4 Replies Latest reply on Dec 4, 2006 3:14 AM by flexsam
    Printing
    GeorgeWS Level 1
      I have this kinda working. I have an error in my script
      The error line is:
      thePrintView.myData.dataProvider = myData.dataprovider;
      The error is:
      Access of possibly undefined property dataProvider through a ref. with static type mx.collections:ArrayCollection
      My Array that fills the datagrid is called "myData"
      Can anyone tell me what is going on
      George
        • 1. Re: Printing
          jlingwai Level 1
          you cant not set thePrintView.myData.dataProvider equal to another dataprovider. set it equal to the arrayCollection that is the myData dataProvider.
          ex:
          public var myArry:ArrayCollection;
          public function initApp():void{
          myData.dataProvider = myArry;
          thePrintView.myData.datProvider = myArry;
          • 2. Re: Printing
            GeorgeWS Level 1
            Thanks alot!
            I figured it out. Where can I get info on making the output layout landscape. I see other stuff like font alternatRowColor but no layout margins etc.
            • 3. Re: Printing
              jlingwai Level 1
              I wanted to do the same thing. You are unable to change the printOrientation using flex. However, you can check the orientation and rotate it accordingly. I found a problem with this though. If you rotate the printDatagrid it will not display the data. I haven't tried but maybe if you rotate a canvas with a printDatagrid as a child it might work.
              • 4. Re: Printing
                flexsam Level 1
                Just remember the rule of the thumb... whenever any component is rotated (which has text), if you want the text to show up/printed the text needs to be embeded.
