        0x10a297fff +com.adobe.ACE AdobeACE 2.19.18.19553 (2.19.18.19553) <B2CC095C-33A0-7782-7A51-0F2C2567DDE8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                 0x10a2aa000 -        0x10a2d2ff7 +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <4D68A67D-F390-33AB-6036-5CE76A3067E7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                 0x10a2d9000 -        0x10a39efff +com.adobe.JP2K 2.0.0 (2.0.0.18562) <B14B096C-AA23-BA8F-E3AE-8DB102F9D161> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                 0x10a3eb000 -        0x10a42dff7 +com.adobe.ARE AdobeARE 1.5.02.19553 (1.5.02.19553) <33F16AE8-11E3-1B04-1B26-6761897DB125> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                 0x10a435000 -        0x10a87bff7 +com.adobe.MPS AdobeMPS 5.8.0.19673 (5.8.0.19673) <E63AFCA8-3E74-1745-8C74-8B0A78073BE5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                 0x10a8f7000 -        0x10a923ff7 +com.adobe.AXE16SharedExpat AdobeAXE16SharedExpat 3.7.101.18636 (3.7.101.18636) <6BC56AE6-E5FE-956E-B7BA-9D4DEEDD1A48> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
                 0x10a946000 -        0x10ba44fef +com.adobe.psl AdobePSL 13.0.0.19655 (13.0.0.19655) <8029DA17-402C-301F-02E9-D0EC8DF48BE8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                 0x10bc04000 -        0x10bd51ff7 +com.winsoft.wrservices WRServices 5.0.0 (5.0.0) <FFA48E0A-A17C-A04F-AE20-6815EB944DEA> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                 0x10bdc5000 -        0x10beb7fef +com.adobe.ExporterHost.framework 6.0.0 (6.0.0.0) <0D4A1A03-71A3-CA53-168E-5AE6056E5309> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                 0x10bfa7000 -        0x10c021fef +com.adobe.adobe_caps adobe_caps 6.0.29.0 (6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                 0x10c030000 -        0x10c114fe7 +com.adobe.amtlib amtlib 6.0.0.75 (6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                 0x10c125000 -        0x10c13fff7 +com.adobe.ahclientframework 1.7.0.56 (1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                 0x10c148000 -        0x10c91cfe7 +com.adobe.PDFL PROD_MAJOR.PROD_MINOR.PROD_STEP (10.0.1.19598) <D1204626-3571-3CED-36D9-DF063196C7C2> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                 0x10c9d4000 -        0x10c9f7fef +SegMatServices.dylib ??? (???) <E3514315-6096-B380-018C-71547B5E5FED> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SegMatServices.dylib
                 0x10ca0b000 -        0x10ca0bff7 +SAM.dylib ??? (???) <AE58DC75-6DBC-CC6E-0B45-89868D799BBB> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SAM.dylib
                 0x10ca0e000 -        0x10ca6afff +TDL.dylib ??? (???) <F08A0DD5-FF1B-579F-BDFA-4B58DB558345> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/TDL.dylib
                 0x10ca7f000 -        0x10caa9fff +com.adobe.dvacaptioning.framework 6.0.0 (6.0.0.339847) <D5364E58-97DD-2AC3-2F18-18B8AC3F4743> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
                 0x10cadf000 -        0x10cdb7fe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libxerces-c-3.0.dylib
                 0x10cf31000 -        0x10cf55fe7 +com.mainconcept.mc.enc.dv 9.1 (9.1.6.4544) <842421AD-DB61-E7AA-8398-1AB75D600CC0> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
                 0x10cf69000 -        0x10cfd8fff +com.adobe.QT32Client.framework 6.0.0 (6.0.0.0) <600BB9C9-450E-18C9-A2FA-7373D73027A1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
                 0x10d06e000 -        0x10e46ff2f +liboptix.1.dylib 3.0.1 (compatibility 1.0.0) <F73808E6-D80C-065F-00F6-FF446FB5CD29> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/liboptix.1.dylib
                 0x10eb8e000 -        0x10ebf8fef +libcudart.dylib 4.2.0 (compatibility 1.1.0) <6FD33B3C-5941-CE4A-41B5-F80250A591E1> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libcudart.dylib
                 0x10ebff000 -        0x10ec00fff +libtlshook.dylib 4.0.0 (compatibility 1.1.0) <1D1C35CB-E17F-79E0-7DAE-988625AB57F9> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtlshook.dylib
                 0x10ec03000 -        0x10ecceff7 +com.adobe.AMEWrapper.framework 6.0.0 (6.0.0.0) <1262E81B-473A-5104-1662-08F20A1865F5> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
                 0x10ed98000 -        0x10ee96ff7 +com.adobe.EncoderHost.framework 6.0.0 (6.0.0.0) <9693F065-140A-207D-08E7-273A1A035621> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                 0x10ef8b000 -        0x10f181fff +com.adobe.SettingsUI.framework 6.0.0 (6.0.0.0) <71661181-CF07-1C33-2906-874C148B4277> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                 0x10f3de000 -        0x10f40afff +com.adobe.amefoundation.framework 6.0.0 (6.0.0.0) <971F8583-B8BC-25F6-E186-BC59F0FBFD81> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
                 0x10f44e000 -        0x10f47fff7 +com.adobe.ameproperties.framework 6.0.0 (6.0.0.0) <7880964B-6827-E0C7-D65D-3C8E26E6F25C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
                 0x10f4cb000 -        0x10f4e7ff7 +com.adobe.AMEAppFoundation.framework 6.0.0 (6.0.0.0) <8EC48E27-A65D-85EA-529F-F53B84B0C6BD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                 0x10f51c000 -        0x10f541fff +com.adobe.PostEncodeHost.framework 6.0.0 (6.0.0.0) <8BD5E652-2FAF-1729-B88C-F33293EE5376> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
                 0x10f5a8000 -        0x10f5aafef  com.apple.textencoding.unicode 2.3 (2.3) <D95D796E-4D14-665C-F439-4652C0CD453F> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                 0x11009a000 -        0x1100a7ff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.5 (2.2.5) <6AF52262-5A98-9EC3-4640-B2617DAE5E17> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
                 0x1102ed000 -        0x1102eeff7 +libcuda.dylib 4.2.10 (compatibility 1.1.0) <DEAD4D33-A552-A5DF-C21E-DC78BF9538A7> /usr/local/cuda/lib/libcuda.dylib
                 0x1102f0000 -        0x1102f1ff7 +libcuda.dylib 3.2.17 (compatibility 1.1.0) <B0B0F347-F28F-E31A-B5F4-46E0EECDD3AE> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libcuda.dylib
                 0x123089000 -        0x12308afff  ATSHI.dylib ??? (???) <C3BF96C6-C170-B0DD-7541-78AD91B4BD70> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                 0x123091000 -        0x123095fff  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <917E3DC8-E34D-B130-F61F-50808466E674> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                 0x12309a000 -        0x1230a0ff7  com.apple.audio.AppleHDAHALPlugIn 2.0.8 (2.0.8f3) <2BC73C66-767B-CA96-B313-B95EC153547B> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                 0x1230a9000 -        0x1230adff7  libFontRegistryUI.dylib ??? (???) <D899EA35-811A-5537-BF0D-7723F6F5782A> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                 0x1230b3000 -        0x1230b7ff7 +com.adobe.AfterEffects.EasyEase ??? (???) <727860C8-59BA-8126-5CB5-722C8C681994> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/EasyEase.plugin/Contents/MacOS/EasyEase
                 0x123787000 -        0x123788fff +com.adobe.AfterEffects.Paint ??? (???) <C0A7248A-0ECE-AD58-1787-57206EF54F91> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
                 0x12393f000 -        0x123985fff +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 6.0.0.24 (6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
                 0x123a3f000 -        0x123a53ff7 +com.adobe.QTParser.framework 6.0.0 (6.0.0.0) <CE2633F2-90C9-52E0-7A33-0AF205722B7F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                 0x123a6b000 -        0x123a6fff7 +com.adobe.AfterEffects.TRKeys ??? (???) <B04E0A85-8624-1C2B-33BF-A2840ADDB0D8> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/TRKeys.plugin/Contents/MacOS/TRKeys
                 0x123af0000 -        0x123af1fff  com.apple.bluetooth.IOBluetoothSCOAudioDriverPlugIn 2.4.5 (2.4.5f3) <7AEC190F-0B3D-38D1-8142-80254C1A1626> /System/Library/Extensions/IOBluetoothFamily.kext/Contents/PlugIns/IOBluetoothSCOAudioDri ver.kext/Contents/Resources/IOBluetoothSCOAudioDriverPlugIn.bundle/Contents/MacOS/IOBlueto othSCOAudioDriverPlugIn
                 0x124e7d000 -        0x124e82ff7 +com.adobe.ExporterCoreAudio.framework 6.0.0 (6.0.0.0) <32004C7B-14BE-FC64-845B-FA0B8211DE3C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCor eAudio
                 0x124e97000 -        0x124ebdfff  GLRendererFloat ??? (???) <38621D22-8F49-F937-851B-E21BD49A8A88> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                 0x124ee5000 -        0x124ef0ff7 +CUDA 4.2.10 (compatibility 1.1.0) <FC7BE7EA-EE98-6705-1785-0889C80AED4A> /Library/Frameworks/CUDA.framework/Versions/A/CUDA
                 0x124ef6000 -        0x124efbff7 +com.adobe.AfterEffects.ExpScale ??? (???) <A453F839-D2C2-06B1-2298-53B3D7CE3816> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/ExpScale.plugin/Contents/MacOS/ExpScale
                 0x125000000 -        0x125193fe7  GLEngine ??? (???) <BCE83654-81EC-D231-ED6E-1DD449B891F2> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                 0x1251c4000 -        0x126235ff7  com.apple.driver.AppleIntelHDGraphicsGLDriver 1.6.42 (6.4.2) <C44CB5D9-318E-3390-EEF4-F49CD0F30765> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelH DGraphicsGLDriver
                 0x126c37000 -        0x126c3aff7 +com.adobe.AfterEffects.Durer ??? (???) <0C7EA13F-D44A-C20D-D894-85D94264CD62> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
                 0x128dc4000 -        0x128deffef +com.digidesign.digidesign.DigiCoreAudioPlugIn 9.0 (9.0f121) <E854AA6F-80C9-0B56-727E-443A7488AE16> /Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio
                 0x128df7000 -        0x128dfcfff +com.adobe.AfterEffects.RPFImport ??? (???) <B87C1A0F-863F-A172-0485-D3781E38E3D8> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/RPFImport.plugin/Contents/MacOS/RPFImport
                 0x129400000 -        0x1294fcfe7 +libcuda_256.00.35.dylib 4.2.10 (4.2.10) <EAD63273-B4A7-08B1-3788-415815E8AA1D> /Library/Frameworks/CUDA.framework/Versions/A/Libraries/libcuda_256.00.35.dylib
                 0x129518000 -        0x129c74fef +libgpgpucomp.dylib ??? (???) <14C54128-9AA4-A717-27FD-86F2ECB45BFD> /Library/Frameworks/CUDA.framework/Versions/A/Libraries/libgpgpucomp.dylib
                 0x12a0cb000 -        0x12a0dafef +com.adobe.AfterEffects.FreePin ??? (???) <D2F0D414-A96A-CAA1-E870-30A8AA84ABEF> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
                 0x12b489000 -        0x12b497ff7 +com.adobe.AudioConverter.framework 6.0.0 (6.0.0.0) <25601F87-A4FA-F668-116A-4C6D544332FD> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
                 0x12b5cb000 -        0x12b7bdff7  com.apple.audio.codecs.Components 2.0.4 (2.0.4) <D674F6B1-EA1B-F541-CDA8-8AED81AB5375> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
                 0x12b82e000 -        0x12b85bfff +com.adobe.ExporterQuickTimeHost.framework 6.0.0 (6.0.0.0) <28F0F79A-0275-EE59-BF27-514F0C304DBB> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
                 0x12b89a000 -        0x12b8dbff7 +com.adobe.ImporterQuickTime.framework 6.0.0 (6.0.0.0) <8BA18EF0-3BDB-8DED-6207-A77552362DCA> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
                 0x12b925000 -        0x12b9c9fff +com.adobe.IPPMPEGDecoder.framework 6.0.0 (6.0.0.0) <6DBE0055-A7B8-1319-658C-B340871059E6> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
                 0x12be8d000 -        0x12be9dfff +com.adobe.AfterEffects.MThread ??? (???) <01F9730A-C5C7-EDC8-436E-77CC29F640D3> /Applications/Adobe After Effects CS6/Plug-ins/Extensions/Mthread.plugin/Contents/MacOS/MThread
                 0x12bea6000 -        0x12beadff7 +com.adobe.AfterEffects.Sequence ??? (???) <31C9C892-C0DF-5247-64A4-4B9D1E98BBD1> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/Sequence.plugin/Contents/MacOS/Sequence
                 0x12c073000 -        0x12c07ffff +com.adobe.AfterEffects.LocalizePresets ??? (???) <DAD68953-F241-238C-BFD0-334430DAAEE9> /Applications/Adobe After Effects CS6/Plug-ins/Extensions/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
                 0x12c087000 -        0x12c092fff +com.adobe.AfterEffects.Analyzer ??? (???) <59551BB0-99B5-07B1-5726-64ADAE05E968> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/Analyzer.plugin/Contents/MacOS/Analyzer
                 0x12c11c000 -        0x12c1a2fef +com.adobe.AfterEffects.AEGPDriver ??? (???) <D968BCB1-420B-6591-94D2-E37693C1DAF4> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
                 0x12c1cf000 -        0x12c1eaff7 +com.adobe.AfterEffects.PS3Export ??? (???) <691DC71B-AEE8-3916-57BA-9F37789F9E99> /Applications/Adobe After Effects CS6/Plug-ins/Format/PS Layer Export.plugin/Contents/MacOS/PS3Export
                 0x12c300000 -        0x12c327fff +com.adobe.AfterEffects.PS3Import ??? (???) <2E9B4973-7A05-1680-6EE2-E2D55CB9EF43> /Applications/Adobe After Effects CS6/Plug-ins/Format/PS Layer Import.plugin/Contents/MacOS/PS3Import
                 0x12c337000 -        0x12c39cfff +com.adobe.AfterEffects.Escher ??? (???) <61E03E2D-EDA3-0033-F918-71751EF0DB0B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
                 0x12c3a9000 -        0x12c43dff7 +com.adobe.AfterEffects.AEDynamicLinkServer ??? (???) <676C348C-4E95-A3D5-90D7-49714403740F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
                 0x12c504000 -        0x12c520ff7 +com.adobe.AfterEffects.AudioPal ??? (???) <E6AC1195-9144-789D-4908-4042AC7F57F3> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
                 0x12c534000 -        0x12c563fe7 +com.adobe.AfterEffects.BrushPal ??? (???) <204A6489-1C9B-D64E-C6BC-C10CA756386F> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
                 0x12c57b000 -        0x12c5bcfe7 +com.adobe.AfterEffects.CharPal ??? (???) <642CC87B-1C75-1727-CE17-F49C75C681C7> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
                 0x12c5dc000 -        0x12c602fff +com.adobe.AfterEffects.InfoPal ??? (???) <F194A823-92B9-3899-4955-37F5ABAA81F8> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
                 0x12c617000 -        0x12c641fff +com.adobe.AfterEffects.PaintPal ??? (???) <10BDDBD6-2966-A142-B29B-5FD70AD34691> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
                 0x12c659000 -        0x12c67aff7 +com.adobe.AfterEffects.ParaPal ??? (???) <28DF4553-C5BC-BB05-3DCE-E8BDDB330E4C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
                 0x12c68f000 -        0x12c72bfff +com.adobe.AfterEffects.Picasso ??? (???) <51BF1512-B232-1042-29FA-AE83EDB6CF14> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Picasso.plugin/Contents/MacOS/Picasso
                 0x12c760000 -        0x12c784ff7 +com.adobe.AfterEffects.TimePal ??? (???) <8A1E0115-9D78-ACCF-1C86-4418BB54497C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
                 0x12c79c000 -        0x12c7bdfff +com.adobe.AfterEffects.TrackerPal ??? (???) <50713473-7D32-9DDA-E8EB-218FE53F5464> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
                 0x12d000000 -        0x12d14afff +com.adobe.AfterEffects.SnapCut ??? (???) <7F67FBA3-C675-10EF-A18A-AF084CC8130C> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
                 0x12d178000 -        0x12d1bffff +com.adobe.AfterEffects.ToolPal ??? (???) <C3A2D30A-F802-6042-8A5D-96FEB808F292> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
                 0x12d1e4000 -        0x12e7fefff +com.imagineersystems.mochashapeconverter4ae 2.0.1 (2.0.1f5279) <EE442D71-21B1-3F1E-A51C-7A04C465D54F> /Applications/Adobe After Effects CS6/Plug-ins/Effects/mochaAE/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
                 0x12eb79000 -        0x12ebeefe7 +com.adobe.AfterEffects.Renoir ??? (???) <04E3A321-17D1-1C92-48D7-F258E231C63C> /Applications/Adobe After Effects CS6/Plug-ins/Extensions/Renoir.plugin/Contents/MacOS/Renoir
                 0x12ee1f000 -        0x12eea2ff7 +com.adobe.AfterEffects.FlashExporter ??? (???) <059A500D-B450-5332-70EB-A8076CCD43D6> /Applications/Adobe After Effects CS6/Plug-ins/Format/FlashExporter.plugin/Contents/MacOS/FlashExporter
                 0x12eeca000 -        0x12f02fff7 +com.adobe.AfterEffects.OpenEXR ??? (???) <6D94A565-94B4-B5DE-482C-F0AA739AFFBA> /Applications/Adobe After Effects CS6/Plug-ins/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
                 0x12f296000 -        0x12f2cafff +com.adobe.AfterEffects.PNGIO ??? (???) <C0D1B907-7391-60DE-619D-08E1411B5F48> /Applications/Adobe After Effects CS6/Plug-ins/Format/PNGIO.plugin/Contents/MacOS/PNGIO
                 0x12f2d8000 -        0x12f3b8ff7 +com.adobe.AfterEffects.PremiereProImport ??? (???) <1FB7A4D5-2F17-4170-D3E9-C712B9FE9C68> /Applications/Adobe After Effects CS6/Plug-ins/Format/PremiereProImport/PremiereProImport.plugin/Contents/MacOS/PremierePro Import
                 0x12f3d5000 -        0x12f431ff7 +com.adobe.MediaCoreUI.framework 6.0.0 (6.0.0.0) <EBF6B876-5128-7BCF-8A71-568334AA8E2E> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                 0x12f494000 -        0x12f8f7fe9 +com.adobe.ProImportAE Pro Import AE version 6.00 (6.00) <E9D54936-8C08-E083-BEA3-A6F0F577E250> /Applications/Adobe After Effects CS6/Plug-ins/Format/ProImport/Pro Import AE.plugin/Contents/MacOS/Pro Import AE
                 0x12fa99000 -        0x12faf4fff +com.adobe.AfterEffects.TIFFIO ??? (???) <41AF7702-25DC-06F9-16DE-5E4FF0CC51CE> /Applications/Adobe After Effects CS6/Plug-ins/Format/TIFF.plugin/Contents/MacOS/TIFFIO
                 0x12fb00000 -        0x12fbcbfef +com.adobe.AfterEffects.Vic ??? (???) <0B3E2ABE-CCF7-9B58-53F1-43B961146F3F> /Applications/Adobe After Effects CS6/Plug-ins/Format/Vector Output.plugin/Contents/MacOS/Vic
                 0x12fc1a000 -        0x12fc37ff7 +com.adobe.AfterEffects.Align ??? (???) <F95B2B1B-8BDC-B6D4-ABC0-D566188707C6> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/Align.plugin/Contents/MacOS/Align
                 0x12fc48000 -        0x12fc57fff +com.adobe.AfterEffects.MayaImport ??? (???) <BF37321E-6386-5FFA-A7A4-EB2CE6038586> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/MayaImport.plugin/Contents/MacOS/MayaImport
                 0x12fc5b000 -        0x12fc72fff +com.adobe.AfterEffects.MetaPal ??? (???) <442452FB-1570-DA32-0773-D667C42F3724> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/MetaPal.plugin/Contents/MacOS/MetaPal
                 0x12fc88000 -        0x12fcb4fe7 +com.adobe.AfterEffects.Moka ??? (???) <4D6D08BA-E92B-A794-BC22-AEA89A476116> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/Moka.plugin/Contents/MacOS/Moka
                 0x12fcc5000 -        0x12fcdafff +com.adobe.AfterEffects.MotionSketch ??? (???) <4646C190-31A8-4CF7-EA8F-43AD5D77379D> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/MotionSketch.plugin/Contents/MacOS/MotionSketch
                 0x12fcea000 -        0x1300d8ff7 +com.adobe.AfterEffects.Scripting ??? (???) <4F355195-7F4B-B9D4-10EB-DBF5ECDACE2B> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/Scripting.plugin/Contents/MacOS/Scripting
                 0x13020f000 -        0x130213ff7 +com.adobe.ape.shim 3.3.8.19346 (3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                 0x130219000 -        0x13030afff +com.adobe.AdbeScriptUIFlex ScriptUIFlex 6.2.29 (6.2.29.20553) <0CB5E114-8871-D53C-3EC0-BE1E93CC9E7B> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdbeScriptUIFlex.framework/Versions/A/AdbeScriptUIFlex
                 0x13038e000 -        0x1303b4ff7 +com.adobe.ape 3.3.8.19346 (3.3.8.19346) <79E11A18-8AF4-2515-59F7-4CBE161BF020> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/adbeapecore
                 0x130856000 -        0x1317dbfd7 +com.adobe.ape.engine 3.3.8.19346 (3.3.8.19346) <5E188E32-37F7-4E0B-0674-E8D16B60074F> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS /adbeapeengine
                 0x131a28000 -        0x131b0efe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <64B3566E-5F3A-A466-ED3F-B91F4B3E5F56> /usr/lib/libcrypto.0.9.7.dylib
                 0x132d92000 -        0x132dcffff  com.apple.DP.ScreenInputDevice 15.0 (15.0) <6DA54430-CEB6-B797-9CF4-B86E3EBAE603> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInpu tDevice.plugin/Contents/MacOS/AppleScreenInputDevice
                 0x132dda000 -        0x132e03fef  com.apple.mio.DAL.VDC_4 142.0 (1497) <9020BFFC-5BD0-0193-6AEF-41A107CE7C1B> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Cont ents/MacOS/VDC
                 0x133094000 -        0x1330abfe7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <E2A386E4-19AE-2103-B9E7-4024C4C14EED> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                 0x1330af000 -        0x1330befe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <D0737202-6BDC-1207-B324-1676BBB21CE6> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                 0x1330c2000 -        0x1330d4fff  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <A980212E-1E49-46AC-6E74-2318DE2DDB6F> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                 0x1330d8000 -        0x1330f9fef  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <4ADF30A9-27A4-B9C5-6BD2-7CC38707F17E> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                 0x134366000 -        0x13437cfff +com.adobe.AfterEffects.Smoother ??? (???) <FE19E96A-C8AB-DFAB-14CF-04940299803B> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/Smoother.plugin/Contents/MacOS/Smoother
                 0x13438c000 -        0x1343a3fff +com.adobe.AfterEffects.Wiggler ??? (???) <8B33EBD9-105B-A9BC-3A61-33F1B98C5F89> /Applications/Adobe After Effects CS6/Plug-ins/Keyframe/Wiggler.plugin/Contents/MacOS/Wiggler
                 0x135d00000 -        0x135df0fe7 +com.adobe.AfterEffects.RefineMatte ??? (???) <DFBA4E6B-984C-AE09-CC0A-B10D26B13E2D> /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
              0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <DB8B8AB0-0C97-B51C-BE8B-B79895735A33> /usr/lib/dyld
              0x7fff80003000 -     0x7fff80088ff7  com.apple.print.framework.PrintCore 6.3 (312.7) <F00C561F-D38B-8785-5218-1A0C3BA61177> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
              0x7fff80089000 -     0x7fff800f1fff  com.apple.MeshKitRuntime 1.1 (49.2) <A490FE03-313D-1317-A9B8-25EF75CB1A81> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
              0x7fff800f2000 -     0x7fff80414fff  com.apple.JavaScriptCore 6534.59 (6534.59.11) <992F7C39-0ADA-C5EF-0405-55F81A5B2F76> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
              0x7fff80415000 -     0x7fff80415ff7  com.apple.ApplicationServices 38 (38) <0E2FC75E-2BE2-D04D-CA78-76E38A89DD30> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
              0x7fff80416000 -     0x7fff80416ff7  com.apple.Carbon 150 (152) <4533D085-6476-0A37-09CD-3CA73D75D4F8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
              0x7fff80417000 -     0x7fff80481fe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <7BD7F19B-ACD4-186C-B42D-4DEBA6795628> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
              0x7fff80482000 -     0x7fff8049dff7  com.apple.openscripting 1.3.1 (???) <DC329CD4-1159-A40A-A769-70CAA70F601A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
              0x7fff8049e000 -     0x7fff8049eff7  com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
              0x7fff8049f000 -     0x7fff804e0ff7  com.apple.SystemConfiguration 1.10.9 (1.10.2) <642854D8-F4EF-4685-42A6-E48A1904D885> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
              0x7fff804e1000 -     0x7fff8071bfef  com.apple.imageKit 2.0.3 (1.0) <9EA216AF-82D6-201C-78E5-D027D85B51D6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
              0x7fff8071c000 -     0x7fff80893fe7  com.apple.CoreFoundation 6.6.6 (550.44) <BB4E5158-E47A-39D3-2561-96CB49FA82D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
              0x7fff80894000 -     0x7fff809d2fff  com.apple.CoreData 102.1 (251) <96C5E9A6-C28C-E9CC-A0DB-27801A22A49F> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
              0x7fff80b84000 -     0x7fff80b8aff7  com.apple.DiskArbitration 2.3.1 (2.3.1) <FD5CF2E6-E5FF-1E2A-37E0-304722DA15E1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
              0x7fff80b8b000 -     0x7fff80bd2fff  com.apple.QuickLookFramework 2.3 (327.7) <A8169A96-FAE6-26B2-A9A9-C78BA5787146> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
              0x7fff80c34000 -     0x7fff80cfffff  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <86982FBB-B224-CBDA-A9AD-8EE97BDB8681> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
              0x7fff80d00000 -     0x7fff80db5fe7  com.apple.ink.framework 1.3.3 (107) <A68339AA-909D-E46C-35C0-72808EE3D043> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
              0x7fff80db6000 -     0x7fff80dd7fff  libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <9410EC7F-4D24-6740-AFEE-90405750FAD7> /usr/lib/libresolv.9.dylib
              0x7fff80dd8000 -     0x7fff80dd8ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
              0x7fff8156e000 -     0x7fff81f68ff7  com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
              0x7fff81f69000 -     0x7fff81fb8ff7  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <066A477D-C16C-A6FD-718F-0CE8D39807DE> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
              0x7fff81fb9000 -     0x7fff8200eff7  com.apple.framework.familycontrols 2.0.2 (2020) <1E8D193F-3236-59AB-2242-14AD94128E81> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
              0x7fff82053000 -     0x7fff82138fef  com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
              0x7fff8218a000 -     0x7fff8218eff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
              0x7fff82268000 -     0x7fff82390ff7  com.apple.MediaToolbox 0.484.60 (484.60) <F921A5E6-E260-03B4-1458-E5814FA1924D> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
              0x7fff82391000 -     0x7fff82447ff7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
              0x7fff82448000 -     0x7fff82489fef  com.apple.QD 3.36 (???) <04F03722-91CA-6858-55A4-54D7F29789A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
              0x7fff8248a000 -     0x7fff825bffff  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <F4814A13-E557-59AF-30FF-E62929367933> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
              0x7fff82763000 -     0x7fff82a97fef  com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
              0x7fff82a98000 -     0x7fff82edffef  com.apple.RawCamera.bundle 3.7.1 (570) <5AFA87CA-DC3D-F84E-7EA1-6EABA8807766> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
              0x7fff82ee0000 -     0x7fff830a1fef  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
              0x7fff830a2000 -     0x7fff830b3fff  com.apple.DSObjCWrappers.Framework 10.6 (134) <CF1D9C05-8D77-0FFE-38E8-63D8A23E92E1> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
              0x7fff830b4000 -     0x7fff830e3fff  com.apple.quartzfilters 1.6.0 (1.6.0) <52D41730-D485-A7AE-4937-FE37FC732F65> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
              0x7fff830e4000 -     0x7fff83125fef  com.apple.CoreMedia 0.484.60 (484.60) <6B73A514-C4D5-8DC7-982C-4E4F0231ED77> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
              0x7fff83142000 -     0x7fff8318cff7  com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
              0x7fff8318d000 -     0x7fff8323dfff  edu.mit.Kerberos 6.5.11 (6.5.11) <CDA011E3-18C9-1573-3A31-497404CD6675> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
              0x7fff8323e000 -     0x7fff8327bfff  com.apple.LDAPFramework 2.0 (120.1) <E5FA9339-4812-E8FE-C366-EE3DC975DBC6> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
              0x7fff8327c000 -     0x7fff8327efff  com.apple.print.framework.Print 6.1 (237.1) <87A5BEEC-2D37-5CB7-8B13-7B605397573F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
              0x7fff832d4000 -     0x7fff832ffff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <3630A97F-55C1-3F34-CA63-3847653C9645> /usr/lib/libxslt.1.dylib
              0x7fff83300000 -     0x7fff83305ff7  com.apple.CommonPanels 1.2.4 (91) <8B088D78-E508-6622-E477-E34C22CF2F67> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
              0x7fff83306000 -     0x7fff83308fff  libRadiance.dylib ??? (???) <BF694EE5-6FDA-553A-CC89-F7135618E9C7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
              0x7fff83309000 -     0x7fff83352fef  libGLU.dylib ??? (???) <B0F4CA55-445F-E901-0FCF-47B3B4BAE6E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
              0x7fff83353000 -     0x7fff83392ff7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <B2E93DEC-2F33-366A-995C-ACA0523D508F> /usr/lib/libssl.0.9.8.dylib
              0x7fff833dd000 -     0x7fff833e0ff7  libCoreVMClient.dylib ??? (???) <75819794-3B7A-8944-D004-7EA6DD7CE836> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
              0x7fff83796000 -     0x7fff837befff  com.apple.DictionaryServices 1.1.2 (1.1.2) <6B8C5FB6-FE6F-3345-0441-BED51E815379> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
              0x7fff837e3000 -     0x7fff83854ff7  com.apple.AppleVAFramework 4.10.27 (4.10.27) <6CDBA3F5-6C7C-A069-4716-2B6C3AD5001F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
              0x7fff83855000 -     0x7fff83a37fef  libType1Scaler.dylib ??? (???) <7892C4D7-3E5E-D7DA-AA4E-8D4ACED143D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
              0x7fff83a38000 -     0x7fff83b0cfe7  com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
              0x7fff83b0d000 -     0x7fff83b54ff7  com.apple.coreui 2 (114) <31118426-355F-206A-65AB-CCA2D2D3EBD7> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
              0x7fff83b7f000 -     0x7fff83b80ff7  com.apple.TrustEvaluationAgent 1.1 (1) <A91CE5B9-3C63-5F8C-5052-95CCAB866F72> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
              0x7fff83b81000 -     0x7fff83c5eff7  com.apple.vImage 4.1 (4.1) <A0DE28F5-7B45-D268-0497-C79A826C8E53> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
              0x7fff83c61000 -     0x7fff83c9bfff  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <4F2A4397-89BD-DEAC-4971-EE838FFA0964> /usr/lib/libcups.2.dylib
              0x7fff83cb8000 -     0x7fff83cb9ff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <49B723D1-85F8-F86C-2331-F586C56D68AF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
              0x7fff83cba000 -     0x7fff83d02ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
              0x7fff83d03000 -     0x7fff83d0dfff  com.apple.DisplayServicesFW 2.3.5 (290) <18913B62-8C65-B81E-AA3C-27049D9D4FF7> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
              0x7fff83d0e000 -     0x7fff83d49fff  com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
              0x7fff83d4a000 -     0x7fff84446ff7  com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
              0x7fff84447000 -     0x7fff8448cfff  com.apple.CoreMediaIOServices 142.0 (1497) <0A7A9B83-0C8A-DA9D-2815-DA710ACF5172> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
              0x7fff84513000 -     0x7fff8459ffef  SecurityFoundation ??? (???) <48FE90D0-7C14-D41B-6A4A-8E174582C7AE> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
              0x7fff845a0000 -     0x7fff846b6ff7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <3814FCF9-92B9-A6AB-E76A-F7021894AA3F> /usr/lib/libxml2.2.dylib
              0x7fff846b7000 -     0x7fff846c6fff  com.apple.NetFS 3.2.2 (3.2.2) <84419796-36C9-DDCF-5FD1-0C96499EB63E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
              0x7fff847bf000 -     0x7fff847c4fff  libGIF.dylib ??? (???) <3BAD0DE8-8151-68B0-2244-A4541C738972> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
              0x7fff849c4000 -     0x7fff849d3fef  com.apple.opengl 1.6.14 (1.6.14) <ECAE2D12-5BE3-46E7-6EE5-563B80B32A3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
              0x7fff849d4000 -     0x7fff84a64fff  com.apple.SearchKit 1.3.0 (1.3.0) <45BA1053-9196-3C2F-2421-AFF5E09627CC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
              0x7fff84a65000 -     0x7fff84d63fff  com.apple.HIToolbox 1.6.5 (???) <98FCEA0D-FA33-E859-B39C-2C1F59F9E22D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
              0x7fff84d64000 -     0x7fff84e26fe7  libFontParser.dylib ??? (???) <EF06F16C-0CC9-B4CA-7BD9-0A97FA967340> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
              0x7fff84e5e000 -     0x7fff84e72fff  libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
              0x7fff84e73000 -     0x7fff84e73ff7  com.apple.CoreServices 44 (44) <616722B1-5E79-DCCF-BF5E-0DD5802CCBD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
              0x7fff84e9c000 -     0x7fff84ef2fe7  libTIFF.dylib ??? (???) <2DBEC120-DAA7-3789-36A2-A205BCDF2D72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
              0x7fff84ef9000 -     0x7fff84f20ff7  libJPEG.dylib ??? (???) <08758593-6436-B29E-1DA8-F15597835EC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
              0x7fff84f7e000 -     0x7fff85018fff  com.apple.ApplicationServices.ATS 275.19 (???) <2DE8987F-4563-4D8E-45C3-2F6F786E120D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
              0x7fff85019000 -     0x7fff85189fff  com.apple.QTKit 7.7 (1800) <10F1DA07-ED26-C103-EE0A-515898C1DB19> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
              0x7fff85196000 -     0x7fff85214ff7  com.apple.CoreText 151.13 (???) <5C6214AD-D683-80A8-86EB-328C99B75322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
              0x7fff85215000 -     0x7fff85236fe7  libPng.dylib ??? (???) <D8EC7740-EE32-865A-2F75-C9EDE2135510> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
              0x7fff85237000 -     0x7fff852f8fef  com.apple.ColorSync 4.6.8 (4.6.8) <7DF1D175-6451-51A2-DBBF-40FCA78C0D2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
              0x7fff852f9000 -     0x7fff852ffff7  IOSurface ??? (???) <2AAA9416-1CC0-1F40-0FA0-33AE6162378D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
              0x7fff85300000 -     0x7fff8569dfe7  com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
              0x7fff8569e000 -     0x7fff85757fff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <E8FFCEA1-3BE3-F0C9-07EA-C37678C4D2F5> /usr/lib/libsqlite3.dylib
              0x7fff85758000 -     0x7fff85796fe7  libFontRegistry.dylib ??? (???) <395D7C0D-36B5-B353-0DC8-51ABC0B1C030> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
              0x7fff857a5000 -     0x7fff857d6fff  libGLImage.dylib ??? (???) <562565E1-AA65-FE96-13FF-437410C886D0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
              0x7fff857d7000 -     0x7fff85a40fff  com.apple.QuartzComposer 4.2 ({156.30}) <C05B97F7-F543-C329-873D-097177226D79> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
              0x7fff85a43000 -     0x7fff85a63fff  com.apple.DirectoryService.Framework 3.6 (621.16) <0ED4A74A-F8FB-366D-6588-F13EA397326F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
              0x7fff85a64000 -     0x7fff85b7efff  libGLProgrammability.dylib ??? (???) <D1650AED-02EF-EFB3-100E-064C7F018745> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
              0x7fff85b7f000 -     0x7fff85b85ff7  com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
              0x7fff85b86000 -     0x7fff85bd9ff7  com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
              0x7fff85bda000 -     0x7fff85bdaff7  com.apple.quartzframework 1.5 (1.5) <FA660AAC-70CD-7EA2-5DF1-A8724D8F4B1B> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
              0x7fff85c69000 -     0x7fff86473fe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <2F26CDC7-DAE9-9ABE-6806-93BBBDA20DA0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
              0x7fff86474000 -     0x7fff8657eff7  com.apple.MeshKitIO 1.1 (49.2) <D7227401-9DC9-C2CB-C83B-C2B10C61D4E4> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
              0x7fff8657f000 -     0x7fff86596fff  com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
              0x7fff86597000 -     0x7fff865e3fff  libauto.dylib ??? (???) <328CCF97-091D-C529-E576-C78583445711> /usr/lib/libauto.dylib
              0x7fff865e4000 -     0x7fff86650fe7  com.apple.CorePDF 1.4 (1.4) <06AE6D85-64C7-F9CC-D001-BD8BAE31B6D2> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
              0x7fff86651000 -     0x7fff866e0fff  com.apple.PDFKit 2.5.5 (2.5.5) <18C99AB3-DACC-3654-200E-0BD09EBFB374> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
              0x7fff866e1000 -     0x7fff866e4ff7  com.apple.securityhi 4.0 (36638) <BAA349B3-F28D-2BFC-8DD5-2A0EE7FFB929> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
              0x7fff8670a000 -     0x7fff8670eff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <DB710299-B4D9-3714-66F7-5D2964DE585B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
              0x7fff8670f000 -     0x7fff8670fff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
              0x7fff86710000 -     0x7fff86726fe7  com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
              0x7fff8687d000 -     0x7fff86891ff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <574C1BE0-5E5E-CCAF-06F8-92A69CB2892D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
              0x7fff868b3000 -     0x7fff8696afff  com.apple.Bluetooth 2.4.5 (2.4.5f3) <169F4284-DC35-D236-9086-9760113C01D3> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
              0x7fff8696b000 -     0x7fff86984fff  com.apple.CFOpenDirectory 10.6 (10.6) <11FAE9D5-6BD2-D302-96B0-2E135049CAA7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
              0x7fff86985000 -     0x7fff86b44fff  com.apple.ImageIO.framework 3.0.6 (3.0.6) <92882FD3-CB3F-D0BE-DDDA-43B4BEE10F58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
              0x7fff86b45000 -     0x7fff86b68fff  com.apple.opencl 12.3.6 (12.3.6) <534AD81C-32AB-4C9A-5E0E-D6C6E77FA946> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
              0x7fff86b69000 -     0x7fff86c09fff  com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
              0x7fff86c0a000 -     0x7fff86c53ff7  com.apple.securityinterface 4.0.1 (40418.0.1) <9AF33A9F-2D8C-2AE6-868C-EA836C861031> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
              0x7fff86c54000 -     0x7fff86c65ff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <5BAFAE5C-2307-C27B-464D-582A10A6990B> /usr/lib/libz.1.dylib
              0x7fff86c70000 -     0x7fff86cacfe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <0109956D-D962-1736-B510-DC294F530E07> /usr/lib/libcurl.4.dylib
              0x7fff86cad000 -     0x7fff86cbafe7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
              0x7fff86cca000 -     0x7fff86d47fef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
              0x7fff86db1000 -     0x7fff86e30fe7  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
              0x7fff86efe000 -     0x7fff86f09ff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <C359B93B-CC9B-FC0B-959E-FB10674103A7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
              0x7fff86f0a000 -     0x7fff86f55fef  com.apple.ImageCaptureCore 1.1 (1.1) <F23CA537-4F18-76FC-8D9C-ED6E645186FC> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
              0x7fff86f56000 -     0x7fff86f8fff7  com.apple.MeshKit 1.1 (49.2) <B85DDDC7-4053-4DB8-E1B5-AA0CBD4CDD1C> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
              0x7fff86f90000 -     0x7fff8704dfff  com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
              0x7fff871b5000 -     0x7fff871c7fe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <30FE378B-99FE-8C7C-06D0-A3AA0A0A70D4> /usr/lib/libsasl2.2.dylib
              0x7fff871c8000 -     0x7fff876ceff7  com.apple.VideoToolbox 0.484.60 (484.60) <F55EF548-56E4-A6DF-F3C9-6BA4CFF5D629> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
              0x7fff876cf000 -     0x7fff87751fff  com.apple.QuickLookUIFramework 2.3 (327.7) <73407EAE-6854-E444-37B1-019AAEDEB31B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
              0x7fff87752000 -     0x7fff87777ff7  com.apple.CoreVideo 1.6.2 (45.6) <31802A1C-81BC-33F8-D5C8-39A793D4D926> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
              0x7fff87879000 -     0x7fff87879ff7  com.apple.Cocoa 6.6 (???) <C69E895A-1C66-3DA9-5F63-8BE85DB9C4E1> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
              0x7fff8787a000 -     0x7fff878dafe7  com.apple.framework.IOKit 2.0 (???) <2D2A51AA-4021-0F64-BE58-B0ED5388D899> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
              0x7fff8790c000 -     0x7fff87acafff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <97A75BFB-0DB6-6F44-36B0-97B7F7208ABB> /usr/lib/libicucore.A.dylib
              0x7fff87c23000 -     0x7fff87c24fff  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <EC039008-5367-090D-51FD-EA4D2623671A> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
              0x7fff87c25000 -     0x7fff87c26fff  liblangid.dylib ??? (???) <D0666597-B331-C43C-67BB-F2E754079A7A> /usr/lib/liblangid.dylib
              0x7fff88c92000 -     0x7fff88c99fff  com.apple.OpenDirectory 10.6 (10.6) <13CECF72-D84B-2A88-CB0C-2092FDF0DB5D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
              0x7fff88c9a000 -     0x7fff88ccdff7  libTrueTypeScaler.dylib ??? (???) <B7BA8104-FA18-39A2-56E1-922EE7A660AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
              0x7fff88d5c000 -     0x7fff88e7bff7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <0CE8D59B-D0C7-1DCE-3654-37F27F61BEFA> /usr/lib/libcrypto.0.9.8.dylib
              0x7fff88eb1000 -     0x7fff88f13fe7  com.apple.datadetectorscore 2.0 (80.7) <DDB40E6F-A9B6-BCDA-E758-0358A971752A> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
              0x7fff890dd000 -     0x7fff890e0fff  com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
              0x7fff890e1000 -     0x7fff89363fff  com.apple.Foundation 6.6.8 (751.63) <E10E4DB4-9D5E-54A8-3FB6-2A82426066E4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
              0x7fff89364000 -     0x7fff89369fff  libGFXShared.dylib ??? (???) <6BBC351E-40B3-F4EB-2F35-05BDE52AF87E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
              0x7fff8936a000 -     0x7fff89378ff7  libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
              0x7fff89379000 -     0x7fff89471ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <208C6671-4A63-B101-9885-7ECCE25DC34D> /usr/lib/libiconv.2.dylib
              0x7fff89472000 -     0x7fff896fbff7  com.apple.security 6.1.2 (55002) <D224882B-D57B-83AF-3781-548BCEACB327> /System/Library/Frameworks/Security.framework/Versions/A/Security
              0x7fff896fc000 -     0x7fff89712fef  libbsm.0.dylib ??? (???) <0321D32C-9FE1-3919-E03E-2530A0C1191B> /usr/lib/libbsm.0.dylib
              0x7fff8971f000 -     0x7fff89762ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <5FF3D7FD-84D8-C5FA-D640-90BB82EC651D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
              0x7fff897fb000 -     0x7fff89810ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <59D9E83D-3131-91F4-E3E2-02047F55917F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
              0x7fff89811000 -     0x7fff89c54fef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <57D38705-6F21-2A82-F3F6-03CFFF214775> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
              0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
          Model: MacBookPro8,1, BootROM MBP81.0047.B27, 2 processors, Intel Core i5, 2.3 GHz, 4 GB, SMC 1.68f99
          Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
          Memory Module: global_name
          AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 5.100.198.104.5)
          Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
          Network Service: AirPort, AirPort, en1
          Serial ATA Device: Hitachi HTS545032B9A302, 298.09 GB
          Serial ATA Device: OPTIARC DVD RW AD-5970H
          USB Device: FaceTime HD Camera (Built-in), 0x05ac  (Apple Inc.), 0x8509, 0xfa200000 / 3
          USB Device: Hub, 0x0424  (SMSC), 0x2513, 0xfa100000 / 2
          USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0245, 0xfa120000 / 5
          USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
          USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x821a, 0xfa113000 / 7
          USB Device: Hub, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
          USB Device: Ext HDD 1021, 0x1058  (Western Digital Technologies, Inc.), 0x1021, 0xfd120000 / 4
          USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd110000 / 3
          FireWire Device: unknown_device, Unknown
