Here's what I need:
A function is called which uses 5 arrays, one for the high damage percentage, one for the low damage percentage, one for the amount of magic points that it costs, one for the frame label, and one for the actual name of the attack. I have a system set up to play the animation, but I need this function to
(a) create a text field
(b) create smaller text fields (one on top of the other) like a list to hold each item of the array + it's MP cost
(c) if the list goes off of certain pixel bounds, it is now scroll-able.
(d) each line (which would be a separate text box) needs to be able to be clicked and send it's associated frame label (held in one of the arrays) to another function.
Is this even possible?
Use a "List" component it's more easier as you can customize it.
