0 Replies Latest reply on Oct 9, 2015 12:25 PM by PHP Daddy
    Property Scripts(?)
    PHP Daddy
      I was researching a way to get my movie to do hilite several words in a text field string that are the
      result of a search, when I came across the sample movie 'handy 185'.
      I downloaded the file and looked at the scripts to get an idea of what I needed to do.
      I do not like to simply 'copy' code from something. The scripts use 'property this' and 'property that'.
      I haven't gotten that far in my Director self-training yet. I label everything a 'global' and take the long road, IMO.
      This is a 'commented by me' sample of the code from 'handy 185':
      property pMemRef --I guess this is the search word
      property pStartColor --the original color of the field text
      property pHiliteColor --the color that the creator want to use to hilite
      property pWholeWord --the checkbox for whole word searches
      property pStatusMem --a line of text acting as the search field
      on beginSprite me
        pMemRef = sprite(me.spriteNum).member --the cat member of the search field
        pStartColor = pMemRef.color --capturing the original text color
        pHiliteColor = color(#rgb, 255, 0, 0) --the new color
        pStatusMem.text = EMPTY --A line of text to display the results
        me.resetMyColor() --the orders to change the text color
      end
      on setWholeWordSearch me, flag
        pWholeWord = flag --if whole word is selected then remember that for the search
      end
      on resetMyColor me
        pMemRef.color = pStartColor --storing the original text color
      end
      on hiliteWord me, wordSearch
        if not voidP(wordSearch) then --if the search result in not void then
          if wordSearch <> EMPTY then --if the result has matches then
            me.resetMyColor() --execute the color reset
            tempStr = pMemRef.text --temporarily store the search word
            hiliteList = [] --a list to store the results
            counter = 0 --the count of an empty list
            repeat while offset(wordSearch, tempStr)
              startChar = offset(wordSearch, tempStr) --if there is a match this returns 1
              endChar = startChar + wordSearch.char.count - 1 --identifying the last character of the search word
              flag = true --when whole word is chosen
              if pWholeWord then --if whole word is chosen then
                prevChar = tempStr.char[startChar-1] --identifying the last character before the search result
                nextChar = tempStr.char[startChar+wordSearch.char.count] --identifying the first character after the search result
                charString = "abcdefghijklmnopqrstuvwxyz" --the alphabet
                if charString contains prevChar or charString contains nextChar then --if the characters before or after the match are anything other than blank
                  flag = false
                end if
              end if
              if flag then
                hiliteList.append( [counter + startChar, counter + endChar] ) --add to the list the number of the match and what the start and end characters of the match are
              end if
              delete char 1 to endChar of tempStr
              counter = counter + endChar
            end repeat
            if hiliteList.count > 0 then --if there are results then
              repeat with i in hiliteList --repeat for the number of list contents
                pMemRef.char[i[1]..i[2]].color = pHiliteColor -make each of the results characters the new color
              end repeat
              if hiliteList.count = 1 then --if the result was just one
                pStatusMem.text = "There was 1 match."
              else --or more than one
                pStatusMem.text = "There were" && hiliteList.count && "matches."
              end if
            else -- or none
              pStatusMem.text = "There were no matches."
            end if
          end if
        end if
      end
      on getPropertyDescriptionList
        return [#pStatusMem: [#format: #text, #default: 0, #comment: "Selet status text member:"]] --not sure about this line
      end
      I can't access what this code and the rest of the code is doing. With my globals I can see everything.
      Can someone kindly put me on the track to either understanding how this code works or possibly
      giving me a non-property workaround?
      Rodney
