4 Replies Latest reply on Oct 17, 2015 10:49 PM by jameel flex
    Scaling text bound through photoshop scripting
    jameel flex
      I am trying to scale the text bounding box along with the text inside.
      I want to achieve the same effect as select the text box by double clicking on text->press cntrl->then resize the bounding box by mouse
      Here is my code to generate text.
      crs is an object with scaleX, scleY, width, height properties. I want to apply the scaling to the text.
      function addText(crs)
        if ( documents.length > 0 )
        var originalDialogMode = app.displayDialogs;
        app.displayDialogs = DialogModes.ERROR;
        var originalRulerUnits = preferences.rulerUnits;
        preferences.rulerUnits = Units.PIXELS;
        try
        var docRef = activeDocument;
        // Now create a text layer at the front
        var myLayerRef = docRef.artLayers.add();
        myLayerRef.kind = LayerKind.TEXT;
        myLayerRef.name = "Text Description";
        var myTextRef = myLayerRef.textItem;
        myTextRef.contents = crs.lableName;
        // off set the text to be in the middle
        myTextRef.position = new Array( crs.xPos, crs.yPos);
        myTextRef.size = 20;
        var internalFontName = getInternalFontName(crs.fontFamily, crs.fontType);
        if(internalFontName != null)
        myTextRef.font = internalFontName;
        var R = hexToR("#"+crs.fontColor);
        var G = hexToG("#"+crs.fontColor);
        var B = hexToB("#"+crs.fontColor);
        //alert(crs.fontColor + " " + R + " " + G + " " + B);
        function hexToR(h) {return parseInt((cutHex(h)).substring(0,2),16)}
        function hexToG(h) {return parseInt((cutHex(h)).substring(2,4),16)}
        function hexToB(h) {return parseInt((cutHex(h)).substring(4,6),16)}
        function cutHex(h) {return (h.charAt(0)=="#") ? h.substring(1,7):h}
        if(isNaN(R) == false && isNaN(G)==false && isNaN(B)==false)
        textColor = new SolidColor();
        textColor.rgb.red = R;
        textColor.rgb.green = G;
        textColor.rgb.blue = B;
        myTextRef.color = textColor;
        if(crs.isFontUnderline == "true")
        myTextRef.underline = UnderlineType.UNDERLINELEFT;
        if(crs.isStrikeThru == "true")
        myTextRef.strikeThru = StrikeThruType.STRIKEHEIGHT;
        if(crs.alignLeft == "true")
        myTextRef.justification = Justification.LEFT;
        else if(crs.alignCenter == "true")
        myTextRef.justification = Justification.CENTER;
        else if(crs.alignRight == "true")
        myTextRef.justification = Justification.RIGHT;
        catch( e )
        // An error occurred. Restore ruler units, then propagate the error back
        // to the user
        alert("some error");
        preferences.rulerUnits = originalRulerUnits;
               app.displayDialogs = originalDialogMode;
        throw e;
        // Everything went Ok. Restore ruler units
        else
        alert( "You must have a document open to add the filename!" );
        var idsetd = charIDToTypeID( "setd" );
           var desc153 = new ActionDescriptor();
           var idnull = charIDToTypeID( "null" );
               var ref62 = new ActionReference();
               var idPrpr = charIDToTypeID( "Prpr" );
               var idTxtS = charIDToTypeID( "TxtS" );
               ref62.putProperty( idPrpr, idTxtS );
               var idTxLr = charIDToTypeID( "TxLr" );
               var idOrdn = charIDToTypeID( "Ordn" );
               var idTrgt = charIDToTypeID( "Trgt" );
               ref62.putEnumerated( idTxLr, idOrdn, idTrgt );
           desc153.putReference( idnull, ref62 );
           var idT = charIDToTypeID( "T   " );
               var desc154 = new ActionDescriptor();
               var idSz = charIDToTypeID( "Sz  " );
               var idPnt = charIDToTypeID( "#Pnt" );
               desc154.putUnitDouble( idSz, idPnt, crs.fontSize );
           desc153.putObject( idT, idTxtS, desc154 );
        executeAction( idsetd, desc153, DialogModes.NO );
      please help.
      Thanks in advance.
