2 Replies Latest reply on Dec 7, 2006 11:23 AM by Illusion_Of_Ender
    mouseUp
    AonSao Level 1
      In AS2, you could use both onRelease and onReleaseOutside together to ensure that you know when the mouse is released (even if the frame rate caused it to be off a little or if the mouse was released off of the stage).
      In the AS3 migration from AS2 it says that both of those were replaced with the mouseUp event... however if you just use mouseUp there are some problems. Like, as mentioned above, if the user puts the mouse off the stage and lets go, it is not registered.
      Is there a solution or trick to this?
