16 Replies Latest reply on Nov 26, 2018 4:14 AM by kalaimanis71535121
    Preflight Pre-Press
    LeoMari Level 2
      Olá a todos,
      Estamos escrevendo um Script para Preflight de Pre-Press e estamos com dificuldades para inserir alguns ítens.
      É possível verificar overprint em branco, preto composto e cor spot em objeto?
      Abaixo segue o que conseguimos até o momento.
      Agradeço a ajuda!
      // Turn debugging mesages on or off
      var debugThisScript = false;
      var xdebugThisScript = false;
      var scriptVersion = "0.1";
      // find active document
      var theDoc = app.activeDocument;
      // Arrays to hold details on the problem elements we find.
      var badBlackType = new Array();
      var badBlackIndex = 0;
      var badOverprintType = new Array();
      var badOverprintIndex = 0;
      var badFillColorType = new Array();
      var badFillColorIndex = 0;
      // Keep track if we are accidentally in RGB color mode
      var badColorMode = 0;
      // Check document color space
      if ( theDoc.documentColorSpace == DocumentColorSpace.CMYK ) {
        //all good
        debugln( "Document color space is CMYK." )
      } else {
        debugln( "Document color space is RGB." )
        badColorMode = 1;
      var dlg;
      // Loop thru all text frames in document
      for ( var i = 0; i < theDoc.textFrames.length; i ++ ) {
        var item = theDoc.textFrames[i];
        debugln( "Starting processing of text frame # " + i );
        debugln( "  Name:         " + item.name );
        debugln( "  Type:         " + item.typename );
        debugln( "  Parent name:  " + item.parent.name );
        debugln( "  Parent type:  " + item.parent.typename );
        //debugln( "  Contents:     " + item.contents );
        if ( item.typename == 'TextFrame' ) {
             debugln( '' );
        var badType = "";
          //for ( var ci = 0; ci < item.characters.length; ci++ ) {
          var inBadBlackType = false;
        var inBadOverprintType = false;
        var inBadFillColorType = false;
          for ( var j = 0; j < item.textRanges.length; j++ ) {
          var tr = item.textRanges[j];
          // xdebugln( 'text range is ' + tr.contents );
                  var fillColor;
                  try {
                      xdebugln( tr.contents + ' ' + inBadFillColorType + ' ' + badFillColorIndex);
           fillColor = tr.characterAttributes.fillColor;
                      if ( inBadFillColorType ) {
                         xdebugln ( '--------- i am here --------- ' );
                        badFillColorIndex++;
                  } catch ( e ) {
                    if ( ! inBadFillColorType ) {
          inBadFillColorType = true;
          badFillColorType[ badFillColorIndex ] = new Object();
          badFillColorType.contents = "";
          if ( typeof( badFillColorType[badFillColorIndex].contents )=="undefined" ) {
          badFillColorType[badFillColorIndex].contents = tr.contents;
          } else {
          badFillColorType[badFillColorIndex].contents += tr.contents;
                      continue;
          //var fillColor = tr.characterAttributes.fillColor;
          var c = undefined;
          var m = undefined;
          var y = undefined;
          var k = undefined;
          // we have CMYK type.
          if ( fillColor.typename == "CMYKColor" ) {
          c = fillColor.cyan;
          m = fillColor.magenta;
          y = fillColor.yellow;
          k = fillColor.black;
          } else if ( fillColor.typename == "SpotColor" ) {
          var theSpot = fillColor.spot;
          if ( theSpot.color.typename == "CMYKColor" ) {
          c = theSpot.color.cyan;
          m = theSpot.color.magenta;
        y = theSpot.color.yellow;
          k = theSpot.color.black;
          }  else if ( fillColor.typename == "GrayColor" ) {
          c = 0; m = 0; y = 0;
          k = fillColor.gray;
          // Check for bad type
          if ( k > 60 && c+m+y > 0 ) {
          if ( ! inBadBlackType ) {
          inBadBlackType = true;
          badBlackType[ badBlackIndex ] = new Object();
          badBlackType.contents = "";
          if ( typeof( badBlackType[badBlackIndex].contents )=="undefined" ) {
          badBlackType[badBlackIndex].contents = tr.contents;
          } else {
          badBlackType[badBlackIndex].contents += tr.contents;
        badBlackType[badBlackIndex].cmyk     = "" + c + " " + m + " " + y + " " + k;
          } else {
          if ( inBadBlackType == true ) {
          badBlackIndex++;
          // Check for overprint white type.
          if ( ( c + m + y + k ) == 0  && tr.characterAttributes.overprintFill ) {
          if ( ! inBadOverprintType ) {
          inBadOverprintType = true;
          badOverprintType[ badOverprintIndex ] = new Object();
          badOverprintType.contents = "";
          if ( typeof( badOverprintType[badOverprintIndex].contents )=="undefined" ) {
          badOverprintType[badOverprintIndex].contents = tr.contents;
          } else {
          badOverprintType[badOverprintIndex].contents += tr.contents;
        badOverprintType[badOverprintIndex].cmyk     = "" + c + " " + m + " " + y + " " + k;
        inbadOverprintType = true;
          } else {
          if ( inBadOverprintType == true ) {
          badOverprintIndex++;
          debugln( "--> " + tr.contents + " is " + fillColor.typename + " " + c + " " + m + " " + y + " " + k );
          // out of textframe. reset inFlag. increment index by 1 if still in;
          if ( inBadBlackType ) {
          badBlackIndex++;
          if ( inBadOverprintType ) {
            //item.contents = mapData[dataType][ key ].text;
        //item.textRange.characterAttributes.fillColor = getColorfromString( mapData[dataType][ key ].fillCMYK );
      var numProblems = badColorMode + badBlackType.length + badOverprintType.length + badFillColorType.length;
      var resultsMsg = "";
      if ( numProblems > 0 ) {
        resultsMsg +=  "Lista de problemas apresentados \"" + theDoc.name + "\"\n";
        resultsMsg +=  '\n';
        if ( badColorMode ) {
        alertMsg += "\nSeu documento está em RGB, converta para CMYK.\n"
        resultsMsg +=  'SEU DOCUMENTO ESTÁ EM RGB, CONVERTA PARA CMYK\n';
        resultsMsg +=  '==================================================================\n';
        resultsMsg +=  "File>Document Color Mode>CMYK Color.\n";
        resultsMsg +=  '\n';
        if ( badBlackType.length  ) {
        alertMsg += "\nYour document has " +  badBlackType.length + " pieces of 4-color black type."
        resultsMsg +=  'PRETO COMPOSTO!!\n';
        resultsMsg +=  '================================================\n';
        for ( var i=0; i<badBlackType.length; i++ ) {
        debugln("");
        debugln("-------------------------");
        debugln("Bad 4-color black type")
        debugln( badBlackType[i].contents );
        debugln( badBlackType[i].cmyk );
        resultsMsg += badBlackType[i].contents + "\n";
        resultsMsg +=  '\n';
        if ( badFillColorType.length  ) {
        alertMsg += "\nYour document has " +  badFillColorType.length + " pieces of type with invalid CMYK specs."
        resultsMsg +=  'BRANCO COM OVERPRINT EM FONTE\n';
        resultsMsg +=  '(Verifique seu documento!)\n';
        for ( var i=0; i<badFillColorType.length; i++ ) {
        debugln("");
        debugln(" type")
        debugln( badFillColorType[i].contents );
        debugln( badFillColorType[i].cmyk );
        resultsMsg += badFillColorType[i].contents + "\n";
        resultsMsg +=  '\n';
        if ( badOverprintType.length  ) {
        alertMsg += "\nYour document has " +  badOverprintType.length + " pieces of overprinting white type."
        for ( var i=0; i<badOverprintType.length; i++ ) {
        debugln("");
        debugln("Overprinting white type")
        debugln( badOverprintType[i].contents );
        resultsMsg += badOverprintType[i].contents + "\n";
        resultsMsg += '\n';
      } else {
        resultsMsg = 'Seu documento está OK.';
      displayAlert( resultsMsg );
      function displayAlert( msg ) {
        dlg = new Window('dialog', 'Preflight Scriba');
        var msgPnl = dlg.add('panel', undefined, 'Preflight Scriba');
        msgPnl.orientation = 'row';
        msgPnl.report = msgPnl.add('edittext', undefined, msg,{multiline:true});
        msgPnl.report.preferredSize = [600,400];
        var btnPnl = dlg.add('group', undefined, '');
        btnPnl.orientation = 'row'
        btnPnl.cancelBtn = btnPnl.add('button', undefined, 'Cancel', {name:'cancel'});
        btnPnl.cancelBtn.onClick = function() { dlg.close() };
        dlg.show();
      app.redraw();
      function getCMYKfromString( s ) {
            var cmyk      = s.split( "," );
            var color     = new CMYKColor();
            color.cyan    = cmyk[0];
            color.magenta = cmyk[1];
        color.yellow  = cmyk[2];
        color.black   = cmyk[3];
        return color;
      function getColorfromString( s ) {
        var colorType = '';
        var colorData = '';
        if ( s.match( ":" ) ) {
        var colorParts = s.split( ':' );
        colorType = colorParts[0];
        colorData = colorParts[1];
        } else {
        colorType = 'CMYK';
        colorData = s;
        var color;
        debugln( '    --> Color type: '  + colorType ) ;
        debugln( '    --> Color data: '  + colorData ) ;
        if ( colorType == 'CMYK' ) {
        } else if ( colorType == 'Swatch' ) {
        try {
        if ( theDoc.swatches[colorData] ) {
        var swatch = theDoc.swatches[colorData];
        color = swatch.color;
        } catch (e) {
        alert( "The swatch " + colorData + " doesn’t exist" );
        return color;
      true;
      // Functions start here
      function getNewName(sourceDoc, destFolder) {
        var docName = sourceDoc.name;
        var ext = '.jpg'; // new extension for pdf file
        var newName = "";
        // if name has no dot (and hence no extension,
        // just append the extension
        if (docName.indexOf('.') < 0) {
        newName = docName + ext;
        } else {
        var dot = docName.lastIndexOf('.');
        newName += docName.substring(0, dot);
        newName += ext;
        newName = newName.replace( / /g, '-' );
        // Create a file object to save the pdf
        saveInFile = new File( destFolder + '/' + newName );
        return saveInFile;
      function debugln ( s ) {
        if ( debugThisScript ) {
        $.writeln( s );
      function xdebugln ( s ) {
        if ( xdebugThisScript ) {
        $.writeln( s );
        • 1. Re: Preflight Pre-Press
          Vinicius Baptista Level 2
          Boa noite LeoMari, interessante eu trabalho em uma gráfica e já trabalhei com Preflight e Pre-press por aqui, enfim, em vez de eu interpretar todo o código que já criou acho melhor você me dizer qual é o objetivo do seu projeto, "fazer isso ou aquilo e tal", e o que está tendo problemas em fazer, espero poder ajudar de alguma forma, talvez algumas coisas eu já tenha desenvolvido e sejam úteis.
          Certamente seu projeto também me será útil.
          Abraço.
          • 2. Re: Preflight Pre-Press
            LeoMari Level 2
            Olá Vinícius, trabalho em uma editora onde temos vários ilustradores externos e estamos querendo padronizar as questões técnicas das imagens que recebemos (Vetor). Criamos uma action (se quiser dar uma olhada, envio pra você) pra aplicar overprint em preto 100% e remover quando aplicado em branco mas nem sempre é usada. A idéia é ter um preflight que acusa os problemas do arquivo, assim podemos dar um retorno mais rápido para o ilustrador. Trabalhamos com o preflight do Indesign mas nem todas as máquinas possuem o Indesign, por isso a ideia de fazer no Illustrator.
            No script que estamos desenvolvendo ele avalia se o arquivo está em RGB, se há preto nas 4 cores, overprint em branco e cor spot mas funciona apenas em fonte, queremos avaliar objeto também.
            Obrigado pela atenção.
            Abraço!
            • 3. Re: Preflight Pre-Press
              Olá agradeço se puder enviar sua action, quanto as leituras dos objetos acredito que seja possível fazer sim, só uma dúvida se conseguirmos identificar os problemas não seria melhor já corrigi-los em tempo de execução ou alguns casos existem excessões? Enfim, estarei dando uma olhada no seu script e te dou um retorno assim que possível.
              Abraço.
              • 4. Re: Preflight Pre-Press
                LeoMari Level 2
                Seria ótimo corrigir durante a execução mas ai já é muito pra mim.. Preciso da ajuda de quem entende..rs
                Se puder divulgar seu e-mail, envio a action pra vc conferir. Acho que da pra transforma-la em um script..
                Abraço!
                • 5. Re: Preflight Pre-Press
                  W_J_T Level 4
                  LeoMari wrote:    We are writing the script ... Below is what we have Achieved so far.
                  ??? Credit: mericson on Oct 10, 2013
                  illustrator-scripts/Preflight.jsx at master · mericson/illustrator-scripts · GitHub
                  • 6. Re: Preflight Pre-Press
                    LeoMari Level 2
                    Peguei boa parte de outro lugar W_J_T e estamos adaptando para nossa realidade. O correto então seria "Estamos adaptando e escrevendo...". De qualquer maneira, crédito seja dado ao Mericson caso seja ele o autor do original..
                    • 7. Re: Preflight Pre-Press
                      Olá amigo, segue abaixo o script que escrevi para os Pretos Compostos e os Brancos Overprints, ele irá remover em tempo de execução e então notificará as alterações feitas!
                      Para trabalhar com todos os objetos existentes no documento use a propriedade pageItems[ ].
                      Agora quanto a sua dúvida em relação a cor spot não entendi bem o que deseja fazer.
                      Abraço.
                      function preflight(){
                          if(app.documents.length == 0){return};
                      var totalItens = app.activeDocument.pageItems.length;
                      var totalPretoComposto = 0;
                      var totalBrancoOverprint = 0;
                      var items = app.activeDocument.pageItems;
                      //cria preto 100%
                      var preto = new CMYKColor;
                      preto.cyan = 0;
                      preto.magenta = 0;
                      preto.yellow = 0;
                      preto.black = 100;
                      //loop em todos os itens existentes no documento, transforma todos vetores preto composto em preto 100%
                      for (i = 0; i < totalItens; i++){
                          if(items[i].typename == 'PathItem'){
                              //preto composto vetores preenchimento
                              if ((items[i].fillColor.cyan + items[i].fillColor.magenta + items[i].fillColor.yellow > 0)  && items[i].fillColor.black == 100){
                                  items[i].fillColor = preto;
                                  totalPretoComposto++;
                              //preto composto vetores contorno
                              if ((items[i].strokeColor.cyan + items[i].strokeColor.magenta + items[i].strokeColor.yellow > 0)  && items[i].strokeColor.black == 100){
                                  items[i].strokeColor = preto;
                              //remove overprint em branco preenchimento
                              if (items[i].fillColor.cyan == 0 && items[i].fillColor.magenta == 0 && items[i].fillColor.yellow == 0 && items[i].fillColor.black == 0){
                                  if (items[i].fillOverprint == true){
                                  items[i].fillOverprint = false;
                                  totalBrancoOverprint++;
                              //remove overprint em branco contorno
                              if (items[i].strokeColor.cyan == 0 && items[i].strokeColor.magenta == 0 && items[i].strokeColor.yellow == 0 && items[i].strokeColor.black == 0){
                                  if (items[i].strokeOverprint == true){
                                  items[i].strokeOverprint = false;
                          if(items[i].typename == 'TextFrame'){
                              for ( var j = 0; j < items[i].textRanges.length; j++ ) {
                                  //preto composto textos preenchimento
                                  if ((items[i].textRanges[j].fillColor.cyan + items[i].textRanges[j].fillColor.magenta + items[i].textRanges[j].fillColor.yellow > 0) && items[i].textRanges[j].fillColor.black == 100){
                                      items[i].textRanges[j].fillColor = preto;
                                  //preto composto textos contorno
                                  if ((items[i].textRanges[j].strokeColor.cyan + items[i].textRanges[j].strokeColor.magenta + items[i].textRanges[j].strokeColor.yellow > 0) && items[i].textRanges[j].strokeColor.black == 100){
                                      items[i].textRanges[j].strokeColor = preto;
                                  //remove overprint de branco textos preenchimento
                                  if (items[i].textRanges[j].fillColor.cyan == 0 && items[i].textRanges[j].fillColor.magenta == 0 && items[i].textRanges[j].fillColor.yellow == 0 && items[i].textRanges[j].fillColor.black == 0){
                                      if (items[i].textRanges[j].characterAttributes.overprintFill == true){
                                          items[i].textRanges[j].characterAttributes.overprintFill = false;
                                  //remove overprint de branco textos contorno
                                  if (items[i].textRanges[j].strokeColor.cyan == 0 && items[i].textRanges[j].strokeColor.magenta == 0 && items[i].textRanges[j].strokeColor.yellow == 0 && items[i].textRanges[j].strokeColor.black == 0){
                                      if (items[i].textRanges[j].characterAttributes.overprintStroke == true){
                                          items[i].textRanges[j].characterAttributes.overprintStroke = false;
                      //resultados
                      alert('\n' + totalPretoComposto + ' = Item(s) com preto composto transformados em preto 100%.' + '\n' + totalBrancoOverprint + ' = Item(s) com branco overprint.');
                      preflight ();
                      • 8. Re: Preflight Pre-Press
                        LeoMari Level 2
                        Muito bom Vinicius, incorporei seu script no que postei acima e estou escrevendo pra colocar overprint em todos os pretos 100%.
                        Além do preto com overprint, também vou precisar colocar em uma cor spot que é a cor resposta para o professor, a diferença do livro do aluno para o do professor é uma cor Spot que imprimimos pro professor e desligamos para o aluno. Essa cor tem que estar com overprint por que se a resposta estiver encima de algum fundo, vai preservar o espaço daquela cor e dar a resposta ao aluno.
                        Mais uma vez obrigado pela ajuda!
                        • 9. Re: Preflight Pre-Press
                          Obrigado, é bom poder ajudar rs, boa sorte com seu desenvolvimento, qualquer dúvida, vá postando aqui que tentamos te ajudar, para o preto sempre overprint duplique as partes do codigo onde remove o overprint do branco e edite desta forma:
                                  if (items[i].strokeColor.cyan == 0 && items[i].strokeColor.magenta == 0 && items[i].strokeColor.yellow == 0 && items[i].strokeColor.black == 100){
                                      if (items[i].strokeOverprint == false){
                                      items[i].strokeOverprint = true;
                          A cor spot já existe e tudo que estiver nessa cor pretende deixar overprint? Estarei fazendo uns testes e se conseguir te aviso blz?
                          Abraço.
                          • 10. Re: Preflight Pre-Press
                            LeoMari Level 2
                            Maravilha.. a cor spot pode existir ou não, se existir deverá estar em oveprint.. Normalmente chamamos de CorProf em spot, magenta 100%.
                            Mais uma vez obrigado!
                            • 11. Re: Preflight Pre-Press
                              LeoMari Level 2
                              Funcinou Vinicius, consegui aplicar overprint em todos os pretos 100%. Agora estou tentando resolver a cor spot..
                              Valeu!!
                              • 12. Re: Preflight Pre-Press
                                LeoMari Level 2
                                Fiz uma mudança no Script. Tirei a parte que remove o overprint do branco e coloquei no início algumas linhas pra remover todos os overprints. Assim, no final ele coloca só no preto..
                                Está ficando bacana, falta só aplicar over na minha cor spot..rs
                                • 13. Re: Preflight Pre-Press
                                  Isso ae Leo, parabéns fico feliz em saber que está alcançando seus objetivos. Em tempo, mesmo esquema das demais coisas, segue o padrão para a CorProf:
                                          if (items[i].fillColor.typename == 'SpotColor'){
                                              if (items[i].fillColor.spot.name == 'CorProf'){
                                                  items[i].fillOverprint = true;
                                                  totalCorProfOverprint++;
                                  Se tiver mais dúvidas manda aqui, ou vá criando outros tópicos para respondermos, ficarei feliz se vc puder compartilhar o resultado final conosco.
                                  Se preferir, vbaptistacg@gmail.com
                                  Até mais, abraço!
                                  -Vinícius
                                  • 14. Re: Preflight Pre-Press
                                    kalaimanis71535121 Level 1
                                    Hi Vinicius Baptista
                                    Your Script has worked good. But I need to select overprinted white text and objects. kindly help me to do this script.
                                    • 15. Re: Preflight Pre-Press
                                      Hi kalaimanis71535121 how are you?
                                      If you want to select all white overprint(s) objects after running the script, you must simply insert this ( .selected = true; ) at each true condition like this....
                                                     //This way...
                                                  items[i].selected = true;
                                      Try and let me know if work...
                                      2 people found this helpful
                                      • 16. Re: Preflight Pre-Press
                                        Yes, it is working good.
                                        thanks
