2 Replies Latest reply on Oct 4, 2015 12:13 AM by LeoTaro
    Problems with CC SDK samples / xcode
    ivanmmmmm Level 1
      I have Illustrator CC 2015 (19.1.0) and fresh downloaded SDK (AI_CC_2015_SDK_Mac_44_0.dmg). XCode Version 6.4 (6E35b), OS X 10.5 El Capitan.
      Sample plugins don't show their panels from Window menu. I've tried FreeGrid, Tutorial, SnippetRunner. When I choose Window->SDK->SnippetRunner - nothing happens. Only EmptyPanel shows its controls (panel and control bar), but it has some strange rectangle with shadow over it, see the screenshot. What's it all about? Any ideas?
        • 1. Re: Problems with CC SDK samples / xcode
          ivanmmmmm Level 1
          Exploring other samples:
          DrawArt demo explanation says "This sample is a CS Extension; to run it, choose Window > Extensions > DrawArt.", but I have no Extensions menu under the Window.
          LiveDropShadow works well, as it has no panels to show.
          MarkedObjects seems to be working but again - when I choose "Window > SDK > Marked Objects" menu - nothing happens.
          MenuPlay, MultiArrowTool are working but they don't need panels.
          ScriptMessage - I counldn't understand where to find that panel.
          StrokeFilter - when I choose Object > Filters > Additional Filters > Dash or Wave - I get an error window with text "SDK_ASSERT File=/...local path.../samplecode/StrokeFilter/Source/StrokeFilterFlashController.cpp Line=75", which is somehow also about the plugin's panel.
          TransformButtons - when I choose Window > SDK > Transform Buttons > Show Transform Buttons Dialog - nothing happens.
          TwirlFilee - WHOA! This is the only plugin from samplecode folder which actually shows up its panel and fully works!
          Webter - Window > SDK > Webter - shows nothing.
          Any thoughts?
          • 2. Re: Problems with CC SDK samples / xcode
            LeoTaro Level 4
            You need to build the equivalent *UI projects using Flash Builder.
