The only discussion that I found that is similar to the problem we're experiencing is Clearing application buffer after a live stream ends
but suggestion resolution didn't help (adding &adbe-record-mode=record to stream name).
Problem is that after the publishing is stop, AMS keeps streaming the last ~30s of the unPublished stream. Also I tried playing around with Event.xml settings but
applications/livepkgr/streams/_definst_/streamname/* keeps on persisting regardless of how much time passed since streaming ended (even if you try accesing the same stream day after it stops it will still play/stream the last chunk).
Encoder (we tried FMLE and WIrecast with same results)
FMLE with recommended settings end the stream with:
Fri Oct 09 2015 10:36:10 : Video Encoding Stopped
Fri Oct 09 2015 10:36:10 : Session Stopped
Fri Oct 09 2015 10:36:10 : Primary - Network Command: onFCUnpublish
Fri Oct 09 2015 10:36:10 : Primary - Stream[fmletest] Status: NetStream.Unpublish.Success
AMS version 5.0.9.
FMLE 3.2
What else can we try to set on a AMS side in order to app/stream be terminated once encoder stops publishing?
