14 Replies Latest reply on Oct 2, 2015 11:18 AM by Obi-wan Kenobi
    How to create this layout in Indesign without several text boxes?
    Miiagod Level 1
      Hello all!
      My challenge is to create this layout without using several separate text boxes. How would you approach it?
      The obvious solution would be to use a separate text box for each, and then spent time aligning them, but this is what I want to avoid as there will be several changes to the copy and I don't want to start realigning each b ox every time. I tried to tackle this with the tabs settings but the issue is that my left section has several lines of text and not only one. If there was only one title on the left, then the tabs approach would be suitable.
      Any ideas? Thanks very much!
