3 Replies Latest reply on Sep 30, 2015 12:19 PM by VVanWilde52
    Animation Technique
    VVanWilde52 Level 1
      Is this style of animation achievable in AE? Or is it safer to go the tradional route to achieve this kind of effect?
      https://mir-s3-cdn-cf.behance.net/project_modules/disp/18a0c454485935.560947205de14.gif
        • 1. Re: Animation Technique
          After Effects is certainly capable of doing that kind of animation. It's not automatic, but everything saying that example can be accomplished in After Effects.
          • 2. Re: Animation Technique
            StormyCPb Level 3
            Yes you can. I'd draw lines using the pen and stroke tool on a shape layer , animate them using the Trim Paths and maybe add the Vegas effect to give some unevenness to your lines. Then add a Wave Warp to each line so they wobble/undulate and finally add Posterize Time (with a low fps, like 3-5), which will give it that stop motion effect. Then add a texture over the top of everything (may need to add Wave Warp and Posterize to this too)... That should get you started, you'll have to play around and experiment as I'm just thinking off the top of my head at the moment!
            • 3. Re: Animation Technique
              VVanWilde52 Level 1
              Thanks Stormy!
