I have an array that holds the animations for a character MovieClip. On the first frame there is code which accesses this array (both are on the same layer and frame)
var attackList: Array = new Array();
attackList.push('dashBurst', 'punch');
curAnim = attackList[randomCalc(0, attackList.length)];
curAnim exists and can be defined in a different way.
By using trace statements I determined that flash was not getting any index at all from attackList. I tried attackList[0] and [1] and both threw the same error.
TypeError: Error #1009: Cannot access a property or method of a null object reference.
randomCalc is just a function that generates a random whole number between two values.
Why am I getting this error?
I got it now.
On the main timeline there was a line telling the MovieClip to skip that frame.
Oops.
I just found out that none of my Arrays are able to be accessed at all.
What am I doing wrong?
Adding more trace statements shows that none of the arrays, variables, import statements, or anything are being run.
I got it now.
Oops.
See Array - Adobe ActionScript® 3 (AS3 ) API Reference‌, maybe you should use " instead '.
attackList.push("dashBurst", "punch");
Or try another way:
var attackList: Array = new Array("dashBurst", "punch");
Hope this help!
