0 Replies Latest reply on Sep 28, 2015 10:12 PM by arasank86029633
    Export pdf script not working
    arasank86029633
      Hi Expert,
      Please any one help this is my script i am writing for export pdf.
      #targetengine main
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
      var jOptions = ["PRINTER", "EXTRAIT PDF", "LOWRES PDF", "WEB PDF"];
      var actDoc;
      var arr = [];
      var fArr = [];
      var tfFntArr = [];
      var lArr = [];
      var mFntArr = [];
      var ovstData = [];
      var errArr = [];
      var pdfprst;
      var count;
      var pWidth;
      var myJrnl;
      var jrnlType;
      var myCheck = 0;
      var myProgsPanel;
      var myProgsText;
      var hiddenText;
      Array.prototype.contains = function(k) {
          for(p in this) {
              if(this[p].split(",")[0] === k)
                  return true;
                  if (p == this.length-1)
                      break;
          return false;
      checkPresets(jOptions);
      if (app.documents.length != 0) {
          try {
              actDoc = app.activeDocument;
          catch(_){
              while (app.documents.length != 0)
                  app.documents[0].close (SaveOptions.NO);
              alert ('Please run the tool once again!', "SMART_EXPORTER");
              endFunction();
      else {
          if (app.books.length != 0) {
              if (confirm ("Do you wish to create PDF for '" + app.activeBook.name + "' book document?", "", "SMART_EXPORTER")) {
                  prosBookDocs (app.activeBook);
                  app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
                  endFunction();
              else
                  endFunction();
          else {
              alert ("No documents are kept open!", "EXPORTER");
              endFunction();
      checkFonts(actDoc);
      checkLinks(actDoc);
      checkOverset(actDoc);
      hiddenText = getHiddenText(actDoc);
      if (fArr.length > 0 || lArr.length > 0)
          errArr.push ("Missing Fonts / Links found in this document!\rFont(s): " + fArr.length + "\r" + fArr.join("\r") + "\rLink(s): " + lArr.length + "\r" + lArr.join("\r"));
      if (tfFntArr.length > 0)
          errArr.push ("TrueType fonts found in this document!\rFont(s): " + tfFntArr.length + "\r" + tfFntArr.join("\r"));
      if (hiddenText != null)
          errArr.push ("Hidden text identified page(s) Nos.: " + hiddenText);
      if (ovstData.length > 0)
          errArr.push ("Overset text identified page(s) Nos.: " + ovstData.join(", "));
      if (errArr.length != 0) {
          alert (errArr.join("\r\r"), "SMART_EXPORTER");
          endFunction();
      else
      function checkFonts(doc){
          var dFonts = doc.fonts;
          for (f=0; f<dFonts.length; f++){
              if (dFonts[f].status != FontStatus.INSTALLED){
                  fArr.push ("\t" + dFonts[f].name.replace(/\t/gi, " - "));
              else if (dFonts[f].fontType == FontTypes.TRUETYPE || dFonts[f].fontType == FontTypes.OPENTYPE_TT){
                  if (dFonts[f].name.replace(/\t/gi, " - ") != "Euclid Symbol - Regular")
                      tfFntArr.push ("\t" + dFonts[f].name.replace(/\t/gi, " - "));
          return {mf: fArr, tf: tfFntArr};
      function checkLinks(doc){
          var dLinks = doc.links;
          for (l=0; l<dLinks.length; l++){
              if (dLinks[l].status != LinkStatus.NORMAL){
                  lArr.push ("\t" + dLinks[l].name);
          return lArr;
      function checkPresets(){
          var mArr = [];
          var pdfPrsts = app.pdfExportPresets;
          for (p=0; p<jOptions.length; p++){
              if (pdfPrsts.item(jOptions[p]) == null && pdfPrsts.item("[" + jOptions[p] + "]") == null)
                  mArr.push(jOptions[p]);
          if (mArr.length > 0) {
              alert ("Please load the following PDF preset(s) and try again!\r\r" + mArr.join("\r"), "EXPORTER");
              endFunction();
      //HiddenText
      function getHiddenText (doc){
          var actPage = doc.layoutWindows[0].activePage;
          var docPages = doc.pages;
          var myObjArr = [];
          var tmpObj = [];
          var myTObjArr = [];
          var hiddenWrds = [];
          var temp;
          doc.zeroPoint = [0,0];
          Array.prototype.intersects = function(/*bounds*/pib)
          // Return TRUE if this page intersects the bounds
          // <pib> == [top,left,bottom,right]
          var b = this;
          return b[0]<=pib[2] && pib[0]<=b[2] &&
              b[1]<=pib[3] && pib[1]<=b[3];
          for (pg=0; pg<docPages.length; pg++){
              var docPageItems = docPages[pg].pageItems;
              for (dp=0; dp<docPageItems.length; dp++){
                  app.select (docPageItems[dp]);
                  if (app.selection.length == 0)
                      continue;
                  var pSel = app.selection[0];
                  if (pSel.itemLayer.visible && pSel.textWrapPreferences.textWrapMode == TextWrapModes.NONE && pSel.constructor.name.match(/Group|Rectangle/gi) != null && isOpqObj (pSel, pSel.constructor.name)) {
                      tmpObj.push (pSel);
                      tmpObj.push (pSel.geometricBounds);
                      myObjArr.push (tmpObj);
                      tmpObj = [];
                  else if (pSel.constructor.name == "TextFrame" && pSel.itemLayer.visible && pSel.contents != "") {
                      myTObjArr.push (pSel);
              for (cp=0; cp<myTObjArr.length; cp++){
                  var tLines = myTObjArr[cp].texts[0].lines;
                  var tBounds = myTObjArr[cp].geometricBounds;
                  try {
                      bPoint:
                      for (X in myObjArr) {
                          if (tBounds.intersects(myObjArr[X][1])) {
                              for (tp=0; tp<tLines.length; tp++){
                                  var lcInsertion = (tLines[tp].characters[-1].insertionPoints[-1].lines[0] != tLines[tp]) ? tLines[tp].characters[-1].insertionPoints[-2] : tLines[tp].characters[-1].insertionPoints[-1];
                                  if ([(tLines[tp].baseline - tLines[tp].ascent),tLines[tp].insertionPoints[0].horizontalOffset,tLines[tp].baseline,lcI nsertion.horizontalOffset].intersects(myObjArr[X][1])) {
                                      app.select (tLines[tp]);
                                      var tWords = tLines[tp].characters;
                                      for (tw=0; tw<tWords.length; tw++) {
                                          var wcInsertion = (tWords[tw].characters[-1].insertionPoints[-1].lines[0] != tLines[tp]) ? tWords[tw].characters[-1].insertionPoints[-2] : tWords[tw].characters[-1].insertionPoints[-1];
                                          if ([(tWords[tw].baseline - tWords[tw].ascent),tWords[tw].insertionPoints[0].horizontalOffset,tWords[tw].baseline,wcI nsertion.horizontalOffset].intersects(myObjArr[X][1])) {
                                              app.activeDocument = doc;
                                              app.select (myObjArr[X][0]);
                                              myTObjArr[cp].select(SelectionOptions.ADD_TO);
                                              app.copy();
                                              var temp = app.documents.add();
                                              app.activeDocument = temp;
                                              app.paste();
                                              app.select (temp.textFrames[0]);
                                              if (app.menuActions.itemByID(11283).enabled)
                                                  hiddenWrds.push (tWords[tw].parentTextFrames[0].parentPage.name);
                                              temp.close(SaveOptions.NO);
                                              break bPoint;
              catch(_){/*alert (_.toString())*/}
              myTObjArr = [];
              myObjArr = [];
          app.selection = null;
          doc.layoutWindows[0].activePage = actPage;
          if (hiddenWrds.length > 0) {
              return RemoveDuplicates (hiddenWrds).join(", ");
          else
              return null;
      function isOpqObj (obj, objType){
          var oCheck = 0;
          if (objType == "Group") {
              var gpItems = obj.allPageItems;
              for (gp=0; gp<gpItems.length; gp++) {
                  if (getColorProps (gpItems[gp]) || (gpItems[gp].constructor.name == "Rectangle" && gpItems[gp].allGraphics.length != 0))
                      oCheck = 1;
              return (oCheck == 1) ? true : false;
          else if (objType == "Rectangle") {
              if (getColorProps (obj) || obj.allGraphics.length != 0)
                  return true;
              else
                  return false;
      function getColorProps (cObj){
          try {
              cObj.fillColor.colorValue;
              return true;
          catch (_){ return false; }
      function RemoveDuplicates(arr)
          //get sorted array as input and returns the same array without duplicates.
          var result=new Array();
          var lastValue="";
          for (var i=0; i<arr.length; i++)
              var curValue=arr[i];
              if (curValue != lastValue)
                  result[result.length] = curValue;
              lastValue=curValue;
          return result;
      //Overset
      function checkOverset(doc){
          var docStories = doc.stories;
          for (sv=0; sv<docStories.length; sv++){
              if (docStories[sv].overflows == true){
                  try {
                      var ovstPage = getOvstPage(docStories[sv]);
                      if (ovstPage.parent instanceof Spread)
                          ovstData.push(ovstPage.name);
                  catch(_){}
              for (tv=0; tv<docStories[sv].tables.length; tv++){
                  if (docStories[sv].tables[tv].parent.constructor.name == "TextFrame" || docStories[sv].tables[tv].parent.constructor.name == "Story"){
                      for (cv=0; cv<docStories[sv].tables[tv].cells.length; cv++){
                          if (docStories[sv].tables[tv].cells[cv].overflows == true){
                              try {
                                  var ovstCellPage = getOvstPage(docStories[sv].tables[tv].cells[cv]);
                              if (ovstCellPage.parent instanceof Spread)
                                          ovstData.push(ovstCellPage.name);
                              catch(_){}
      function getOvstPage(theObj) {
          if (theObj.hasOwnProperty("baseline"))
              theObj = theObj.parentTextFrames[0];
          while (theObj != null) {
              if (theObj.hasOwnProperty ("parentPage")) return theObj.parentPage;
              var whatIsIt = theObj.constructor.name;
              switch (whatIsIt) {
                  case "Page": return theObj;
                  //case Spread : return "PB";
                  case "Character": theObj = theObj.parentTextFrames[0]; break;
                  case "Footnote":; // drop through
                  case "Cell": theObj = theObj.insertionPoints[0].parentTextFrames[0]; break;
                  case "Note": theObj = theObj.storyOffset; break;
                  case "Story": theObj = theObj.textContainers[theObj.textContainers.length-1]; break;
                  case "Application": return null;
              if (theObj == null) return null;
              theObj = theObj.parent;
           return theObj;
      thanks,
      arasan
