4 Replies Latest reply on Oct 2, 2015 12:11 PM by ciprianom33135827
    How to keep audio from cutting off when rendering?
    ciprianom33135827
      When I render for output to .mp4(H.264), the audio of an imported .mpg renders to a certain point then it cuts off and there is no more audio. The video part of the movie continues to render and looks fine. The audio part renders (in the output file) up to a certain frame, then goes silent.
      Audio works fine and does not cut off when I render to Quicktime .mov.
      Audio (48.000k 16bit stereo) output is on in Output Module settings.
      Output format H.264 and set up of  following format options:
      Video Output Settings
      Format Options
      Multiplexer
      Multiplexing - MP4
      Stream compatibility - Standard
      Basic Video Settings
      Codec: MainConcept - H.264
      Profile; - High
      Level - 4.2
      Bitrate Settings
      VBR - 1 pass
      Target Bitrate  - 4
      Max Bitrate  - 5
      Advanced Settings
      Set key frame distance
            Key frame distance - 24 frames
      Audio
      Audio Format Settings
      Audio Format  - AAC
      Basic Audio Settings
      Codec  - AAC
      Audio Quality  - High
      Bitrate Settings  - 128 kps
      Advanced settings
      Precedence Bitrate
      I placed the .mpg video in a work comp so I can cut to specified time codes. I placed this work comp in a main comp. I have many copies of the work comp in the main comp - all displaying different slices of the base .mpg movie.
      Imported video is .mpg.
      Codecs of imported movie - MPEG-2 Video, AC3
      My set up.
      After Effects CS5 10.0.0.458
      MacBook Pro (Retina, 15-inch, Early 2013)
      Processor 2.4 GHz core i7
      Memory 8 GB 1600 MHz
      Thanks in advance!
      Cipriano
