5 Replies Latest reply on Oct 5, 2015 7:34 AM by StormyCPb
    Why are there blue outlines selecting everything at once?
    madi128
      I just started using AE and have been using a tutorial to start animating an Illustrator file. I've made my composition and turned the vectors into shapes but when I click or hover or even select a single group, every stroke has blue lines layered above it. This makes it difficult to see what I'm doing and a lot harder to select and group up my objects. Any suggestions are welcome, thank you!
        • 1. Re: Why are there blue outlines selecting everything at once?
          That's a limitation of shape layers - they draw contour overlays for the underlying shapes and there's no way to turn this off. that being said, if you really struggle, simply import multiple AI files. No harm in having multiple shape layers and you can copy & paste stuff from one to another. Eventually you will have to re-organize your stuff, anyway, to facilitate animation.
          Mylenium
          • 2. Re: Why are there blue outlines selecting everything at once?
            Unless you are going to use the shape animators there is no reason at all to change an imported Illustrator layer to a shape layer. None. In many cases changing to a shape layer is a distinct disadvantage. For example an Illustrator file filled with a gradient will loose that gradient. It would be helpful to know what tutorial you are watching. It would not be inaccurate or pessimistic to say that most of the ones that you find on YouTube teach poor and ineffective techniques. Some are just plain wrong.
            If you click on the layer color in the timeline you can change the color of the outline of the shape path. If you don't want to see the layer handles then you can use the View menu to Hide Layer Controls (Ctrl/Cmnd + Shift + h) but this makes it difficult to figure out what you have selected. If you are working with masks and not shape layers you can choose Cycle Mask Colors in the preferences panel to make multiple masks on a layer easier to work with.
            The most important thing to learn about working with After Effects is how to set up your project and your source files. I design more than 90% of my Illustrator for AE projects to that everything I want to animate is on a separate Illustrator layer and in it's default or final resting place on an illustrator artboard that is usually the same size as the comp I plan to work on. There are other things to consider when designing for video in Illustrator. For example you don't what to have a lot of single point strokes on your layers because they don't like to translate to clean lines when converted to pixels in video. You should have all small details snapped to the pixel grid in AI and for certain types of elements it is important to make sure that the size of the element is an even number pixels(points) high and wide so that these elements line up precisely with the pixel grid. There's a lot more to designing for video than just throwing a few things on the artboard and then trying to sort them out in AE.
            • 3. Re: Why are there blue outlines selecting everything at once?
              StormyCPb Level 3
              If you go to View > Show Layer Controls (uncheck this), you can continue to animate without the paths/bounding box in the way...
              • 4. Re: Why are there blue outlines selecting everything at once?
                madi128 Level 1
                Thank you so much, this is really helpful. To answer your question, the tutorial that I've been using is from Skillshare - https://www.skillshare.com/classes/design/Animating-With-Ease-in-After-Effects/2128437497? via=loggedin-home&autoPlay=1 . I've been impressed with the quality so far, but it seems like there is a lot of time spent grouping and separating elements rather than actually animating.  Do you have any other tutorials for AE that you would recommend?
