1. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
Chetna SrivastavaOct 9, 2015 3:55 PM (in response to dawnc50274317)
Hi dawnc50274317,
would suggest you to follow the steps mentioned in this thread :
Error Message Server Busy During Startup
and right click on Lightroom icon and choose run as administrator.
2. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
dawnc50274317 Oct 9, 2015 4:20 PM (in response to Chetna Srivastava)Have done that and does not make a difference. I had a windows and LR update yesterday, ever since it has done this. I have uninstalled, reinstalled. Bridge works, PS works. I need this figured out, the thought of doing 2 full weddings in PS scares me.
3. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
Chetna SrivastavaOct 9, 2015 4:25 PM (in response to dawnc50274317)
Thanks for the update.
Following steps should help in getting the error fixed :
- Remove all the devices connected to the computer.
- Disable the superfetch and windows search services also make sure that the same has been removed from the task manager .
- End all the adobe processes .
- Restart the computer .
- Launch Lightroom with admin rights.
4. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
dawnc50274317 Oct 9, 2015 4:30 PM (in response to Chetna Srivastava)like remove them by unplugging or removing the drivers?
5. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
Chetna SrivastavaOct 9, 2015 4:34 PM (in response to dawnc50274317)
just by unplugging them.
6. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
dawnc50274317 Oct 9, 2015 10:59 PM (in response to Chetna Srivastava)So I did that and all it did was slow down my PC. Lightroom, is now more jacked up. It turns on, then goes black and then white. This is the first problem I have had with my PC since I had it built.
7. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
Akash SharmaOct 9, 2015 11:04 PM (in response to dawnc50274317)
Hi dawnc
Go to Edit - Preferences - Performance and uncheck Use Graphics Processor.
Close and reopen Lightroom
Let us know if that helps
~Akash
8. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
dawnc50274317 Oct 9, 2015 11:50 PM (in response to Akash Sharma)I found an driver update for my graphics cards. Currently I am downloading it. If it doesn't help then I will try that. Thank you for the swift reply
9. Re: I cannot use Lightroom. Server busy, switch to or retry message keeps popping up.
dawnc50274317 Oct 10, 2015 12:01 AM (in response to dawnc50274317)Thank you for your help.
So for anyone who comes across this problem, update your Graphics card to the newest version for Windows 10. It will save you days of headaches.
