1. Re: Click Tag in Edge Animate
rosebudd Sep 28, 2015 7:48 AM (in response to animonkey13)You may find the Doubleclick Studio Edge template in page 300x250 template useful, as the DC logo is a button that clicks through.
Rich Media Gallery | Template Database
Simply make the DC logo 0% opacity, and change the dimensions to cover the entire ad. Make sure it is the topmost layer, because unlike Flash, button position matters. Or make your own 0% opacity button with the rectangle tool.
In the actions for that button, change Enabler.exit('Clicked on'); to
window.open(clickTag, "_blank");
In your published HTML document, remove the script tag call to enabler.js, as you won't be using it if your ad is not rich media, and put in its place
var clickTag = "https://www.google.com";
</script>
If you do not uncheck use CDN in publish settings change http to https
Zip your published folder contents.
Your other option is to use Google's free banner app, GWD.
2. Re: Click Tag in Edge Animate
animonkey13 Sep 29, 2015 9:03 AM (in response to rosebudd)I was able to get this to work using their sample download file. However, when I tried the same technique in my own file the link would not click through. My published
HTML document did not seem to have a script tag call to enabler.js, so I was not sure what part to replace if anything. Below is my code (which I have not modified manually).
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
<meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
<title>Untitled</title>
<!--Adobe Edge Runtime-->
<script type="text/javascript" charset="utf-8" src="http://animate.adobe.com/runtime/6.0.0/edge.6.0.0.min.js"></script>
<style>
.edgeLoad-EDGE-1724517141 { visibility:hidden; }
</style>
<script>
AdobeEdge.loadComposition('ucla1439-wh-300x250-1_4_ms', 'EDGE-1724517141', {
scaleToFit: "none",
centerStage: "none",
minW: "0px",
maxW: "undefined",
width: "300px",
height: "250px"
}, {"dom":{}}, {"dom":{}});
</script>
<!--Adobe Edge Runtime End-->
</head>
<body style="margin:0;padding:0;">
<div id="Stage" class="EDGE-1724517141">
</div>
</body>
</html>
Which part should I replace with below code?
</script>
Also, just to show you what I did in Edge...
I named the button layer with my 0% opacity shape which covers the entire screen "Clicktag".
Then I copied the window.open(clickTag, "_blank"); code into the action field.
When I published everything it also produced a JS file. Do I need to modify that in any way?
3. Re: Click Tag in Edge Animate
rosebudd Oct 6, 2015 6:26 AM (in response to animonkey13)Unless you are doing Rich Media slated for Doubleclick Studio, you do not need enabler.js.
You do need to add this outside the Edge Runtime comments
</script>
