3 Replies Latest reply on Oct 7, 2015 10:41 AM by Magus069
    variables
    Hunter191919
      I must be very stupid.
      How do i acces a global variable is a pdf form in ES4???
      Variables.name.rawValue does not work...
      topmostSubform.Page2.CodeElementen.txtCijfer       works fine... for an object... where txtCijfer is a box.
      Can find it on google...
      Many Thanks!!
        • 1. Re: variables
          Magus069 Level 4
          If it is declared as a global variable in the PDF it should be .value instead of rawValue
          Hope this help!
          • 2. Re: variables
            Hunter191919 Level 1
            Still does not work... partly:
            if (this.rawValue < 0.666) {
            xfa.form.topmostSubform.onvoldoende1.value = 1; // think my path is wrong, but can't figure out what it should be...
            Does not work...
            "this.rawValue = onvoldoende1.value"  does work somewhere else...
            • 3. Re: variables
              Magus069 Level 4
              I think just using the name value should do the trick
                   //Also global variables should be only strings, so you should give the value 1 as a string
                   onvoldoende1.value = "1";
              To make a integer value accessible, you would have to create your own script object and have get;set; functions
              By keeping the global variable as the accessible value, if you want to use it as an integer to use it for calculation you can use
              //Integer
              parseInt(onvoldoende1.value);
              //Decimal
              parseFloat(onvoldoende1.value);
              Hope this help!
