Hello, I have my web-based application developed in Flash Professional CC and exported to Flash Player 13.
In my web-based application I have 2 classes: Connection (who creates the connection with my Adobe Media Server) and GlobalObject (who creates the Remote Shared Object).
This is the code that I have:
//Class Connection
import flash.events.AsyncErrorEvent;
import flash.events.Event;
import flash.events.IOErrorEvent;
import flash.events.SecurityErrorEvent;
import flash.events.SyncEvent;
import flash.events.NetStatusEvent;
import flash.net.NetConnection;
import flash.net.ObjectEncoding;
import flash.net.SharedObject;
var nc:NetConnection = new NetConnection();
nc.objectEncoding = ObjectEncoding.AMF3;
nc.client = this;
nc.proxyType = "best";
nc.addEventListener(NetStatusEvent.NET_STATUS, netSAServerRTMPStatus);
nc.addEventListener(IOErrorEvent.IO_ERROR, onIOError);
nc.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
nc.addEventListener(SecurityErrorEvent.SECURITY_ERROR, onSecurityError);
nc.connect("rtmp://myAMS_URL:1935/myApp", "myRandomChannel");
var _ro:GlobalObject;
function onIOError(e:IOErrorEvent):void
trace("onIOError");
function asyncErrorHandler(e:AsyncErrorEvent):void
trace("asyncErrorHandler = " + e.error);
function onSecurityError(e:SecurityError):void
trace("onSecurityError = " + e.error);
function netSAServerRTMPStatus(event:NetStatusEvent):void
switch (info.code)
case "NetConnection.Connect.Success":
trace("connected");
ConnectToSharedObject();
default:
trace(e.info.code);
break;
function ConnectToSharedObject():void
_ro = new GlobalObject();
var randomRO:Number = Math.random();
_ro.connect(randomRO, nc, false);
trace(_ro.connected);
if(_ro.connected == true)
_ro.addEventListener("onNewMsg", onNewMsg);
_ro.sendNewMsg("Hello");
function onNewMsg(e:Event):void
trace(e.target.chatMsg);
//Class GlobalObject
import flash.events.EventDispatcher;
var so:SharedObject;
var connected:Boolean;
var _msg:String;
function GlobalObject()
super();
function connect(p_soName:String, p_nc:NetConnection, p_persistant:Boolean):void
// create StoredObject
so = SharedObject.getRemote(p_soName, p_nc.uri, p_persistant);
so.client = this;
// setup the onSync events
so.addEventListener(SyncEvent.SYNC, onSync);
// connect to the SO
so.connect(p_nc);
connected = true
function disconnect():void
so.close();
function onSync(evt:SyncEvent):void
trace("onSync");
public function sendNewMsg(msg:String):void
so.send("mewMsg", msg);
function mewMsg(msg:String):void
_msg = msg;
dispatchEvent(new Event("onNewMsg", _msg));
The problem is that I never receive the "onSync" event, so then I never receive the messages. What I'm doing wrong? What I have to add or modify?
I have no code on the server side (C:\ProgramFiles\Adobe\AdobeMediaServer5\applications\myApp). All this code is compiled and exported to a SWF file, and it's the file that the user loads when go to my webpage.
I hope someon could help me.
Best regards,
Manel
Hello,
The problem is fixed! The point was that the AMS folder that I created were defined as "live" by default app.Once I changed this, it works corretly.
Best regards
Hello,
Best regards
