1 Reply Latest reply on Oct 1, 2015 10:56 PM by Willi Adelberger
    How come all the paragraph breaks and line breaks are on the left?
    brianh723
      Some of the line breaks and paragraph breaks are on the left of the sentences. And I don't know what option do i have to change it back.
        • 1. Re: How come all the paragraph breaks and line breaks are on the left?
          Do you have an international version, in your case an Asian version installed?
          You should look into the direction of your paragraph, in such document are several levels to change from LTR to RTL reading and writing:
          • New Document & Document Set Up: Binding
          • Story
          • Paragraph
          • Character
          • Special Marker
          All can be defined in styles. You have access to the control in menu and panels if you install a version with a language to these properties. Go to the CC desktop application and change there the language of applications and install again.
          If you open such a document without a language enabled version, things are still in the document and will not get lost, but you have no commands to change or apply it except preprepared styles.
