8 Replies Latest reply on Oct 8, 2015 2:14 AM by K159
    Change the word.
    K159 Level 1
      I want to get the last word (cursor left word) in the text frame would like to change it to another word.
         < - textFrame
          STEP 1 : Run the script.
         STEP 2 : It selects the last word by the cursor.
         STEP 3 : Get selected word.
         STEP 4 : Type the word I want to change.
         STEP 5 : Change the word.
      #targetengine session;
      main();
      function main()
          var curDoc = app.activeDocument;
          var mySel = app.selection[0];
           if(!app.selection[0])
              alert("did not select the object.");
          else if (app.selection[0].textFrames)
              if(app.selection[0].contents)   // Word blocks
                  var mySelWord = mySel.words.lastItem().contents;
              else
                  var mySelWord = "did not select the word.";
          var w = new Window ("palette", "Form");
          w.add ("statictext", undefined, "Get selected word:");
          var getText = w.add ("edittext", undefined, "");
          getText.text = mySelWord;
          w.add ("statictext", undefined, "Change the word:");
          var changeText = w.add ("edittext", undefined, "");
          getText.characters = 20;
          changeText.characters = 20;
          changeText.active = true;
          var myButtonGroup = w.add ("group");
          myButtonGroup.alignment = "right";
          var bt1 = myButtonGroup.add ("button", undefined, "Change word");
          var bt2 = myButtonGroup.add ("button", undefined, "Cancel");
          bt1.onClick = function()
              var myDocument = app.activeDocument;
             app.findTextPreferences = NothingEnum.nothing;
             app.changeTextPreferences = NothingEnum.nothing;
              //Set the find options.
              app.findChangeTextOptions.caseSensitive = false;
              app.findChangeTextOptions.includeFootnotes = false;
              app.findChangeTextOptions.includeHiddenLayers = false;
              app.findChangeTextOptions.includeLockedLayersForFind = false;
              app.findChangeTextOptions.includeLockedStoriesForFind = false;
              app.findChangeTextOptions.includeMasterPages = false;
              app.findChangeTextOptions.wholeWord = false;
              //Search the document for the string "copy" and change it to "text".
              app.findTextPreferences.findWhat = getText.text;
              app.changeTextPreferences.changeTo = changeText.text;
              myDocument.changeText();
              //Clear the find/change text preferences after the search.
              w.close();
          w.show ();
      I can get the word, if run the script after text selection(block).
      But I don't know how to get the last word without selection(block).
      Please help me.
      Even a little helps a lot.
      Thanks.
        • 1. Re: Change the word.
          Jump_Over Level 5
          Your code has trouble while veryfying selection.
          I suggest to create a new function to do this job and return a word or false.
          This function should check if:
          •     selection is Valid
          •     selection is "text-based"
          •     detect if selection is "block" or "cursor"
          •     find last word and return OR return false
          I.e. like this:
          var mySelWord = lastWord() ? lastWord().contents : "did not select the word.";
          function lastWord()
            if (!app.documents.length || !app.selection.length)
            return false;
            var
                 resWord = false,
                 mSel = app.selection[0],
                 mCursor, cIdx, mStory;
            if (mSel.hasOwnProperty ("baseline") )
                 mCursor = mSel.insertionPoints[-1];
            else return resWord;
            cIdx = mCursor.index;
            mStory = mCursor.parent;
            do {
                 if (!cIdx) break;
                 if (mCursor.words.length) {
                      resWord = mCursor.words[0];
                      break;
                 mCursor = mStory.insertionPoints[cIdx--];
                 } while (true)
            return resWord;
          use var mySelWord to further job of script
          Jarek
          • 2. Re: Change the word.
            K159 Level 1
            Your answer is very detailed.
            It really was helpful.
            Thanks Jarek !
            + ask one more.
            How to set text block like "Find"?
            • 3. Re: Change the word.
              Jump_Over Level 5
              This line in your code makes it already:
              Jarek
              • 4. Re: Change the word.
                K159 Level 1
                Hi, Jarek
                That's not what I want.
                I would like to just set the text block.
                Does that make a block(like the picture) in that code?
                • 5. Re: Change the word.
                  Jump_Over Level 5
                  So explain me what do you mean by "set the text block"
                  Jarek
                  • 6. Re: Change the word.
                    K159 Level 1
                    Sorry, I'm  English is unskilled.
                    "set the text block" means selection. Black box. Like (how) in the picture.
                    • 7. Re: Change the word.
                      Jump_Over Level 5
                      Basically, you cant write, modify, or even read javascript code for InDesign without this help site (neverending thanks for jongware):
                      Indesign JavaScript Help
                      to select text use text.select() method
                      in your specific case:
                      lastWord().select();
                      Jarek
                      • 8. Re: Change the word.
                        K159 Level 1
                        Thanks for answer and advice to the end.
