6 Replies Latest reply on May 15, 2006 6:53 PM by Newsgroup_User
    Font is always bod
    grandpuba647
      HELP! the text in my tables is always bold no matter what I do i cannot change the text out of bold no matter what i do! help
      (yes i have tried the menus) i have had this happen once before it was a keystroke that fixed it but now i cant remember it HELP ME PLEASE!
        • 1. Re: Font is always bod
          Level 7
          url would help
          • 2. Re: Font is always bod
            Level 7
            There must be a style being applied to tables. Check your css style sheets.
            Am sure you must have tried to check and see if a bold tag exists in the
            table data or not.
            Alternately could you host the page so that we can take a look? or post the
            code in your next post.
            Hope this helps.
            "grandpuba647" <webforumsuser@macromedia.com> wrote in message
            news:e4ar5a$bgn$1@forums.macromedia.com...
            > change
            • 3. Re: Font is always bod
              Level 7
              > table data or not.
              > Hope this helps.
              >> change
              Or you could have defined 1 or more rows of your table as <th> instead
              of <td>, which would make it a header and, by default, bold.
              Bonnie in California
              kroko at
              pixelplum dot com
              http://www.theanimalrescuesite.com/cgi-bin/WebObjects/CTDSites.woa
              • 4. Re: Font is always bod
                Level 7
                Bingo.
                Murray --- ICQ 71997575
                Adobe Community Expert
                (If you *MUST* email me, don't LAUGH when you do so!)
                http://www.dreamweavermx-templates.com - Template Triage!
                http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
                "Bonnie" <"kroko[Occam]"@pixelplum.com> wrote in message
                news:e4arf5$bos$1@forums.macromedia.com...
                >> sheets. Am sure you must have tried to check and see if a bold tag exists
                >> in the table data or not.
                >> the code in your next post.
                >> Hope this helps.
                >>> change
                > Or you could have defined 1 or more rows of your table as <th> instead of
                > kroko at
                > pixelplum dot com
                • 5. Re: Font is always bod
                  Level 7
                  If you are typing between <th>textherewillbebold</th> tags
                  it will show up as bold.
                  > change
                  • 6. Re: Font is always bod
                    Level 7
                    Bonnie hit it on the head... in the insert table dialogue box, you should
                    see a checkbox about using table headers... uncheck that and you shouldn't
                    then see any <th>s in your code. Headings by default will be given a bolded
                    font.
                    Nadia
                    Adobe� Community Expert : Dreamweaver
                    http://www.csstemplates.com.au - CSS Templates | Free Templates
                    http://www.perrelink.com.au - Web Dev
                    http://www.DreamweaverResources.com - Dropdown Menu Templates|Tutorials
                    http://www.macromedia.com/devnet/dreamweaver/css.html - CSS Tutorials
                    > change
