2 Replies Latest reply on Oct 12, 2015 10:23 PM by ABB654
    VSH's tapes to AVCHD video same tape different segment lengths depending on overall length of record time
    ABB654 Level 1
      I have some old VHS tapes that I am trying to put on my computer.  I set up VCR record through star tech into AVCHD video with the video information below.  The concern is I don't know on the VHS tape how long the content part of the video tape is before the tape just returns to blue screen not recorded.  So I set the record for say 9.58 hours.  When I look at the video I see about 3 hours 11 mins of content.  But if I take the same VHS tape but set it to record for just under 4 hours then the content part (of the same video tape) is only 1 hr. 42 mins.  My concern is that I am missing some part of content.  I have checked multiple times and the content part ends with the same content on either the almost ten hours piece as it does on the just under 4 hours piece.
      Here's the video information for the almost 4 hour one (then further below the video information for the almost 10 hours one):
      General
      Complete name                            :  1.42 total allmost 4 hours.m2ts
      Format                                   : MPEG-TS
      File size                                : 25.3 GiB
      Duration                                 : 3h 58mn
      Overall bit rate mode                    : Variable
      Overall bit rate                         : 15.2 Mbps
      Video
      Menu ID                                  : 1 (0x1)
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : High@L4.0
      Format settings, CABAC                   : Yes
      Format settings, ReFrames                : 2 frames
      Format settings, GOP                     : M=3, N=15
      Codec ID                                 : 27
      Duration                                 : 3h 58mn
      Bit rate mode                            : Variable
      Bit rate                                 : 14.2 Mbps
      Maximum bit rate                         : 21.6 Mbps
      Width                                    : 720 pixels
      Height                                   : 480 pixels
      Display aspect ratio                     : 4:3
      Frame rate                               : 29.970 fps
      Standard                                 : NTSC
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Interlaced
      Scan order                               : Top Field First
      Bits/(Pixel*Frame)                       : 1.372
      Stream size                              : 23.6 GiB (94%)
      Audio
      Menu ID                                  : 1 (0x1)
      Format                                   : MPEG Audio
      Format version                           : Version 1
      Format profile                           : Layer 2
      Codec ID                                 : 3
      Duration                                 : 3h 57mn
      Bit rate mode                            : Constant
      Bit rate                                 : 224 Kbps
      Channel(s)                               : 2 channels
      Sampling rate                            : 48.0 KHz
      Compression mode                         : Lossy
      Delay relative to video                  : -67ms
      Stream size                              : 381 MiB (1%)
      Here's the video information for the almost 10 hour one
      General
      Complete name                            : 3.11 total 9.58 hours.m2ts
      Format                                   : MPEG-TS
      File size                                : 33.8 GiB
      Duration                                 : 9h 58mn
      Overall bit rate                         : 8 086 Kbps
      Video
      Menu ID                                  : 1 (0x1)
      Format                                   : AVC
      Codec ID                                 : 27
      Duration                                 : 9h 58mn
      Bit rate                                 : 7 460 Kbps
      Width                                    : 720 pixels
      Height                                   : 480 pixels
      Standard                                 : NTSC
      Color space                              : YUV
      Bit depth                                : 8 bits
      Bits/(Pixel*Frame)                       : 0.720
      Stream size                              : 31.2 GiB (92%)
      Audio
      Menu ID                                  : 1 (0x1)
      Format                                   : MPEG Audio
      Codec ID                                 : 3
      Duration                                 : 9h 58mn
      Bit rate                                 : 224 Kbps
      Stream size                              : 958 MiB (3%)
        • 1. Re: VSH's tapes to AVCHD video same tape different segment lengths depending on overall length of record time
          A.T. Romano Level 7
          ABB654
          I am still thinking this out.
          I have just deleted what I had written last night and now have the following questions for you.
          Given you have VHS tapes (analog) and you need to digitize them for use in your Premiere Elements projects.
          What is the "9 hours and 52 minutes" and "3 hours and 11 minutes" that you are setting for what you are calling recording? Is that really the duration that you are setting in the converter for the analog to digital conversion? What device are you using for the analog to digital conversion?
          When you recorded the original VHS tapes, what was your VCR settings at that time - SP, LP, or EP?
          More later
          ATR
          • 2. Re: VSH's tapes to AVCHD video same tape different segment lengths depending on overall length of record time
            ABB654 Level 1
            O.k. it seems there was something weird with the windows media player.  I got some information VLC media Play and when I play the video on that the content time for the sections in both the longer file vs. the shorter file is the same.  Still seems strange.  I would say the content should be the same despite how long the capture segment is set for.
            Q:  What is the "9 hours and 52 minutes" and "3 hours and 11 minutes" that you are setting for what you are calling recording?
            A:  That is just the title or identifier I used to show that one segment was recorded for 9 hours and 52 mins (the long one) and the other time the capture time was set for 3 hours and 11 mins.
            Q:  Is that really the duration that you are setting in the converter for the analog to digital conversion?
            A:  The duration for the longer one was about 9 hours 52 mins and the duration for the shorter one was about 3 hrs 11 mins.  no problem there.
            Q:  What device are you using for the analog to digital conversion?
            A:  StarTech USB2HDCAP USB 2.0 HD PVR Gaming and Video Capture Device - 1080p HDMI / Component
            Q:  When you recorded the original VHS tapes, what was your VCR settings at that time - SP, LP, or EP?
            A:   I don't know.
