1 Reply Latest reply on Dec 4, 2006 7:15 AM by Mete Atamel
    Two Sync methods
    David_S_deB Level 1
      Is it possible to have one destination with two sync methods, for say two different method calls of the same object? My Tomcat server throws the following error when I attempt to use the destiation below. all works fine if I remove the second sync method.
      Destination:
      - <destination id="Clientes">
      <adapter ref="java-dao" />
      - <properties>
      <source>com.company.project.ClientesAssembler</source>
      <scope>application</scope>
      - <!-- <ClientesDTO>List getClientes(...) used for identity purpose
      - <metadata>
      <identity property="CODCODIGONOTES" />
      </metadata>
      - <!-- <ClientesDTO>List searchClientes(...) ignored for identity purpose
      - <network>
      <session-timeout>0</session-timeout>
      <paging pageSize="200" enabled="true" />
      <throttle-inbound policy="ERROR" max-frequency="500" />
      <throttle-outbound policy="ERROR" max-frequency="500" />
      </network>
      - <server>
      - <fill-method>
      <name>getClientes</name>
      </fill-method>
      - <sync-method>
      <name>getClientes_sync</name>
      </sync-method>
      - <fill-method>
      <name>searchClientes</name>
      <params>java.util.Map</params>
      </fill-method>
      - <sync-method>
      <name>searchClientes_sync</name>
      </sync-method>
      </server>
      </properties>
      </destination>
      Error:
      [2006-11-28 14:19:10,514] ERROR [Thread-1] (log@ApplicationContext.java:675) - StandardWrapper.Throwable
      flex.messaging.config.ConfigurationException: Unable to create service 'flex.data.DataService' for 'data-service' due to the following error: Unexpected multiple values for property 'sync-method'..
      at flex.messaging.config.MessagingConfiguration.createServices(MessagingConfiguration.java:2 02)
      at flex.messaging.config.MessagingConfiguration.configureBroker(MessagingConfiguration.java: 84)
      at flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:105)
