1 Reply Latest reply on Oct 9, 2015 2:30 PM by Peter Spier
    InDesign crashes when I move an object with my direct select tool
    mariabelita313
      Hi there,
      I have no issues opening indesign, I have no issues scaling, editing and changing objects in any way shape or form but the moment I try to drag/move an object with my selection tool- my indesign crashes. Same thing with Illustrator.
      I'm on a 2014 15" macbook pro, OSX 10.9.5 and indesign CC (2014 release) version 10.0.0.70 and illustrator
      Here are the first ten lines in the Indesign crash report:
      Process:         Adobe InDesign CC 2014 [42194]
      Path: /Applications/Adobe InDesign CC 2014/Adobe InDesign CC 2014.app/Contents/MacOS/Adobe InDesign CC 2014
      Identifier: com.adobe.InDesign
      Version: 10.0.0.70 (10000)
      Code Type:       X86-64 (Native)
      Parent Process: launchd [249]
      Responsible:     Adobe InDesign CC 2014 [42194]
      User ID: 1584883763
      Date/Time: 2015-10-09 11:46:39.077 -0500
      OS Version:      Mac OS X 10.9.5 (13F34)
      Report Version:  11
      Anonymous UUID: 8C821D6D-CCE9-63EF-FB28-14214422FDC3
      Sleep/Wake UUID: B5DF541E-36ED-47C4-9229-AFC08D0FE20C
      Crashed Thread: 0  Dispatch queue: com.apple.main-thread
      Exception Type: EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: KERN_INVALID_ADDRESS at 0x00007f920001d023
      VM Regions Near 0x7f920001d023:
          MALLOC_NANO            0000618000a00000-0000618003e00000 [ 52.0M] rw-/rwx SM=PRV
          MALLOC_TINY            00007f92e0c00000-00007f92e1000000 [ 4096K] rw-/rwx SM=PRV
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0 com.apple.CoreFoundation         0x00007fff8691c9d0 __CFPasteboardLockTry + 160
      1 com.apple.CoreFoundation         0x00007fff86997c26 CFPasteboardBeginGeneration + 70
      2 com.apple.HIServices                   0x00007fff86ab4aef PasteboardClear + 33
      3   com.adobe.InDesign.Application UI       0x0000000117aaf0ee 0x11796e000 + 1315054
      4 com.adobe.InDesign.Application UI       0x00000001179ed9db 0x11796e000 + 522715
      5 com.adobe.InDesign.Layout UI  0x00000001173dd806 0x1172e1000 + 1034246
      6 com.adobe.InDesign.Layout UI  0x000000011730400a 0x1172e1000 + 143370
      7 com.adobe.InDesign.Layout UI  0x00000001172f0f61 0x1172e1000 + 65377
      8 com.adobe.InDesign.Layout UI  0x00000001172f0bfc 0x1172e1000 + 64508
      9 DV_WidgetBinLib.dylib                0x000000010d2f9edb DVEventHandler::DVPointerEvent(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool&) + 315
      Here are the first few lines of the illustrator crash:
      Process:         Adobe Illustrator [42754]
      Path:            /Applications/Adobe Illustrator CC 2014/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
      Identifier:      com.adobe.illustrator
      Version:         18.0.0 (18.0.0)
      Responsible:     Adobe Illustrator [42754]
      User ID:         1584883763
      Date/Time:       2015-10-09 14:12:43.483 -0500
      Report Version:  11
      Exception Type:  EXC_BREAKPOINT (SIGTRAP)
      Exception Codes: 0x0000000000000002, 0x0000000000000000
      Application Specific Information:
      *** CFRelease() called with NULL ***
      0   com.apple.CoreFoundation       0x00007fff868ba4c4 CFRelease + 724
      1   com.adobe.dvaui.framework     0x000000010959462e dvaui::datatransfer::OS_SendData::~OS_SendData() + 62
      2   com.adobe.illustrator         0x0000000100626b7d std::vector<DCSPlateInfo*, std::allocator<DCSPlateInfo*> >::_M_fill_insert(__gnu_cxx::__normal_iterator<DCSPlateInfo**, std::vector<DCSPlateInfo*, std::allocator<DCSPlateInfo*> > >, unsigned long, DCSPlateInfo* const&) + 67325
      3   com.adobe.illustrator         0x0000000100517433 std::_Rb_tree<AIFolderType, std::pair<AIFolderType const, ai::FilePath>, std::_Select1st<std::pair<AIFolderType const, ai::FilePath> >, std::less<AIFolderType>, std::allocator<std::pair<AIFolderType const, ai::FilePath> > >::_M_erase(std::_Rb_tree_node<std::pair<AIFolderType const, ai::FilePath> >*) + 138931
      4   com.adobe.illustrator         0x000000010051484c std::_Rb_tree<AIFolderType, std::pair<AIFolderType const, ai::FilePath>, std::_Select1st<std::pair<AIFolderType const, ai::FilePath> >, std::less<AIFolderType>, std::allocator<std::pair<AIFolderType const, ai::FilePath> > >::_M_erase(std::_Rb_tree_node<std::pair<AIFolderType const, ai::FilePath> >*) + 127692
      5   com.adobe.illustrator         0x0000000100504594 std::_Rb_tree<AIFolderType, std::pair<AIFolderType const, ai::FilePath>, std::_Select1st<std::pair<AIFolderType const, ai::FilePath> >, std::less<AIFolderType>, std::allocator<std::pair<AIFolderType const, ai::FilePath> > >::_M_erase(std::_Rb_tree_node<std::pair<AIFolderType const, ai::FilePath> >*) + 61460
      6   com.adobe.illustrator         0x0000000100502173 std::_Rb_tree<AIFolderType, std::pair<AIFolderType const, ai::FilePath>, std::_Select1st<std::pair<AIFolderType const, ai::FilePath> >, std::less<AIFolderType>, std::allocator<std::pair<AIFolderType const, ai::FilePath> > >::_M_erase(std::_Rb_tree_node<std::pair<AIFolderType const, ai::FilePath> >*) + 52211
      7   com.adobe.illustrator         0x00000001004d9ca9 std::_Deque_base<unsigned short, std::allocator<unsigned short> >::_M_initialize_map(unsigned long) + 20137
      8   com.adobe.illustrator         0x0000000100483a42 std::_Rb_tree<ai::UnicodeString, std::pair<ai::UnicodeString const, std::pair<ai::ColorSpace, bool> >, std::_Select1st<std::pair<ai::UnicodeString const, std::pair<ai::ColorSpace, bool> > >, std::less<ai::UnicodeString>, std::allocator<std::pair<ai::UnicodeString const, std::pair<ai::ColorSpace, bool> > > >::_M_insert_unique(std::pair<ai::UnicodeString const, std::pair<ai::ColorSpace, bool> > const&) + 13346
