1 Reply Latest reply on Sep 27, 2015 10:01 AM by A.T. Romano
    Elements Premiere 13
    colinb11482679
      I am creating a slide show with Adobe Premiere Elements 13. How do I change the duration of the photos all at the same time instead of each photo singlely ?
        • 1. Re: Elements Premiere 13
          A.T. Romano Level 7
          colinb
          If you are creating the slideshow solely in the Premiere Elements 9.0/9.0.1 Editor....
          After import of the source files to the Timeline....
          Select all the clips at one time, right click anywhere in the selection, select Time Stretch, set the duration 00;00;00;00 (hours;minutes;seconds;frames) and OK out of there.
          To select the clips at one time
          a. As you hold down the Shift key, click on the clips wanted in the selection
          or
          b. With the mouse cursor draw a rectangle around the clips to select them
          For before import...
          See Edit Menu/Preferences/General and the setting for Still Image Default Duration...that setting applies only to the photos that you import after the setting has been made.
          Any questions or need clarification, please ask.
          Thank you.
          ATR
