11 Replies Latest reply on Oct 7, 2015 11:27 PM by camo63
    Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
    camo63
      We have implemented an automated workflow at a customers site that when the user exports to PDF from InDesign CS6, that a PNG version is also created at the same time.
      We have found though that there is a colour difference between the created PNG(RGB) file and the PDF.
      The users InDesign Colour Settings are configured as below.
      If we export to JPEG(RGB) instead of a PNG, we have the option of embedding the RGB Working Space profile we are using in our Colour Settings. The resulting JPEG matches the colour of the PDF.
      When exporting to PNG  though, we don't get the option of embedding a profile so therefore we can't Colour Manage a PNG from InDesign?
      I've looked at CC 2015 and it also doesn't have this option available.
      I know we can open the resulting PNG in Photoshop and then re-save the PNG and embed the profile there but is there a reason why it can't be done when Exporting from InDesign?
        • 1. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
          Steve Werner Adobe Community Professional & MVP
          Because the InDesign engineers didn't include that feature. Use the Photoshop workaround.
          • 2. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
            camo63 Level 1
            Thanks for your response Steve.
            But is it possible I could get a more technical response from somebody on why a format like a JPEG is supported in this way and a PNG file is not?
            • 3. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
              This isn't technical, but it probably has to do with PNG being primarily a screen rather than print format, and trying to color manage screens you don't control is harder than herding cats.
              You can filer a feature request at Feature Request/Bug Report Form
              • 4. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
                InDesign also doesn't support embedded profiles for incoming placed PNGs—an embedded profile is ignored and the document profile is assigned. I can't tell you why you can't include a profile going out. All of the major desktop browsers, at least on OSX, honor embedded profiles in PNGs, so it seems like it should be an option.
                Is the automation scripted? You should be able to add the profile via scripting.
                • 5. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
                  camo63 Level 1
                  Thanks Peter and Rob for your replies.
                  I'll certainly take up your recommendation Peter for a feature request.
                  Our Developers have created a number of InDesign plugins Rob, that allows InDesign to communicate to other systems within our workflows.
                  One of these plugins allows the user to export the InDesign page. It uses InDesign's own export function.
                  When they export as a PDF (used for Print), the plugin automatically creates a PNG file of the page so it can be used for the clients web site.
                  We'd like the PDF and the PNG files to be the same in regards to colour.
                  I'll discuss with them if we can achieve what we want through scripting.
                  Thanks again for your help.
                  • 6. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
                    If the idea is to provide a screen proof in a browser, there are still problems even if you can get the profile assigned. Current desktop browsers on OSX honor embedded profiles and I assume the same is true on Windows, but iOS tablets and phones do not. If you export a PNG and assign AdobeRGB, its appearance will shift on a tablet or phone because the profile is ignored. It isn't clear what the assumed RGB profile is on iOS, but the further away from sRGB the greater the color shift. See this thread:
                    Re: Colour shifted in iPad vs MacPro/MacBook Pro 17
                    In current OSX browsers, images with no profile are displayed as sRGB. You can see this if you load an RGB image with sRGB embedded and the same image with no profile—the display of the two will be identical. If the same is true on Windows browsers you should consider setting the InDesign document’s RGB profile to sRGB. In that case you wouldn't need an embedded profile because the exported PNG will be converted to sRGB and the current browsers are going to assume the image with no profile is sRGB and display it as sRGB.
                    • 7. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
                      The other complication is that any color management requires a properly calibrated and profiled display. Embedding a profile might guarantee the correct numbers are sent to the screen in some browsers, but that doesn't  mean they will "look" correct when displayed or match the printed output. Having someone making color decisions on an un-profiled monitor is a disaster waiting to happen.
                      • 8. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
                        That's fair to say, but on the Mac side all new machines come with a display profile installed, so an OS and browser color management system is in place out of the box. You can argue that you might get a better profile of the display if you run a hardware calibration, but there is a native white point and gamma described by the installed profile. So it would be wrong to throw up our hands and say don't bother including a source profile because we don't know what the state of CM is on anyone's machine.
                        In OSX browsers, I can see RGB images with no source profile convert into the monitor's RGB space as if the source is sRGB—an image with no profile or an sRGB profile will display the same. So if I'm not going to bother including a profile the best approach is to convert all color into sRGB.
                        More than subtle browser color problems happen if I don't convert to sRGB and also don't embed a profile. If I work in a big gamut space like ProPhotoRGB and save without an embedded profile there will be a major color shift in the browser that doesn't relate to monitor calibration and profiling. CMYK with no source profile will create a similar problem, which you can see in the link I posted in #6.
                        Here's an example of a significant browser color shift due to a missing source profile. On the left an image with ProPhotoRGB embedded in InDesign, in the middle the image saved as a PNG with the ProPhoto profile embedded and displayed in Safari, and on the right the file saved with no profile embedded:
                        So yes it would be foolish to use a web proof as a sign-off for print, but the ProPhotoRGB image with no profile would be very misleading and not useful as even a preliminary proof.
                        • 9. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
                          It would be wrong to assume that the person needing the web proof is on Mac...
                          • 10. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
                            I think the conversion to sRGB would still be best approach if there's no browser CM. It's easy enough to test for CM, save the same image with ProPhotoRGB embedded and with no profile and open them into a browser and see if the color is different, if it is the browser is color managed. I'd be surprised if Chrome and Firefox are CM'd on the Mac side but not on Windows.
                            • 11. Re: Is it possible to embed an ICC Profile when Exporting to PNG from InDesign
                              camo63 Level 1
                              Thanks so much Rob and Peter for your advise.
                              We'll change our RGB Working Space to sRGB.
                              Our customer is a retailer of furniture, electrical and white good appliances etc.
                              We're putting their printed catalogues onto their web site (using the PNG files) so that the general public can flip through the pages just as they would the catalogue.
                              We wanted the red loungefor example in the catalogue to match (as closely as we could get it) the page on the web.
                              Right now the red lounge in the catalogue is appearing a brown colour on the web.
                              I've done some testing this afternoon using the sRGB RGB Working Space and I'm getting a much closer match between the PDF and the PNG on MacOSX and Windows browsers.
                              As you said above; and in the link Rob supplied, we're not going to get a colour match with IOS devices. We can't help this.
                              Thanks again for your help and advise.
