• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Deployment Adobe Reader with SCCM 2007 R3
Community Beginner ,
Oct 08, 2015 Oct 08, 2015
Hello,
I have created a package with the following program to update all Adobe Reader (coming from any version (6, 7, 8, 9  to 10)
rem Installation Adobe Acrobat Reader 10.1.15 (for all client with version 10.x.x. and below)
net use \\CONFIGMGRSRV\D$\Applications\Adobe\Acrobat\10.1.15\Reader\AdbeRdr1000_mui_Std
msiexec.exe /i "AcroRead.msi" ALLUSERS=1 /q /norestart TRANSFORMS="AcroRead.mst"
net use \\CONFIGMGRSRV\D$\Applications\Adobe\Acrobat\10.1.15\Reader\AdbeRdr1010_mui_Std
rem installation update 10.1.15
msiexec /update AdbeRdrUpd10115.msp /norestat
if "%errorlevel%"=="0" cls &Echo Success.
if "%errorlevel%"=="1" cls &Echo Fail
exit 0
but the  update to 10 works but not the upgrade to 10.1.15, it sys that the program updated does not exist on the client???
Why?
Dom
TOPICS
Acrobat
Views
813
Translate
Translate
Report
Report
Community guidelines
community guidelines
Oct 13, 2015 Oct 13, 2015
Hello,
I noticed also that the items in Add/remove Programs are not consistent:
two items but on another machine I have only 1 item!!!
So several questions now:
Why only the MUI updates works on an 10.1.0 not MUI and not the regular 10.1.15 (Not MUI)?
Why the 10.1.0 does not show in Ad/Remove program?
Dom
Votes
Translate
Translate
Report
Report
Adobe Employee ,
The first screenshot on top shows that you have Adobe Reader X English installed in one instance and Adobe Reader X MUI (Multilingual) in the other instance.  So essentially you have two Adobe Readers installed on one machine.
The second screenshot on botton shows only the Adobe Reader X MUI  (Multilingual) installed.
Votes
Translate
Translate
Report
Report
What do you call instance? I have only one server with supposedly only one reader active ???
Also why I am able to update manually 10.1.0 to 10.1.11 but never to 10.1.15?
Dom
Votes
Translate
Translate
Report
Report
Adobe Employee ,
The Windows Programs Control Panel has two entries of the Adobe Reader X listed.  That means at some point the server was installed with Adobe Reader X ENU and Adobe Reader MUI (Multilingual).  I am not sure as to the reason why you haven't been able to update but the recommendation would be to remove both versions of Adobe Reader X, decide which version of Adobe Reader X or later that you want to exist on your server, and then install that version of Adobe Reader.
Votes
Translate
Translate
Report
Report
I will uninstall the MUI as I need only English...
the update is a real concern as I am blocked so far to 10.1.11 and the other updates failed saying the original product is not installed !!!
Votes
Translate
Translate
Report
Report
Oct 14, 2015 Oct 14, 2015
this is the command file I am trying to use for the update:
rem installation update 10.1.16
msiexec /p AdbeRdrUpd10116.msp /qn /norestat
exit 0
What is worng as it does not work..
If  run locally the msp everything is fine
DOm
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Oct 15, 2015 Oct 15, 2015
Try using the verbose logging switch  for MSI installations to see what happens during the failure.
Msiexec (command-line options)
Votes
Translate
Translate
Report
Report
Oct 19, 2015 Oct 19, 2015
LATEST
After checking there was a spelling error restat instead of restart..
Dom
Votes
Translate
Translate
Report
Report
