3 Replies Latest reply on Nov 16, 2015 2:53 AM by khatwani
    Permission Issue Lightroom, Cannot create required folder
    roxanaw18490748
      I just set up Lightroom / photoshop and I'm having trouble loading Lightroom when I open it this pops up internal error has occurred, cannot create the require folder library/applcation support/adobe/lightroom/develop presets and also another after that .
      Can anyone help with my Lightroom set up problem?
      Message was edited by: Jitendra Khatwani
        • 1. Re: Permission Issue Lightroom, Cannot create required folder
          khatwani Adobe Employee (Admin)
          Hi roxanaw,
          Greetings!!!
          This is a permission issue.
          Try giving permissions to both the Libraries (System Library & user Library) and the Applications folder.
          For Applications Folder
          Open Finder
          On the left panel you will find applications folder ->  right click on that (CTRL + Click) and then click on Get Info.
          At the bottom you will find sharing and permissions - Click on that
          You will find a Lock icon at the bottom right , please click on that lock icon and then it might ask you for your mac password, please put in that.
          Now click on the small plus(+) icon and then add the users that you want , Please make sure that you are adding the admin account as well.
          Provide read and write permissions to all.
          Click on the gear icon at the bottom of the get info window and then choose "Apply to enclosed items "  This will pop a message that changes cannot be undone- click OK to that.
          This will apply privileges and that might take a bit time depending upon the size of folder.
          once done , Click on lock icon and then close the get info window.
          Done with applications folder here.
          For User Library
          Open Finder
          Click on Go at the top and then select "Go to folder"
          type "~/Library" and press go
          Right Click(CTRL + click) on the the Library folder, if you are inside that library you can right click (ctrl + click) at blank space between the folders and then click on Get Info
          Done with user library folder here.
          For System Library
          Open Finder
          type "/Library" and press go
          Done with System library folder here.
          Please let me know if that works
          Please Note : Do not just right click on complete MAC HD and provide full permissions that can make MAC in no boot mode.
          Regards
          Jitendra
          • 2. Re: Permission Issue Lightroom, Cannot create required folder
            jovanwolfe
            Thank you for this. It worked!!!
