5 Replies Latest reply on Nov 15, 2015 10:46 PM by Aston Ray
    Script for replacing images in .indd document
    Aston Ray
      I am using InDesign CS6 server for manipulating .indd files.
      Can some one help me out with script for replacing images by another images.
      Is this possible through  script in indesign server  or not.
      Someone please help as this is of high priority.
        • 1. Re: Script for replacing images in .indd document
          Jump_Over Level 5
          Definitely is possible.
          How do you expect this help would look like?
          Jarek
          • 2. Re: Script for replacing images in .indd document
            Aston Ray Level 1
            Thanks Jarek for replying!!!
            Do you have script for replacing images with other images or some links form where I can get some clue...
            It will be great help as I have spent all day searching for the same.
            Aston
            • 3. Re: Script for replacing images in .indd document
              Aston Ray Level 1
              Hi, thanks for your reply.
              We will pay you, but need some more clarification about other issues to....
              Do you have any idea about how to import idml through indesign server and create the .indd document.
              • 4. Re: Script for replacing images in .indd document
                Jump_Over Level 5
                Answer for all your question are "YES", so far.
                However all those questions are "Is it possible...?", "Have you any idea...?" and so on.
                If your goal is to create some automatic tool, which should be able to proccess doc "X" or "Y" with some procedures - "A", "B" or "C" - describe it, pls.
                I will try to answer any specific question you ask.
                For now I can only say: -Yes. Indesign javascript is able to open/import IDML file and modify/replace its image links executing a proper rules.
                Both InDesign and InDesign Server.
                We can continue this subject using email if you wish to.
                Jarek
                • 5. Re: Script for replacing images in .indd document
                  Aston Ray Level 1
                  Hello Jarek,
                  Thanks for reply...
                  K to be specific I have below three questions, can you please provide solution for this.
                  If you want email conversation, here my email, astonrmartin@gmail.com
                  1. I want script, which will identify all the images of indd doc, then i will replace these images with any other image, so replacing script is also needed.
                  2. Script for importing idml to indd documents.
                  3. Converting pdf to indd document.
                  All above scripts are needed for Adobe InDesign Server.
                  Reply me or mail me, waiting for your reply....
                  Aston
